Having been pointed in this direction by MarkeR following queries on upgrades to play arma3 I am asking more questions!
Basically I may be in need of a gpu upgrade to replace my aging gtx260 core 216 (clocked to 280ish speeds I think) specifically for playing arma3, I have been recommended to stick with nvidia because I also play DCS sims. Budget is limited, ideally £75-100 but I am more than happy with older 2nd hand cards. Anything with less heat/power and size than the 260 would be a bonus.
I'm not trying to chase maximum fps (as my cpu is also pretty old and limited - [email protected]), I would be happy with something that will pull a fairly constant 35-40 fps on high @ 1080p in arma3.
I'm initially looking at a gtx660ti which can be had on fleabay typically for 70-80 quid, any further thoughts or suggestions?
