Since Arma 3 is free this weekend I thought I'd give it a try, but the performance has been much lower than I expected for my 290X/4770k. It's weird because the core clock doesn't go over about 800Mhz even though it's overclocked to 1100Mhz. Also none of the CPU cores are hitting 100%, at most they're about 60%, the CPU is overclocked slightly too.
I've also tried setting the unofficial overclocking mode to 'without powerplay support' in Afterburner, which does force the core clock to 1100Mhz but there's no improvement in FPS.
The performance I'm getting on Ultra is about 22-25 on the helicopter ride at the start of the SP campaign, then about 30 once I'm in the camp. If I run the infantry showcase it's between 30-40. This is on 1080p resolution. Looking at reviews like this, I should be getting almost twice that?
The card is watercooled so doesn't go above 50C, so heat isn't an issue. Can anyone tell me what's going on? I've noticed this in other games too (the core clock not maxing out), but it's never been as bad as Arma 3. Thanks.
