I'm half considering selling on my GTX 770 (friend has offered £160) and going for that Zotac 780ti... Am I mad? Planning on a monitor upgrade to 1440p early next year which is my 'justification'![]()
Go for it
Could I have the gigabyte or Asus ti for under £300 pleeease![]()
You mentioned the KFA2 is £289??! Is that the HOF 780 ti one, because that is £389 on the website. I must have misunderstood. If it is £289 I will buy it Friday lol!
I have to say i think i rate the 780 higher than the 970, never mind the 780TI
The 970 just looks a bit like a GTX 770 with a massive overclock.
It's the reference one.
Yeah I know what you mean, I rate the 280X higher than the R290 because the 290 just looks like a HD5870 with a modified shroud >.>
Lol
Seriously, you rate the 780 higher because it runs hotter, slower, uses more power and doesn't over-clock as well, but does that while not using GTX760/770 PCB's? /facepalm
That 3DMark Firestrike score for the 980 seems very low
Lol
Humbug's still trying to get over the most pointless amd release in history, the 2gb 285 tonga.![]()
when the 970's were released i thought about getting a pair to replace my 780's in sig. The drop in power use and heat alone would have been worth it let alone the higher oc potential. Didn't go through with it though as 780 prices plummeted like a lead balloon.I have to say i think i rate the 780 higher than the 970, never mind the 780TI
If the load is held constant, then the lower power consumption measurements vanish immediately. There’s nothing for GPU Boost to adjust, since the highest possible voltage is needed continuously. Nvidia's stated TDP becomes a distant dream. In fact, if you compare the GeForce GTX 980’s power consumption to an overclocked GeForce GTX Titan Black, there really aren’t any differences between them. This is further evidence supporting our assertion that the new graphics card’s increased efficiency is largely attributable to better load adjustment and matching.
Maxwell is very clever with its fast adaptive power switching.
Even if you are comparing performance to power consumption in either real working loads or synthetic unrealistic loads, you have to compare the performance achieved to the consumption. Loading a gpu up in furmark or equivalent app, and measuring current draw is irrelevant as far as i'm concerned. For example there's no point loading all cores up on an fx8370 in prime and stating it consumes ridiculous power, when an I5/i7 consumes considerably less.
Where if you compared the workload in a real app such as handbrake encoding then the performance vs the consumption becomes relative.
Nvidia's maxwell in most situations is providing greater performance than gk110 with a refined architecture and more importantly with considerably less shaders and on 28nm. Pushing a 2560 core maxwell on 28nm is getting close to the limit, but Maxwell looks to scale well in the future.
Whilst they aren't intended as compute cards, considering their smaller shader configuration, they can still provide great compute performance over Hawaii or gk110 for example.
http://www.anandtech.com/show/8526/nvidia-geforce-gtx-980-review/20
