I absolutely love my HD 650's. It took a few days to get used to the signature, which coming from AKG K702s sounded very dull. I'd heard tales of the HD 650 "veil" and was beginning to think I'd made a mistake but after a few days my brain adjusted and discovered that I wasn't missing anything at all. The high frequency sounds were still there, they were just reduced to what now sounds like far more natural levels. The bass surprised me, it really does dig quite deep and has quite a bit of grunt but star of the show are the mids and those really do take your breath away. Voices and guitars sound ridiculously good, smooth yet detailed and real enough to touch.
Actually I thought I'd have a listen to some music using my AKG K702s earlier - I didn't even make it through the first track, all that high frequency "tizzzz" was killing my ears, which obviously are no longer used to it. Now I'm converted to the HD 650 I can't see me ever wanting to change them, not unless Sennheiser come up with a replacement that sounds even better. For gaming though I still much prefer the AKG K702's and my STX, that huge sound stage and HF detail make surround sound gaming quite an experience.
As for the Schiit Modi and Schiit Vali combo, I'm really happy with them, they seem to complement the Sennheisers really well and music really comes to life. The Modi is a fine little DAC that punches well above it's weight and the Vali is just ridiculous for the price. I am yet to push the volume much above 50% on the Vali and that is borderline painful, so it has plenty of grunt but forget it if you want to use IEMs or low impedance headphones as the noise floor is too high - totally silent with higher impedance cans though. The only other thing is that the tubes are microphonic, so if you give it a clout you will hear them ringing. They tend to ring when it's first switched on or when you insert the headphone plug but it goes away after 20 to 30 seconds. With practice I have now mastered the art of plugging the headphones in with zero ringing - a milestone in my audio life.
