Spec me a factory overclocked GTX970
28 Feb 2012
Herts
Hi all,
Would you please spec me a good factory overclocked GTX 970? I've seen quite a few on here and not really sure which one to go for.
Hoping it will be a worthwhile upgrade from my 2GB GTX 670.
Cheers.:)
If you are not going to touch the OC, just get the Gigabyte G1, its the fastest outthe box (cherry-picked) 970...
EDIT: and it will be quite a significant upgrade from your 670.
Thanks for the replies guys,
I'm still learning the art of CPU OC, I've never OCd a GPU though.
My case is a Corsair 600T, would that be ok?
Also, I have a 650w PSU (XFX Core Ed.), so don't want to stretch it.
Both case and Psu are fine. Overclocking Nvidia cards is simple. If in doubt, when you get the new card and choose to overclock just pop up a new thread and plenty here will guide you through the motions.
Your case will be fine, I have the same one :)
Your PSU won't be an issue in the slightest.
