- 11 Mar 2013
Seems a bit steep for a 970 with a reference cooler. Colectors perhaps?
You bet. Won't be many of these around.
Awesome. Just got my 2nd MSI 970, but i would consider swappingYes they shall get a few from me.![]()
What difference does £20 make? If you're spending £300 anyway...
I wonder why the reference design isn't more readily available aesthetically its much nicer with the added bonus of dumping the hot air outside the case, that's a win win as far as i'm concerned.
A reference card exhausts out of the case via the pci slots. As opposed to a non ref card which dumps heat into the case. Hence why the ref cooler is a better choice if you intend to run sli. You can run non ref cards in sli, but the top one will always run a good deal hotter than the lower one as the air from it gets trapped in the space. This is an issue i have using non ref 780's in sli.As a noob, what is the difference/advantages of having a reference card and the nvidia cooler?
Im not interested in overclocking etc, just want it to work and not be noisy i.e. Coil whine, buzzing?
This or any of the non ref 970's as a single card will be fine. A non ref model will run a bit quieter, though this new nvidia reference cooler is supposed to be pretty quiet too. You will still have hot air dumped into the case with a non ref card. But it's only a small amount and doesnt do any harm.
Hi there
Good news regarding coil whine, we've requested our factory to make some changes to the capacitors on our cards, the revisions include:-
Capacitors surrounded by plastic containers which are then stuck to the PCB by glue, very similar/same to what Powercolor themselves do on PCS+ cards. This will help reduce coil whine and eliminate it. This has cost us extra but we won't be moving our retail price on this model.
A photo of the capacitor in the container:
As the OcUK 970 is a design/build request by myself I have influence over the parts used and my original specification was NVIDIA BGA + Samsung memory, so built to NVIDIA standard using only NVIDIA approved components, so the quality was already high. We've just now implemented everything we can to help reduce/eliminate coil/whine into the design.![]()
how will we know which have this will there be mark 1 and mk2 ? has this been applied to all the pre order cards ?
Hi there
Nice one!
Could be a game changer for me.
If it wasn't for that other 970 you're designing.
Or are they one and the same?
