** PARVUM SYSTEMS F1.0 PERFORMANCE PRESSURE FANS - SPECIAL OFFER **
rjk
rjk
OcUK Staff
8 Aug 2007
Hi Guys
Our friends over at Parvum Systems have been working hard to bring you something a little bit unique. To compliment their impressive range of Acrylic cases, Parvum have been working in conjunction with Premier cooling brand Alpenföhn, the Parvum F1.0 is based around the high performance Wing Boost 2 cooling fan. The Wing Boost 2 offers excellent performance in both air and watercooling applications and compliments the Parvum Systems ethos perfectly.
The Wing Boost 2 is already very popular at OcUK due to the strength of the Alpenföhn brand name here but Parvum have really pushed for them to produce a white version of the fans for them. So good in fact that I am using them in my own system to compliment my watercooling radiators.
The fans are available in black and white versions and to celebrate this step forward from an OcUK exclusive supported vendor, we are offering a free Parvum F1.0 fan with every Parvum Systems case purchased from now until the end of the year.
Black base colour cases come with a black fan, White base colour cases come with a white fan.
In addition to this, if you buy a Parvum Systems case and Super Flower PSU between now and 2015, you can use the code 'SFCASE' to qualify for free shipping!
[more info here]
Nice to see they've finally surfaced!
I was given a set of these for testing by Parvum about a week after i51. Still running them now as case fans and also have 2 on my H100i. Cannot fault them if I'm honest.
Quiet, effective and they look great :D
I use the wing boost 2 fans and they're very nice.
However I could never find any reviews for them, anyone got a link for them or these?
Really tempted to get these to replace my Hiper Hiperflow fans that are getting to the end of their life.. but getting 7 of them starts getting expensive.
As requested :)
Three Fan Bundle - Parvum Systems F1.0 Performance Fan - White @ £28.99 inc VAT
Parvum Systems Cases offer a unique take on a system modding project and to compliment the impressive acrylic case range, the F1.0 fan has been launched.
Working in conjunction with Premier cooling brand Alpenföhn, the Parvum F1.0 is based around the high performance Wing Boost 2 cooling fan. The Wing Boost 2 offers excellent performance in both air and watercooling applications and compliments the Parvum Systems ethos perfectly.
In addition to the Parvum branding, the Parvum F1.0 White edition is an exclusive colourway to Parvum Systems.
WB2-Technology
Many users ask themselves…what are WingBoost´s? WingBoost´s are ridges on the
impeller that guide the air on the air-inlet side of the impeller. Using the WingBoost 2
technology air turbulences are reduced wich leads to a lower noise level at full speed.
S-Shape geometry
With the improved S-Shape geometry we could reach a higher static pressure compared
to conventional designs.
HD-bearing:
The new developed HD Bearing (Hydraulic Bearing) reduces friction noises to a minimum and thus enables to a quiet operation.
Plus Funktion:
The new WingBoost 2 is equipped with a "plus-function".
That means that a Y split cable has been attached to the PWM connector for a
second fan. Thanks to this split cable it is possible to control additional PWM fan
with the same PWM connector on the motherboard instead of using a cable adapter or a 3pin connection.
Specifications:-
- Dimensions: 120 x 120 x 25 mm (W x H x D)
- Dimensions: about 166 g
- Material: plastic, rubber
- Color: Black, White
- Volume: max. 18.2 dB (A)
- Speed: 500 - 1,500 r / min
- Air flow: max. 106 m³ / h
- Voltage: 12 V
- Connector: 4-pin PWM (with Y-switch)
- Accessories:
- 1x Cable 4-pin to 3-pin (no PWM)
- 1x Adapter 4-pin PWM-to-7-volt Molex
- Adapter 1x 4-pin PWM-to-5-volt Molex
- 4x Gummipins for decoupled housing mounting
Was £35.96 Inc. VAT
Only £28.99 inc VAT.
ORDER NOW
Three Fan Bundle - Parvum Systems F1.0 Performance Fan - Black @ £28.99 inc VAT
WB2-Technology
S-Shape geometry
HD-bearing:
Plus Funktion:
Specifications:-
- Voltage: 12 V
- Accessories:
Was £35.96 Inc. VAT
ORDER NOW
Disappointed Parvum haven't worked something out about the 2 80mm fan slots I have at the back of mine doing nothing...
Please Parvum my lowly Fermi needs moar cools
BeQuiet do some as do noiseblocker and noctua.
I have noctua's but id go for some noiseblockers or bequiet ones now if i had a choice again or changed them
awesome! Triple pack!
Now I just have to decide if I want to mix and match colours or keep them consistent!
edit: any idea when the packs will be in stock? Ready to buy 2 of them right now :)
edit 2: Maybe not, will these clip into a fan bracket? My CM Stacker has 5 brackets that use clips instead of screws
