Intel pledges Skylake ramp in 2015: Intel to begin manufacturing its Skylake processors in 2015
So I assume my Xeon E3 1230 V2/Core i7 3770 should be OK for the next year or so??
If you're just gaming etc, will probably be ok for the next 3-5 years :D, especially with upcoming DirectX 12 taking the pressure of the CPU..
Let's be honest, we rarely buy out of pure need, eventually one of the new and shiny chips that come along you will want it whether you need it or not, for me it was X99 + 5820K :p
Next Intel CPU's have double the cores, cache and ddr4, which when all combined will be far more powerful than you 'highly clocked haswell'.
What so many games being multi-threaded now, plus all new games ported from ps4/xb1 will use all 8 cores, Haswell is in no way future proof imo.
i predict they will be 10 - 15% faster than current cpus at the same price... they have no reason to ram up performance...
I will be limited to the consumer sockets for a while,as I prefer SFF builds. Most of my usage is for gaming and image work anyway.
Intel’s Skylake-S ES-1(Engineering Sample) processors pictured
http://wccftech.com/intel-14nm-skylakes-engineering-samples-spotted/
The processors will feature a 2.3Ghz Core Clock and a 2.9Ghz Turbo Clock. Another configuration will have 2.2 Ghz Core Clock with 2.4Ghz of Turbo. TDP will be 95W and 80W respectively
Seems kinda low clock speed for a future next gen processor.
By the looks of it the first desktop Skylake processors won't be high performance parts and will be more
for power saving and with a GPU built in than anything else.
It is more than likely Intel will unleash the full performance potential of Skylake for the desktop thought it
will probably be released on a completely new socket sometime in 2016 or whenever they think it is needed.
I still believe the x99 platform is the only way to go for now until then if you want high performance parts.
Aren't they just ES samples? Also, it's from like the worst site ever.
Also, why is it we keep getting this thread of "Intel says X or Y" They very rarely have substance.
We're very unlikely to get a desktop Broadwell till next year, all this talk of ramping up manufacturing is fairly null till it's here. We'd be very lucky to see anything close to a higher end mainstream Skylake part in 2015. It'll likely be 2016.
I like the name skylake, but won't upgrade from similarly well named sandy bridge unless I need to. Which I probably won't.
Though a hexacore i5 would sway me as I do enjoy hexagons.
Most likely these rumours are all fake - though it is possible for Skylake's new architecture to be so efficient that those lower clock speeds are fine.
Remember the huge performance increase we had from high clocked P4's to the low clocked core2 series? :)
Except it's the worst site in the world, and ES samples.
And apparently they're low power samples, so the clock speeds could very well be accurate, but completely irrelevant as far as panicking goes.
Guess you missed the top sentence of my post?
"Most likely these rumours are all fake"
