Man of Honour
- 5 Jun 2003
- Falling...
Venison fillet with mustard, sweet potato chips
1 venison (1.2 kilograms with fat)
1 onion
2 shallots
20 cl of red wine
3 tbsp of mustard
salt and pepper
For chips:
3 sweet potatoes
oil
salt and pepper
Preparation:
The night before, put the venison in a deep dish, and sprinkle the red wine. Add the peeled and minced shallots, pepper and marinate in the fridge overnight.
Peel the sweet potatoes and cut them into very thin slices. Wash and dry them in a clean cloth. They need to be cool for the next stage so can prepare in advance.
Heat a large amount of oil in a deep fryer or in a pan. Dip the slices of potato in small quantities. Letting them brown, then drain the chips on paper towels, salt and put them in a bowl.
Preheat the oven (240 ° C). Carefully drain the fillet and wipe with paper towels to soak up excess marinade. Brush on the mustard.
Strain and put aside the marinade.
Place in a dish and roast for 10 minutes then reduce the oven gas mark 6 (180 ° C) and cook 15 min.
Remove the dish from the oven, remove the venison and let it rest under foil.
Place the roasting dish over low heat and deglaze it with the marinade.
Let it reduce by a third.
Pour the remaining sauce into a bowl.
Cut the venison into thick slices and serve with sweet potato chips and gravy.
1 onion
2 shallots
20 cl of red wine
3 tbsp of mustard
salt and pepper
For chips:
3 sweet potatoes
oil
salt and pepper
Preparation:
) it's not quite so bad.
