** BOOOOOOOOOOOOM: ANOTHER PRICE LOCK FOR YA!! **
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
Another Price Lock product for you and what a product it is too:-
GALAX GeForce GTX 980 SOC Gamer 4096MB GDDR5 PCI-Express Graphics Card (98NQH6DNC7VZ) @ £419.99 inc VAT
The new NVIDIA GeForce GTX 980/970 is powered by the next generation NVIDIA Maxwell Architecture, giving you incredible performance, unmatched power efficiency, and cutting-edge features.
Maxwell is the most advanced GPU architecture ever made, designed to be the engine of next generation gaming. Inspired by light, it was designed to solve some of the most complex lighting and graphics challenges in visual computing. For the first time, gaming GPU's can dynamically render indirect light using the new VXGI (Voxel Global Illumination technology). Scenes are significantly more lifelike as light interacts more realistically in the game environment.
The GTX 980 is the worlds fastest GPU and the GTX 970 offers the most advanced performance in its class. Each delivers 2x the performance of previous-generation card, bringing new gaming experiences to virtual reality, and ultra resolution 4k displays.
Enable the detail of 4k monitors, on a 1080P display. DSR produces smoother images by rendering a game at a high resolution, then downscaling it to the native resolution of the display using advanced filtering.
GeForce GTX 980 and 970 cards support tear-free, super-fast NVIDIA G-Sync monitor display technology including 4k. Together, these technologies provide the most immersive and competitive gaming experiences possible.
Features:-
- Voxel Global Illumination Technology (VXGI)
- NVIDIA® Super Resolution technology
- NVIDIA® GameWorks technology
- NVIDIA® GameStream technology
- NVIDIA® TXAA Technology
- NVIDIA GPU Boost 2.0
- NVIDIA PhysX® Technology
- NVIDIA FXAA Technology
- NVIDIA Adaptive Vertical Sync
- NVIDIA Surround
- Support for four concurrent displays including: Two dual-link DVI, HDMI and DisplayPort 1.2
- Microsoft DirectX 12
- NVIDIA® 3D Vision® Ready
- NVIDIA SLI® Ready Technology
- NVIDIA CUDA® technology
- PCI Express 3.0 support
- OpenGL 4.4 support
- OpenCL support
- NVIDIA SHIELD Ready
- NVIDIA G-Sync Ready
Specification:-
- Advanced IR3595 Digital PWM
- Multi-layer ceramic capacitors (Helps reduce coil whine)
- GeForce GTX 980
- GPU: GeForce GTX 980 (GM204)
- Process: 28nm
- Core Base Clock: 1228MHz
- Core Boost Clock: 1329MHz
- Memory Clock: 7010MHz
- Memory Size: 4096MB GDDR5
- Bus Type: PCI Express 3.0
- Memory Bus: 256-bit
- CUDA Cores: 2048
- DirectX 12: Yes
- DVI Port: 1x Dual-Link DVI, 3x DisplayPort & 1x HDMI
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 2x 8-Pin
- 500W PSU Required
- 165W TDP
- Warranty: 2yr
Only £419.99 inc VAT.
ORDER NOW
Stock is landing next week and its just won the Hexus award:-
http://hexus.net/tech/reviews/graphics/76361-galax-geforce-gtx-980-soc/
Knock it down another fifty pounds, along with the use of your car at weekends, and we might have a deal, Gibbo. :D
In all seriousness, that's a pretty good deal. :)
Yeah for me I personally think this is the best looking cooler, just think the black and gunmetal goes well with the dark red fans, a nice blend that works well with most motherboard designs. :)
hate to say i still prefer the reference design. Which is opposite to my amd cards where the reference design should be set on fire and only talked about in hushed voices
Earlier than expected these have landed into stock now, one of the best custom overclocked cards available and at a great price. :)
Just a shame that I have sensitive ears otherwise this would be ideal. If you could knowck those super dead quiet Strix's down though for Christmas then I'll be ultra happy. :D
