Need a new tyre
6 Jan 2006
Newcastle upon Tyne
I have a slow puncture so went to Tyre Spot and they said they cant get the speed rating for mine apparantly? Its a 245/45 R18 100Y. Ive had a look on blackcircles.com but there are loads of different brands to chose from! Should I just go with the same Bridgstone that I have on there currently (they are one of the most expensive) or will another manufacturer be ok? The bridgestones are coming out at £155 fitted.
Or if there is anywhere else to look at I'll happily take a look!
If its only one tyre, fit the one you currently have.
Have a look on camskill and tyreleader. Some good prices on there. Get the tyres delivered then go to a garage and get them fitted.
Thanks, will check them out now
What car?
A6
Maybe a daft question but do you mean stick with the same brand and model? The tyre I have has a hole in it :p
