What size screw for the r9 290 ref screws?
22 Nov 2004
I had a screwdriver set but i have misplaced it, going to order a new set but i want to make sure i get the right size head for the gfx card screws.
Not sure on the exact size but I usually use either a jewellers driver set or find something in a bit set that fits.
For the Fan screws?
I use an inexpensive Belkin F8E060 10-Piece Computer Tool Kit, it has the right size Phillips Screewdriver for those fiddly little fan screws.
Yeah it's to take the cooler off/put it back on. Thinking of going crossfire but i'll have to put the stock cooler on while i test before putting the second card under water.
Yeah that kit works for that, i have had my 290 Cooler off with it. i'm more comfortable using it for PC's than i am standard screw drivers, as its for PC's they should be demagnetized.
