I think you should go with 17-55mm 2.8
Why I didn't (and it was a close call)
I have 10-22mm
Have 50mm 1.8
Wanted the creativity of f1.4 35mm over the versatility of zoom.
I personally think 85mm is too long for your purposes. I love my 100mm macro 2.8 but it's very very long on a crop body
Anything 30-50mm seems good for portrait
The 17-55mm covers this completely and is meant to be very very good in all regards
I still want to try one (especially if it is faster to focus than me sigma)
So the canon version rather than sigma?
You might as well get something that's sharp and that can spend a lot of time on your camera(but yes was pricy 550 I think )
18-35mm is similarly priced
I would have gone second hand. But none exist. The canon 17-55mm has 2nd hand listings all the time
Mpb are excellent
What do you guys think to the
Canon EF 24-70mm f2.8L II USM Lens
and no, it's not me lolWhat do you guys think to the
The Tamron 17-50 2.8 (non-VC) is a good alternative to the Canon 17-55 and much easier on the wallet. That and an 85mm f/1.8 (or Sigma 85 f/1.4 if you can afford it) should cover a lot of bases.
Good lens but that range suits a full frame camera really whereas you're left a bit wanting at the wide end for a crop body.
17-55mm F2.8!
The 15-85mm is another good crop body lens but that doesn't have a fast constant aperture like the 17-55mm so it wouldn't be as good for what you want it for imo.
Good lens but wouldn't be my first choice for a crop body
