** INSANE TITANZ DUAL GPU DEAL: PALIT @ £899 BUT ONLY 9PC AVAILABLE!!
OcUK Staff
17 Oct 2002
OcUK HQ
HI there
Crazy EPIC Deal done!
Palit GeForce Titan Z 12288MB GDDR5 PCI-Express Graphics Card **ONLY 9 AVAILABLE** @ £899.99 inc VAT
If you crave only the very best, then Titan Z is exactly that, featuring a pair of the most powerful gaming GPU's available, Titan Black Editions fused onto a single PCB. Featuring a whopping 5760 CUDA Cores and a massive 12GB of GDDR5 memory operating on a 786-Bit interface, makes this the perfect card for a 4k monitor setup.
With advanced dynamic power balancing and 12 phase power supply, not only is this card incredibly fast out the box it also sports some very impressive overclocking ability as well. Power balancing ensures both cores are locked at the same speeds always to ensure the smoothest possible FPS experience with no micro-stutter of any kind.
NVIDIA keep noise levels to a minimum by using an extra-large axial fan to keep this beast of a card as cool as possible along with dual vapor chambers and a 60% larger fin stack area.
Tested at 3840x2160, with AA and high settings on a 3960X at 3.3GHz yielded above 40fps in Batman, Crysis 3, Bioshock Infinite, Battlefield 4, Far Cry3, Metro Last Light and Tomb Raider, making this truly a 4k capable gaming graphics card.
Also being a Titan GPU it is ideal for BIOinformatics, Computational Chemistry, Computational Fluid Dynamics, Computational Structual Mechanics, Data Science, Defense, Electronic Design Automation, Computational Finance, Imaging & Computer Precision, Medical Imaging, Weather & Climate and Numerical Analytics.
Features:-
- 450W Cooling ability at 2700rpm
- 375W Power requirement (Stock Clocks)
- Maintain over 40fps in the latest games at 4k resolution
Specification:-
- Cuda Cores: 5760
- Base Clock: 705MHz
- Boost Clock: 876MHz
- Single Precision: 8.1 Teraflops
- Double Precision: 2.3 Teraflops
- Memory Config: 12GB / 768-Bit GDDR5
- Memory Speed: 7000MHz
- Power Connectors: 2x 8-Pin
- TDP: 375W
- Outputs: 2x DL-DVI, 1x HDMI, 1x DisplayPort 1.2
- Interface: PCI-Express 3.0
- Warranty: 2yr
Was [£1199.99] Inc. VAT
Only £899.99 inc VAT.
ORDER NOW
Only 1 in stock and 8 more due later today, giving a total of 9 at this price. We cannot get any more. :(
SNOOZE YOU LOOSE!
I was really close to pulling the trigger on another lightning but this is very tempting.....
I know the lightnings will be quicker but a one card solution and the extra VRAM is swaying me
5 left!
Website put price back upto £1999, I've put it back down to £899, be quick guys, these will be gone at this rate by lunch time. :eek:
just ordered one! :)
crazy price...
just what I needed for my mini itx
can't be much left now I just ordered another
Good deal if you're in the market for one of these indeed, I spent £500 on my 780 TI a while back I think that's the most I would personally want to spend on a card! :)
