Pretty sure crashing when overclocked is due to power states on the 9 series, nvidia have acknowledged it.
Using K-Boost to hold clocks has stopped any crashes when overclocked for me and others.
customized Power+ circuitry, advanced OC Plus real-time performance intelligence and FireStorm Gamer Mode for expert adjustments to fine-tune overclocking with extreme precision
Do Not Buy Zotac's GTX 980 Extreme Overclocking Card
Best card I tested, got me no.1 on Heaven 4.0 benchmark here, a stunning card!
I was right then.
Did you get a working FireStorm Gamer Mode Gibbo?
Screenshots please![]()
You never watched the vid then.![]()
Look at heaven thread, screenshot was submitted over a week ago, no.1 spot finally taking crown from 780ti![]()
That said, it's like comparing a 780 to a 780ti, just wait for the 980ti and all will be forgotten
Well not much of an accomplishment really, as you work in the place that you sell the products, so cherry pick as you will whatever parts, including open an benched test rig (lets not forget)That said, it's like comparing a 780 to a 780ti, just wait for the 980ti and all will be forgotten
Can you tell how did you achieve these results? Tdp, mem volt, core volt, target temp... wise. Also I dont know where is heaven bench thread can you link?Yes worked on mine. Had read outs but I was also limited with 1.20v
I achieved 1570/8800 overclock on one and 1580/8600 on my other.
Memory overclocking is superb, at stock memory voltage both my cards did 8400MHz and with memory voltage as the Zotac extreme seems the only 980 via firestorm gamer to adjust memory voltage I could hit 8600-8800MHz on both cards.
I've asked Zotac to give support to 1.26v and they sent me revised software last week, I will test it when I get chance but doubt it will work as such limitations are normally bios set and not software, but will give it a try.
You seem to think it's all about benching thoight..?At the end of the working day, you run at all stock on everything but stup spec?
Because the 970 was well priced into the market. On top of that it's clocked really well (saving more £). It's all about releasing to the marking at the right price point, as you know. It's why the 980 isn't spoken about much, not a market mover as to speak. But give it until the 980ti is here and the prices are slashed, then we'll have a winner (980).
Why do you choose to run an AMD CPU?![]()
