need help with water cooling
There's loads of people on this forum that are pc gods. If you need advice just ask. It's always better to ask first before blowing something up :D. Mistakes can be expensive :(.
There's no such thing as a stupid question :D.
thanks for your help to really appreciate it :P
My only worry is how to fit the bay's and and motherboard
Also could put some speakers in if j was thinking
No worries :).
You can buy motherboard trays that you could build into the desk or you could mark out on some paper where the mobo holes are then drill through the paper to place the mounts directly into the desk.
As for the bay why not get an external blueray and sit it on the desk? Keeps the sides clean. Or I think you can buy 5.25" enclosures which you could build into the desk again. All you'd need is a jigsaw to cut the opening and line the cage up behind it.
I wouldn't advise putting the speakers in it as it will distort noise/take up space. Along with if you follow my luck they'll blow and you'll never be able to find a replacement to fit the same hole :D.
Does your mate have experience in building things?
often if you have an old case kicking about it is actually easier to cut out the mounting plate with all the pre drilled holes and fix that into the desk
EK Water Blocks EK-RES X3 400 Reservoir EK Water Blocks EK-RES X3 400 Reservoir
Product Code: WAEK-527 5+
remove £43.49 £86.98
EK Water Blocks EK-D5 X-TOP Vario Incl. Pump - Plexi EK Water Blocks EK-D5 X-TOP Vario Incl. Pump - Plexi
Product Code: WAEK-656 5+
remove £74.99 £149.98
EK Water Blocks EK-FC980 GTX Backplate - Black EK Water Blocks EK-FC980 GTX Backplate - Black
Product Code: WAEK-932 20+
remove £23.10 £46.20
EK Water Blocks EK-Supremacy - Nickel EK Water Blocks EK-Supremacy - Nickel
Product Code: WAEK-420 10+
remove £46.25 £46.25
EK Water Blocks EK-FC980 GTX - Nickel CSQ EK Water Blocks EK-FC980 GTX - Nickel CSQ
Product Code: WAEK-927 5+
remove £82.95 £165.90
PrimoChill Acrylic Tube 13/10mm, 60cm (24inch) 4 Pack - Clear PrimoChill Acrylic Tube 13/10mm, 60cm (24inch) 4 Pack - Clear
Product Code: WAAU-253 5+
remove £13.25 £26.50
EK Water Blocks EK-CoolStream RAD XTX 360 EK Water Blocks EK-CoolStream RAD XTX 360
Product Code: WARA-235 2
remove £64.04 £128.08
what you guys think to this setup
