So I have a final budget now of £1000 give or take £200ish to upgrade my current system, and getting straight into it I have a couple of questions but also some ideas:
- Is the ROG Swift worth the premium price of £670? Would it be worth waiting a while to see if anything else is released/the monitor goes down in price? It's a lot of money to spend on a monitor and obviously that means you're losing out on other potential components, but if it's worth the plunge then I'll more than likely be getting myself one (included in the budget). I've been using these 60hz 1080p monitors for way too long and want something bigger and better for an amazing gameplay experience.
- I want this upgrade to last me for a good 3-4 years AT LEAST so I was thinking that I could maybe go for an X99 upgrade, including a 5820k. Now I don't do too much work which is usually related to the X99 platform, however I've heard that it's great for future-proofing as games in the future are likely to be using more cores? I'm not sure, but I want it to be sustainable for at least the aforementioned period of time, so if it's worth spending the extra money at the gain of sustainability then I'll more than likely go for an X99 combo. I was already thinking of replacing my RAM anyway to some higher speed stuff so that in theory reduces the cost of DDR4 a bit more.
I'm asking if you could please play around with the budget a bit and see what you can come up with, and also your opinion on the points mentioned above, and include a ROG Swift in it if you feel it's worth the money.
Please ignore my signature, as at the time of the upgrade I'll have a GTX 980 installed, and that's not included in this budget. Here's the rest of my system:
i5-2500 (Locked) @ 4.0
(GTX 980)
8gb 1600mhz
BeQuiet System Power 7 600w
AsRock Z68 Pro3
Also, please no comments saying wait for Broadwell/Skylake etc. as I am going to be upgrading soon and don't want to wait the extra time for the new chipsets. Forgot to mention, the system is primarily used for gaming (will be playing a lot of AAA titles next year)
Cheers
(GTX 980)
8gb 1600mhz
AsRock Z68 Pro3
Cheers
