Anyone with a 5930K wanna help me out?
Could you install this and run the test.
Tell me if you pass or fail
I ran it and it failed?
--- Testing Processor 1 ---
--- IPDT64 - rev 2.10.0.0.MP ---
--- Start Time: 10/24/2014 12:13:38---
--- Skipping Config ---
--- Reading CPU Manufacturer ---
Expected --> GenuineIntel
Detected --> GenuineIntel
Found --- Genuine Intel Processor ---
--- Temperature Test ---
Temperature Test Passed!!!
Temperature = 68 degrees C below maximum.
--- Reading Brand String ---
Detected Brand String:
Intel Core i7-5930K 3.50GHz
Brand String Test Passed!!!
--- Reading CPU Frequency ---
Expected CPU Frequency is --> 3.50
Detected CPU Frequency is --> 3.70007
CPU Frequency Test Passed with Warning!!!
The processor frequency could be affected by power management features. In order
to ensure the processor frequency is not affected by a power management setting,
enter BIOS, load defaults, and disable any 'Over-Clocking' or power
management features that may affect processor frequency. Also, set any
software applications which control power management features to default.
--- FSB NOT Supported on this Processor ---
--- Running Base Clock test ---
Detected Base Clock --> 100
Base Clock test Pass ---
--- Error while retrieving QPI Link rate ---
..QPI Link rate Test Failed..
QPI Link rate Test Failed. Error while retrieving QPI Link rate
--- Test End Time: 10/24/2014 12:13:39---
System Information
Processor Name: Intel(R) Core(TM) i7-5930K CPU @ 3.50GHz
Processor Information: Intel64 Family 6 Model 63 Stepping 2
Number of Physical Cores: 6
Number of Logical Cores: 12
Installed System Memory: 32 GB
Operating System: Microsoft Windows 8.1 Pro 64-bit
Graphics Information: AMD Radeon R9 200 Series
System Product: X99-DELUXE
System BIOS: 1004
FAIL
5930K here with Windows 10 (build 9860).
It fails, with "QPI Link rate Test Failed. Error while retrieving QPI Link rate".
I suspect the *reason* it fails is because QPI hasn't been used (to communicate between the core and uncore) since the earliest i7s - goodness only knows why it's looking for it!
Well that's good then, confirms my CPU isn't a dud. Cheers chaps
This can be locked now or deleted. -if only Mod powers followed you from forum to forum. Ho hum.
Run the test without QPI as the Haswell chips don't use it. Go to settings and select edit - this then allows you to untick the qpi test. Then you can run all the rest of the test ok - mine passed. Must change my sig again lol
