The vrms burning out was due to a high voltage limit set by the BIOS which got corrected if I remember right,the ud means ultra durable components,high end capacitors ect
The UD3 is junk. I would not take my 3970x within a million miles of it.
People laugh and joke and say AMD CPUs use power, but I tell you
no AMD needs 12 phases. I shudder to think what my 3970x guzzles down when I clock it to 4.9ghz and beyond.
But the point remains. 1.5v into the CPU means the VRMs have to bust a nut. There are protection circuits in place but these are easily bypassed on X79 because they are an enthusiast board.
My Big Bang Xpower II has 12+2 phases if I remember correctly. Heck, it may have even been 12+4. And I had to disable DrMOS because it was telling me it was going to shut down my PC due to the VRMs running too hot. In the end I disabled it, and I tell you, the little red LED fet warning light has been jammed on ever since.
But I'm not concerned because the board was built to take it, and that reflects in the price. I paid £220 but on launch they were closer to £300.
If you're going to use a cheap board then the old adage goes - "If you're gonna play be prepared to pay".
No 8 phase board can continually pump out 1.5v and god knows how many amps through the VRMs forever without eventually failing.
I wouldn't even mind, but the phase cooling is crap. Look at this pic.
Now look at the top heat sink and look how an entire row of fets have no cooling at all.
Know why? because this board was £150 when all of the good ones cost double that and IMO was only ever made to run quads and certainly not at 1.5v. I give my 3970x 1.47v @ 4.9ghz and would not dare going any higher without slapping a water block over the fets. For my daily clock of 4.7 I need just 1.42 and this is a 12 phase board and that red light is perma jammed on.
So even if it is the CPU (doubt it) and even if the board still works I wouldn't put
your 4930k in it dude. I don't mean that horribly, I just mean I would not dare attempt such a feat with this board.
It's a low rent budget board, made for quad core CPUs.
