it's utter complete junk what is being offered. I think a huge proportion of GP's are quite uncomfortable with the ethics alone of being paid on diagnosis. It's another area where we as a profession are being hounded for being either incompetent or money grabbing or both. I don't know anyone who thinks it's a good idea after it was announced yesterday. If you think it will incentivise anyone you are very much mistaken also.
In my practice we have above average prevalence of dementia (nearly 1.5%) with currently 112 people on our register. how many new cases do you think is likely to happen in the slightly under 6 months this will be run as an experiment for? A dementia diagnosis doesn't happen overnight either. I would see someone and assess them, arrange for some screening bloods to make sure other simple modifiable causes are not the reason for their memory problems, review them with the results and then refer them to a memory clinic. It will take a couple of months before they are seen in a memory clinic, and they will then perform more tests on their memory, arrange MRI/CT scans of their brain, assess them in day centres and their side generally takes several months to complete before a diagnosis is made. It's quite clearly important you need a robust diagnosis of dementia you don't just want to give it to anyone who has very mild memory problems, as it will have very marked affect on their lives. The whole process in general takes slightly more than 6m for a robust diagnosis. So in reality the new diagnoses of dementia are for people we have referred in the last few months and there is no incentive as it is for work you have already completed
It also is not £55 per patient diagnosed it is £55 for each extra case on your register compared to 30th september, by end of March 2015. so the fact that some of our frail patients with dementia will die in this timeframe would mean that 112 may become 108, so we would actually need to have 5 new diagnoses for the headline grabbing £55, so actually £10 per diagnosis.
I have absolutely no idea what the purpose of this whole scheme is as it will be meaningless, and will only undermine our profession, my practice will not be signing up for it as it only appears divisive. It's another politically driven headline grabbing stunt from NHSE and I'm fed up to the teeth of this rubbish, and if you saw me face to face my ranting over this carp would be significantly worse
