the namings are inconsistent, and not all levels exist for both sides solutions which is true.
From Anand
And there you go 16xQ is really only enhanced 8xMSAA while 8xEQ is enhanced 8MSAA.
That chart is a bit out of date because AMD has the EQ enhanced versions of all the base AA levels and 16xAA and up is only an option with xfire.
AMDs 16xEQ has a 16xAA base not 8xAA like NV 16xQ.
And looking closer at NVs other AA levels are inconsistent with the xQ naming which would assume enhanced while they are not and also xAA which should mean base level that are really enhancing lower levels besides other anomalies.
So NV is adding the base level and the enhancing level together to denote the AA which after 4xAA there would be no way of knowing how much of it is base and how much is enhancing without the chart.
