OK, I'm considering putting some ethernet lines/sockets around the house.
My ADSL comes into my study, and I'm planning on running a single ethernet line through a wall straight into the (neighbouring) garage to a new switch. And for that switch to then have two lines back through the same wall, through loft space (over single story) down the house, out of the rear wall of the house, down that wall, with one wire going back through the wall into the living room, and the other one into the playroom.
Diagram:-
Cables:-
- The blue cables are regular ethernet cables you use between devices. These are patch cables? ie: Regular Cat5e cables?
- The red cables would be cat5e cable spec'd to be able to go outdoors, and would be connected wall socket to wall socket.
Switches:-
- They will all be gigabit spec! Will Cat5e cable over these lengths be gigabit friendly?
Questions:-
- Any obvious issues with my diagram? ie: Traffic going through 3 switches, and 4 sockets? Using Cat5e cables instead of higher spec?
- Can anyone please recommend nice subtle single socket wall sockets for me to put in the living room/playroom? They will need to be surface mounted and as small/subtle as possible, covering the hole/wire coming in from behind, and ideally down facing (ie: ethernet wire plugs in bottom)?
- Where connecting the ethernet cable (red) from socket to socket, is this easy? ie: Just connecting the correct colours into the correct connectors in each socket?
Any help/advice would be most appreciated!
Diagram:-
Cables:-
Switches:-
Questions:-
