GALAX GeForce GTX 970 EX OC 4096MB GDDR5 PCI-Express Graphics Card (97NQH6DNB4UX) @ £259.99 inc VAT
The new NVIDIA GeForce GTX 980/970 is powered by the next generation NVIDIA Maxwell Architecture, giving you incredible performance, unmatched power efficiency, and cutting-edge features.
Maxwell is the most advanced GPU architecture ever made, designed to be the engine of next generation gaming. Inspired by light, it was designed to solve some of the most complex lighting and graphics challenges in visual computing. For the first time, gaming GPU's can dynamically render indirect light using the new VXGI (Voxel Global Illumination technology). Scenes are significantly more lifelike as light interacts more realistically in the game environment.
The GTX 980 is the worlds fastest GPU and the GTX 970 offers the most advanced performance in its class. Each delivers 2x the performance of previous-generation card, bringing new gaming experiences to virtual reality, and ultra resolution 4k displays.
Enable the detail of 4k monitors, on a 1080P display. DSR produces smoother images by rendering a game at a high resolution, then downscaling it to the native resolution of the display using advanced filtering.
GeForce GTX 980 and 970 cards support tear-free, super-fast NVIDIA G-Sync monitor display technology including 4k. Together, these technologies provide the most immersive and competitive gaming experiences possible.
Features:-
- Extreme factory overclock
- Anodized aluminum backplate protects components and reinforces the PCB
- All new Silence Extreme cooler reduces temps by up to 10C
- Silence Extreme technology switches to single fan cooling at idle for almost noiseless operation
Quad mixed-gauge heat pipes ensure maximum heat dissipation
- Copper base with solid aluminum cover
- 5 + 2 Phase enhanced power system with 8 + 6-pin inputs delivers up to 50% more power for overclocking
- Voxel Global Illumination Technology (VXGI)
- NVIDIA® Super Resolution technology
- NVIDIA® GameWorks technology
- NVIDIA® GameStream technology
- NVIDIA® TXAA Technology
- NVIDIA GPU Boost 2.0
- NVIDIA PhysX® Technology
- NVIDIA FXAA Technology
- NVIDIA Adaptive Vertical Sync
- NVIDIA Surround
- Support for four concurrent displays including: Two dual-link DVI, HDMI and DisplayPort 1.2
- Microsoft DirectX 12
- NVIDIA® 3D Vision® Ready
- NVIDIA SLI® Ready Technology
- NVIDIA CUDA® technology
- PCI Express 3.0 support
- OpenGL 4.4 support
- OpenCL support
- NVIDIA SHIELD Ready
- NVIDIA G-Sync Ready
Specification:-
- GeForce GTX 970
- GPU: GeForce GTX 970 (GM204)
- Core Base Clock: 1126MHz
- Core Boost Clock: 1266MHz
- Memory Clock: 7010MHz
- Memory Size: 4096MB GDDR5
- Bus Type: PCI Express 3.0
- Memory Bus: 256-bit
- CUDA Cores: 1664
- DirectX 12: Yes
- DVI Port: 2x Dual-Link DVI, 1x DisplayPort & 1x HDMI
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 1x 8-Pin & 1x 6-Pin
- 450W PSU Required
- 150W TDP
- Warranty: 2yr
Only £259.99 inc VAT.
ORDER NOW
_____
Acer XB270HA 27" G-Sync 144Hz Gaming Widescreen LED Monitor - Black/Red @ £359.99 inc VAT
Acer XB270HA gaming monitor as the world’s first 1080P 27" display featuring NVIDIA® G-SYNC™ technology to provide stunning, ultra-smooth, tear-free imagery and rich colors for outstanding gaming experiences. It features Acer’s flicker-less, low-dimming and ComfyView technologies that reduce strain on the eyes for smooth and comfortable extensive viewing.
The Acer XB270HA is intended to be paired with enthusiast PCs for immersive, ultra high-end gaming. It features a spacious 27-inch LED backlit display with True HD (1920 x 1080 pixels).
With a GeForce® GTX™-powered PC, NVIDIA® G-SYNC™ display technology synchronizes the display’s refresh rates to the GPU to eliminate screen tearing and minimize display stutter and input lag to deliver smoother, faster, more breathtaking gaming experiences. Scenes appear instantly, objects look sharper and more vibrant, and gameplay is more fluid and responsive providing gamers with significant performance advantages.
The Acer XB270HA features 170/160 degree viewing angles so that brilliantly-colored images can be seen from almost every angle. DisplayPort™ v1.2 transmits video signals and four USB 3.0 ports are conveniently located at the side and bottom of the display for connecting to keyboard, mouse or mobile devices.
The Acer XB280HA monitor is made with post-consumer recycled plastic and features a distinctive red ring on the base stand. The multi-functional ErgoStand allows the screen to tilt from -5° to 35° to ensure the best viewing angle; the base rotates 120° from left or right for easy screen sharing; the panel height can be raised by up to 150 mm for optimum comfort; and the screen pivots from horizontal to vertical for more viewing perspectives.
This eco-friendly monitor features a mercury- and arsenic-free panel, LED backlighting for reduced power consumption, and is ENERGY STAR®(1) qualified.
Features:
- Flicker-less technology – stable power supply eliminates screen flicker particularly beneficial for heavy users by helping to reduce eye strain.
- Low dimming technology – adjust to as low as 15 percent brightness in low light environments to make it easy on the eyes. Standard monitor settings start at 30 percent brightness level.
- ComfyView technology – the non-glare panel reduces reflection from light source.
Specification:
- G-Sync Technology
- 3D Vision Technology
- Flicker-less Technology
- Height Adjust stand with tilt, swivel and pivot
- Display Screen Size: 27"
- Aspect ratio: 16:9
- Panel Type: TN
- Brightness: 300cd/m2
- Contrast Ratio: 1000:1 (Typ)
- Dynamic Contrast Ratio: 10,000,000
- Resolution: 1920x1080 144Hz
- Response Time: 1ms (GTG)
- Colurs: 16.7M
- Bits: 8 bits
- Viewing Angle (H / V ): 170 ° / 160 °
- Connectivity: 1x DisplayPort 1.2 (144Hz)
- USB Hub 3.0: Yes (1up, 4down)
- VESA: 100x100mm
- Speakers: No
- Warranty: 2yr
Only £359.99 inc VAT.
ORDER NOW
Features:-
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 970
- CUDA Cores: 1664
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- 450W PSU Required
- 150W TDP
- Warranty: 2yr
ORDER NOW
_____
Features:
Specification:
- G-Sync Technology
- Panel Type: TN
- Colurs: 16.7M
- Bits: 8 bits
- VESA: 100x100mm
- Speakers: No
- Warranty: 2yr
ORDER NOW
