HI there
We have secured LG's True 4K 31" Monitors, check them out. The Price is Pre-Order ONLY as the RRP is in the region of £1200, so at under £1000 these are a real good buy. Bear in mind this is a true 4k panel using AH-IPS technology so the image is stunning!
LG 31UM97 31" True 4K 60Hz Professional WideScreen LED Monitor - Black @ £999.95 inc VAT
When most consumers refer to ‘4K’, they’re actually referring to the UHD (Ultra High Definition) resolution of 3840 x 2160. This is, after all, the most common ‘4K’ resolution. It also maintains the common 16:9 aspect ratio and provides quite an enjoyable experience. The LG 31MU97 features a 4096 x 2160 resolution which is also referred to as ‘Digital Cinema 4K’ due to its use as the dominant 4K resolution by the DCI (Digital Cinema Initiatives). The monitor features LG’s robust ‘business-like’ stand which offers tilt and height adjustment but can’t be pivoted or swivelled.
This display uses a 31” AH-IPS panel (LM310UH1-SLA1) with a 4096 x 2160 resolution (17:9 aspect ratio) and 60Hz refresh rate. This features a very light matte (‘semi-glossy’) screen surface and is designed to provide accurate and consistent colours in both the sRGB and Adobe RGB colour spaces. It uses a flicker-free (‘Flicker Safe’ – PWM free) GB-LED backlight to provide this wide colour gamut (100% sRGB and over 99% Adobe RGB). The monitor is also factory calibrated for both of these colour spaces and features true 10-bit colour reproduction. It can be user-calibrated with the ‘LG True Color Pro’ software as well. ‘Reader’ modes also feature, which are ‘Low Blue Light’ settings allowing the user to select white point targets such as 3882K, 4300K or 4616K to cut down on the blue light emission.
The monitor features a wide range of ports, including; DisplayPort, Mini DisplayPort, 2 HDMI ports, 3 USB 3.0 ports and a 3.5mm headphone jack. The native resolution is supported at 60Hz over DP or MiniDP but only at 30Hz over HDMI. 5W stereo Maxx Audio speakers also feature, which seems to be a favourite on higher-end LGs at the moment. The included stand can be removed to reveal 100 x 100mm VESA holes.
Specification:
- Display Screen Size: 31"
- Aspect ratio: 17:9
- Panel Type: AH-IPS
- Brightness: 300cd/m2
- Contrast Ratio: 1000:1 (Typ)
- Dynamic Contrast Ratio: 10,000,000
- Resolution: 4096x2160 (Only over DisplayPort at 60Hz)
- Response Time: 5ms (GTG)
- Color Support : 1B
- Viewing Angle (H / V ): 178 ° / 178 °
- Connectivity: 2x HDMI (30Hz), 1x DisplayPort (60Hz), 1x Mini-DisplayPort (60Hz)
- USB Hub: Yes (USB3.0)
- Speakers: Yes (5W Stereo)
- VESA: 100x100mm
- Height adjust, pivot, swivel stand
- Warranty: 2yr
Was [£1199.99] Inc. VAT
Only £999.95 inc VAT.
ORDER NOW
Specification:
- VESA: 100x100mm
- Warranty: 2yr
ORDER NOW
