Hi there
Some more Halloween deals for the weekend guys, check them out:
GIGABYTE P25X v2-CF2 Gamer 15.6" Full HD IPS Display, Intel Core i7-4710MQ, 16GB DDR3L, 2 x 256GB SSD & 1TB 7200TPM HDD, NVIDIA GTX880M 8192MB GDDR5 - Windows 8.1 @ £1,559.99 inc VAT
Unrivaled Performance with the all new Intel® Core™ Processor
Experience revolutionary battery life improvement, super-speed performance, ultra-fast image / graphics processing, and many other security protection capabilities with the Haswell platform 4th generation Intel® Core™ Processor. Built on the 22nm architectural process making use of the latest 3D Tri-Gate transistor technology allows for unrivaled performance.
Incredibly Powerful Gaming Discrete Graphics Revealed
Features a highest level NEW NVIDIA® GeForce® GTX 880M GDDR5 8GB graphics processor that supports NVIDIA® FXAA, Adaptive V-Sync technology! With the latest Ultra Boost technology you can easily choose the Extreme mode through an intuitive interface.
Vivid Visual Enjoyment with the 1080p Full HD IPS Matte Display
The 1080p Full HD matte display panel features a light scattering anti-glare layer, which diffuses light, eliminating reflections and delivering a sublime gaming experience. Adding IPS Wide Angle Display, it literally bring games to life from any direction you look at it
Electroluminescence Backlit Keyboard
The P25X epitomizes an automatic light sensing backlit keyboard. This significant feature adjusts the light to external conditions and makes typing and gaming in dimly lit rooms and dark conditions better and easier.
High Performance, Massive Storage System
The P25X is able to pack up to two mSATA 512GB SSD and 1 huge 1TB HDD. It provides massive storage options and delivers super fast performance of 1000MB/s and 850MB/s read/write rate for gamers with mSATA SSD super RAID 0 technology supported. Use the power of Raid 0 technology to your advantage for co-op or sharing games, giving gamers an experience like never before.
Dynamic Sound, Truly Amazing
The unique 4 Dual-channel Stereo Speakers are designed to provide dynamic and realistic sound effects, along with a subwoofer that boosts the deep, punchy bass. The result is a high-fidelity audio experience that is perfect for gaming and multimedia.
Rear Dual Air Vent Design Provides Effective Cooling
The P25W adopts a unique dual heat sink design with dual air vents (one for the CPU and the other for the GPU), increasing its gaming stability. The unique venting system is able to effectively keep the laptop from overheating despite the powerful features under the hood in this machine.
Specification
- Display: 15.6", 1920*1080 Full HD
- Processor Type: Intel Core i7 4710MQ
- Processor Cores: 4 (8 Threads)
- Processor Clock Speed: 2.40GHz (3.40GHz Turbo Mode)
- Hard Drive Supplied: 1 x 1000GB
- Hard Drive Size: 1000GB
- Solid State Drive: 256GB SSD x 2
- Hard Drive Speed: 7200RPM
- Memory Supplied: 2 x 8GB
- Memory Size: 16GB
- Memory Type: DDR3L
- Memory Speed: 1600
- Memory Socket: 2 x SO-DIMM
- Max. Memory Support: 16GB
- Operating System: Windows 8.1
- Graphics Chipset: NVIDIA GeForce GTX 880M
- Graphics Memory: 8GB GDDR 5
- Chipset: Intel HM87 Express
- Optical Drive: BluRay ReWritable Drive
- Microphone: Built-in
- LAN: 10/100/1000Mbps
- Wireless: 802.11 ac
- Bluetooth: v4.0
- USB 3.0 Port(s): 2
- eSATA/USB 2.0 Port(s): 1
- HDMI Port(s): 1
- VGA Port(s): 1
- Microphone Jack(s): 1
- Headphone Jack(s): 1
- LAN Port(s): 1
- Card Reader: SD
- Web Camera:1.0MP
- Keyboard: Backlight LED
- Dimension: 392 x 263 x 32.1~38.3mm
- Battery: Li-ion 8-cell, 5700mAh, 86.18Wh
- Product Weight (g): ~2.6Kgs
- Warranty: 2 Years
Was [£1799.99] Inc. VAT
Only £1,559.99 inc VAT.
ORDER NOW
MSI GS60 2QE-017UK, 15.6" 2880x1620 FHD Anti-Glare IPS Screen, Intel Core i7-4710HQ, 16GB DDR3, 1 x 128 M2 SSD RAID + 1TB 7200RPM HD, NVIDIA GTX 970M 3GB GDDR5 - Windows 8.1 @ £1,499.99 inc VAT
NVIDIA GTX 970M: Insanely Powerful. Discrete Graphics Card with GDDR5 6GB VRAM
The NVIDIA Geforce GTX 970M Series brings extreme, next-generation graphics performance to serious gaming notebooks. As the first graphics solution to reach a score of over 9,000 in 3DMark 11, the GeForce GTX 970M delivers extremely fast and fluid gameplay at the highest settings and resolutions in a lightweight and portable design.
The NVIDIA GTX 970 scored 28.2% higher than a GTX 870M GPU & 8.3% higher than the GTX 880M GPU in 3DMark 11.
Mega Storage & Speed with SUPER RAID 2
Unlock stunning graphics, silky-smooth motion, and higher frame rates on the go with innovative twin SSD in M.2 form factor. New M.2 SATA interface substantially minimizes access time, guaranteeing seamless gaming. Super RAID 2 design gives the storage performance up to 1500MB/s reading performance on MSI GS series, the reading, writing and saving speeds is 15x faster than a single 1TB 7200rpm HDD. And one more HDD can be installed in the same laptop without the need to expand the size to put recovery system, to backup and put more data.
The latest 4th generation Intel® Core™ i7 Processor
The latest 4th generation quad core processor platform, representing superior performance over previous generations. The CPU performance has increased by 3%~7%, while the overall platform is 15% more powerful. Additionally, the GPU performance of 2d and 3D visuals, is even more noteworthy, with an average increase of over 30%. There have also been significant advances in user experience and battery life. Moreover, it employs a more advanced encryption program to help businesses enhance information security and to protect your BIOS/FW from attacks by malware.
3K Display
3K wide-view LCD display takes image clarity to a whole new level with higher pixel resolution. Compare to full HD LCD display, the images are amazingly much more sharp and vivid with 40% more contrast level and 40% more brightness level than regular TN panel. When you're playing games, you will have breathtaking and brilliantly true-to-life viewing experience.
Matrix Display
Matrix display features up to 2 external displays, allowing you to output to 3 displays simultaneously using HDMI 1.4, mini Display-Port 1.2 and VGA port. Users can work with multi-task at the same time. (Overall 3 monitors include notebook's monitor on GS series).
Killer LAN: Zero Latency Is the only way in GAMING
The benefit of the Killer Gaming LAN is the "Advanced Game Detect™" technology, which recognizes online game data packs and processes them first, accelerating them in the process. The best weapon against stuttering characters, freeze-ups, and lagging, it vastly improves all the online experience. Whether FPS or MMO gaming, you'll have that advantage to response faster to get victorious.
802.11ac: 45% - 70% faster than regular 802.11n
802.11ac, the next generation of wireless, promises intensified signals and more stable connections. Experience wireless gaming like never before! Enjoy stronger throughput, extended coverage, less speed decline, and above all, freedom to play anywhere with your MSI GT70.
SteelSeries Engine
SteelSeries Engine is the App to combine all frequent functions for gamers in order to easily customize every individual key and functions to personalize every gamer's play style, including KLM, multiple devices management (for example, headset, mouse, and keyboard), key press macros, and text macros.
Friendly UI design
The SteelSeries Engine is easy to understand by using pictorial representations of devices along with basic drag-and-drop techniques to assign key presses, complex macros, device profiles and buttons. Also features intuitive macro creation with customizable colors, fonts, and names for everything.
4 keyboard layers options!!
There are 4 layers for gamers to set 4 usage scenario or game. Not only that, while playing the game, gamers can easily and quickly switch layer*, such as a chat screen with friends. Communication with friends is not interrupted!!
Intelligent keypress macro capabilities
There are virtually unlimited key press macro creation capabilities. Anything you can do on a mouse or a keyboard can be programmed along with specific event timing. You can even program mouse events into keyboard macros. Your macros will be running at a high priority in your computers Operating System, yet it does NOT interfere with your real time actions during gameplay.
KLM (Keyboard light management)
Depending on your mood and desires, you can choose from more than 1,000 color combinations and five different scenario modes for the keyboard, enabling you to be the coolest gamer at any LAN party!
Statistics to analyze and improve
Whether you're playing an FPS or editing in Photoshop, being better and more efficient is something we want to help you achieve. Use the Statistics module to record your keyboard or mouse actions. Then review the peripheral heat map, which shows with both color and numbers the frequency of your key or button presses. You can then use this information to fine tune your macros as well as your key and mouse button assignments to optimize your tools to play (and work).
Sound by Dynaudio
MSI worked with Dynaudio, world-class name in sound system design from Denmark, studying electrical circuits, dozens of speaker drivers, and how to best arrange internal parts and components to optimize sound. For over a year, they tweaked the sound and developed electrical circuits and materials with the best sound response. The results of their studies have been incorporated into MSI's high-end GT Series gaming NBs--the laptops with the best stereo sound in the industry. The GT Series, the only laptops in the industry with a Dynaudio sound system, clearly leads the industry not simply in terms of volume, but also in terms of stereo and crisp, clear sound for a more enjoyable gaming and multimedia experience.
Windows Start button
On the SteelSeries keyboard there is a change to the usual keyboard layout, the CTRL key is moved to the left of the keyboard and has been made larger as this is an important key for gamers and is now more accessible. The windows key has moved to the right of the keyboard so while your gaming you don't press it by accident, so now you won't quit your game in the middle of a battle!
Product Specification:
- Product Code: GS60 2QE(Ghost Pro 3K)-017K
- OS: Windows 8.1
- CPU: Sharkbay Core i7-4710MQ (2.5GHz - 3.5GHz)
- Display: 15.6" 3K (2880x1620) wide-view IPS LCD Display
- Max Memory Support: 16GB
- Graphics Chipset: NVIDIA GeForce GTX970M
- Graphics Memory: GDDR5 3GB
- Storage: 1 x 128GB M.2 SSD + 1TB 7200RPM
- Keyboard Type: SteelSeries FULL back lit keyboard with SteelSeries Engine
- USB3.0 Ports: 3
- HDMI Port(s): 1
- Mini Display port(s): 1
- LAN Port(s): 1
- Headphone Jack(s) (SPDIF): 1
- Card Reader: SD
- Audio: -Sound by Dynaudio
- LAN: Killer™ E2200 Game Networking LAN
- Wireless: 802.11ac
- Bluetooth: V4.0
- Webcam: FHD Camera 1080p
- Security: Kensington Lock
- Battery: 6-Cell Li-Polymer(4840mAh 52Wh)
- Dimension: 390 X 256 X 19.9
- Weight: 1.96Kg (With Battery)
- Warranty : 2 YR's Collect & Return (1 YR Global)
Was [£1559.99] Inc. VAT
Only £1,499.99 inc VAT.
ORDER NOW
Kingston Predator 16GB (4x4GB) DDR4 PC4-24000C15 3000MHz Quad Channel Kit - Black (HX430C15PB2K4/16) @ £239.99 inc VAT
Kingston Predator DDR4 is some of the most aggressive looking DDR4 available and looks menacing. Make your opponents fear you with Kingston Predator DDR4.
Specification:-
- CPU Compatibility: Intel Haswell-E ( LGA 2011-3 )
- Chipset: Intel X99
- Capacity: 16GB (4GBx4)
- Quad Channel kit: Yes
- Tested Speed: DDR4-3000 MHz (PC4-24000)
- Tested Latency: 15-16-16-36
- Tested Voltage: 1.25V-1.45V
- Registered/Unbuffered: Unbuffered
- Error Checking: Non-ECC
- Type: 288-pin UDIMM
- SPD Speed: 2133 MHz
- SPD Voltage: 1.2V
- Features: Intel XMP 2.0(Extreme Memory Profile)Ready
- Warranty: Lifetime
Was [£269.99] Inc. VAT
Only £239.99 inc VAT.
ORDER NOW
TeamGroup Elite 32GB (4x8GB) DDR4 PC4-19200C16 2400MHz Quad Channel Kit - Black (TPKD432GM2400HC16QC01) @ £337.99 inc VAT
TeamGroup Elite DDR4 offers great value and great performance with superb looks with all black PCB and heatspreader design,.
Specification:-
- Capacity: 32GB (8GBx4)
- Tested Speed: DDR4-2400 MHz (PC4-19200)
- Tested Latency: 16-16-16-36
- Tested Voltage: 1.2V
- SPD Voltage: 1.2V
Was [£359.99] Inc. VAT
Only £337.99 inc VAT.
ORDER NOW
TeamGroup Elite Black 8GB (2x4GB) DDR3 PC3-12800C11 1600MHz Dual Channel Kit (TPKD38G1600HC11DC01) @ £53.99 inc VAT
Keeping abreast with the latest trend to launch new products to replace the old, Team Group is now offering a new choice of superb value expansion with its ELITE DDR3. ELITE DDR3 features outstanding product quality that users have come to expect from Team Group and the product has also passed the strictest tests for quality assurance. Not only that, Team Group’s ELITE DDR3 is manufactured with full compliance to the specifications prescribed by JEDEC (Joint Electron Device Engineering Council) and has gone through extensive burn-in tests. ELITE DDR3 features standard 240 Pin design and operates on 1.5V of power to achieve low power consumption with a truly eco-friendly specification. In addition, TEAM ELITE also comes in a variety of selections with varying frequencies and capacities to satisfy consumers with different needs.
Features:-
- Module Type 240Pin L-DIMM 1600
- CL-tRCD-tRP-tRAS 11-11-11-28
- DRAM Density 256x8 / 512x8
- Data transfer bandwidth 12,800MB/Sec (PC3 12,800)
- Heat Sink Aluminum heat-sink
- Working voltage 1.5V± 0.075V
- Warranty Lifetime warranty
Was [£59.99] Inc. VAT
Only £53.99 inc VAT.
ORDER NOW
TeamGroup Elite Black 16GB (2x8GB) DDR3 PC3-12800C11 1600MHz Dual Channel Kit (TPKD316G1600HC11DC01) @ £99.95 inc VAT
Features:-
Was [£119.99] Inc. VAT
Only £99.95 inc VAT.
ORDER NOW
Sapphire AMD Radeon R9 295 X2 8192MB GDDR5 PCI-Express Graphics Card @ £599.99 inc VAT
No matter what the game or the resolution you can now select the maximum settings even at 4k resolution and enjoy fluid ultimate smooth framerates in latest games such as Titanfall, Diablo 3, Watchdogs and even potential upcoming games such as GTA V and Half Life 3 should they surface.
Featuring a pair of 290X Hawaii GPU's fused onto a single PCB with an advanced PLX chip along with only requiring 2x 8-Pin power connectors.
The other major feature of the 295 X2 is its cooling solution which truly does keep the cards temperatures around 60c even after gaming for hours and it also manages to do this in more or less silence with zero throttling of the cores themselves. Making it one of the smoothest, quietest and easily most powerful graphics card on the market today. If you really crave the most powerful and have or are considering a 4k monitor for gaming then the 295 X2 is the card for you.
If your demands are truly the most powerful experience possible then these cards work great in Crossfire (4 GPU's) and you will be able to smash benchmarks to pieces and have no slow downs in games.
Specification:-
- GPU: 2x Hawaii XT
- Hybrid Liquid Cooling
- Litecoin Hash Rate: 1600-2000
- Stream Processors: 5632
- ROPS: 128
- Core Speed: 1018MHz
- Memory Speed: 5000Mhz
- Memory interface: 1024-Bit (2x 512-Bit)
- Memory capacity: 8192MB GDDR5
- PCI-Express X16 lane required
- 850W or greater PSU required with genuine 8-Pin PCI-E cables such as Silverstone 1500W
- Case capable of fitting such a long card and support for a 120mm radiator
- Dimensions: Card is 307x111x65mm and Cooler is 153x120x63mm
- Power Connectors: 2x 8-pin
- Display Outputs: 1x Dual Link DVI, 4x Mini-DisplayPort
- Warranty: 2yr
Was [£659.99] Inc. VAT
Only £599.99 inc VAT.
ORDER NOW
XFX Radeon R9 290 DD 4096MB GDDR5 PCI-Express Graphics Card (R9-290A-EDFD) @ £229.99 inc VAT
AMD Radeon R9 290 is a new graphics card powered by the latest AMD Radeon™ R9 290 graphics-processing unit (GPU). 4GB of super-fast GDDR5 memory for the best gaming experience at the highest resolutions including 4k and incorporates AMD Eyefinity and TrueAudio technologies to enable expansive multi-display setups and more accurate environmental sounds. R9 290 also includes support for both DirectX® 11.2 and AMD's new Mantle application programming interface (API) for great handling of even the most-demanding PC games.
OcUK has negotiated special RMA terms with XFX which allows OcUK to express RMA any XFX item purchased from ourselves within 48 hours. Also exclusive to OcUK we allow the removal of the stock cooler for those wishing to water-cool their XFX product or change the cooler.
Specification:-
- GPU: Hawaii Pro
- Stream Processors: 2560
- ROPS: 64
- Core Speed: 947MHz
- Memory interface: 512-Bit
- Memory capacity: 4096MB GDDR5
- 600W or greater PSU required
- Power Connectors: 8-pin + 6-pin required
- Display Outputs: 2x Dual Link DVI, 1x HDMI, 1x DisplayPort
- Card Dimension (cm) : 29.5 x 14.3 x 4.2
- Card Dimension (inch) : 11.61 x 5.63 x 1.65
- Warranty: 2yr
Was [£229.99] Inc. VAT
Only £199.99 inc VAT - WITH VOUCHER CODE XFX290PROMO
ORDER NOW
Sapphire Radeon R9 280 Dual-X 3072MB GDDR5 PCI-Express Graphics Card @ £149.99 inc VAT
With 3GB of the latest GDDR5 memory and 1792 stream processors, and support for DirectX 11.2, the architecture is built to play the very latest games with perfectly smooth action even at higher resolutions such as 2560 x 1440. In fact its Ultra HD graphics processor can feed even the latest 4K displays with the HDMI 1.4a interface. The R9 280 family represents a breakthrough in cost
erformance.
Specification:-
- Litecoin Hash Rate: 500-700
- PCI-E 3.0 Ready: Delivers double the bandwidth per lane of PCIe GEN2 for faster GPU- CPU
- Hugely overclockable
- Core Clock Speed: 850MHz
- Boost Clock Speed: 940MHz
- Shader Architecture: GCN
- Stream Processors: 1792
- Texture Units: 128
- ROPS / Z-Stencil: 32 / 128
- Frame Buffer / Memory: 3GB GDDR5
- Memory Width / Speed: 384 bit / 5000MHz
- Display Outputs: 2x DVI + 1x DP + 1x HDMI
- Power: 250W TDP
- 2yr Warranty
Was [£187.99] Inc. VAT
Only £149.99 inc VAT.
ORDER NOW
Powercolor Radeon R9 280X TurboDUO 3072MB GDDR5 PCI-Express Graphics Card @ £179.99 inc VAT
Powercolor R9 280X has the performance to power the latest games with ease but at a very aggressive price point making it incredible value for money.
Equipped with TurboDUO near silent cooling solution meaning you can game in near silence whilst keeping the card nice and cool.
Features:-
- Multi Phase Design: 8 Power Phases for improved OC ability
- Digital PWM
- Ferrite Core Choke: Decreases ripple to deliver more stable voltage
- DirectFET
- Patent GSG- Shape Heat Pipes Design: Reduces temperatures by upto 17% and noise reduction of upto 19%
- Pure Copper Base
- Backplate included
Specification:-
- Litecoin Hash Rate: 550-750
- Core Clock Speed: 880MHz
- Boost Clock Speed: 1030MHz
- Stream Processors: 32 CU / 2048 ALU
- Memory Width / Speed: 384 bit / 6000MHz
- Display Outputs: 1x DVI + 1x DP + 1x HDMI
- Power: 250W TDP
- 2yr Warranty
Was [£199.99] Inc. VAT
Only £179.99 inc VAT.
ORDER NOW
MSI GeForce GTX 760 OC Gaming Edition 2048MB GDDR5 PCI-Express Graphics Card @ £149.99 inc VAT
GeForce® GTX 760 is the new weapon of choice for gamers—a powerful graphics card that gives you fast, smooth, quiet performance in all your favorite titles. It’s packed with next-gen technology innovations, engineering, and features that let you crank up the settings and resolutions in graphics-intensive games like Splinter Cell: Blacklist.
Take hyper-realistic gameplay to a whole new level with NVIDIA GPU Boost 2.0 for max clock speeds, PhysX® and TXAA™ for great graphics, and NVIDIA® SHIELD™ compatibility for incredible portable gaming. Plus, instantly access the latest game-ready drivers automatically—the day a game launches—and optimize settings with one click using GeForce Experience™. Even auto-record all your greatest gaming moments with NVIDIA ShadowPlay.
Specification:
- Core Clock: 1085MHz (GK104)
- Core Boost Clock: 1150MHz
- Memory: 2048MB GDDR5
- Memory Clock: 6008MHz (Effective)
- Memory Interface: 256-Bit
- Processing Cores: 1152
- Shader Clock: 2116MHz
- Bus Type: PCI-Express GEN 3.0 (Backwards compatible)
- Display Connectors: 2x Dual-Link DVI-I, 1x HDMI 1.4a 1x Displayport
- SLI Ready (Upto 3-Way SLI Supported)
- HDCP Capable
- DirectX 11 Support
- OpenGL 4.0 Support
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- NVIDIA Surround Enabled
- Lower power consumption (Maximum consumption 170 watts at stock speed)
- 1x 8-pin & 1x 6-Pin PCI-E Connectors required
- Winner of CustomPC Premium Grade AWARD with 93% overall score!
- Warranty: 3 Years
Was [£169.99] Inc. VAT
ORDER NOW
BenQ DL2215 21.5" Widescreen LED Monitor - Black @ £79.99 inc VAT
Whether you're catching up on the latest show on the Internet or viewing documents, the BenQ DL2215 LED monitor is the perfect choice for you in style! Featuring aspect ratio 16:9 and 100% dot-to-dot image quality, this 21.5"W LED monitor delivers every image detail with the best viewing quality.
- Screen Size: 21.5"W
- Aspect Ratio: 16:9
- Resolution (max.): 1920x1080
- Pixel Pitch (mm) 0.248
- Brightness ( typ.) 200 cd/m²
- Native Contrast ( typ. ) 600:1
- Panel Type TN
- Viewing Angle (L/R;U/D) (CR>=10) 90°/65°
- Response Time(Tr+Tf) typ. 5ms
- Display Colors 16.7million
- Color Gamut 72% NTSC
- Input Connector D-Sub/ DVI
- Power Supply (90~264 AC) Built-in
- Power Consumption (On mode) 20.7W
- Dimensions(HxWxD mm) 369 x 515 x 178
- Net Weight (kg) 2.8kg
- Gross Weight (kg) 3.9kg
Was [£85.99] Inc. VAT
Only £79.99 inc VAT.
ORDER NOW
BenQ VW2245Z 21.5" Widescreen LED Flicker-Free Slim Bezel Monitor - Black @ £79.99 inc VAT
Simply elegant and stylish, the Ultra Slim V40 Series is a perfect combination of aesthetics and technology that adds a touch of subtle splendor and sophisticated minimalism to your modern home décor.
The BenQ V40 Series Monitors, with the ultra-slim sleek design,deliver rich and exquisite visual performance that please your eyes. A masterpiece that is truly beautiful from inside out.
The Flicker-free technology eliminates flickering at all brightness levels and effectively reducing eye fatigue. Conventional LCD screens flicks 200 times per second. Your eyes may not see flickers, but can certainly feel them. Free your eyes from flickers by switching to Flicker-free Monitors and let your eyes do less work. The Reading Mode recreates the comfortable experience of reading actual books by adjusting the monitor's color temperature and brightness, as well as balancing its contrast ratio and sharpness, to simulate the look of paperback paper.
Experience the truest colors of the world with the BenQ Senseye® Human Vision Technology. With the help of its six proprietary calibration techniques, Senseye® 3 delivers only the best viewing quality in each of its pre-set viewing modes – Standard, Movie, Game, Photo, sRGB, Reading, M-book and ECO – with the ECO Mode especially design to save power and money.
Specification:-
- Back Light Unit LED
- LCD Size 21.5"W
- Aspect Ratio 16:9
- Resolution (max.) 1920 x 1080
- Display Area(mm) 476.64 x 268.11
- Brightness ( typ.) 250 cd/m²
- Native Contrast ( typ. ) 3000:1
- DCR (Dynamic Contrast Ratio) (typ.) 20M:1
- Panel Type VA
- Viewing Angle (L/R;U/D) (CR>=10) 178°/178°
- Response Time(Tr+Tf) typ. 25ms, 6ms (GTG)
- Connectivity: 1x DVI, 1x Analogue
- Warranty: 2yr
Was [£89.99] Inc. VAT
ORDER NOW
LG 22MP65HQ-P 22" LED IPS HDMI Monitor - Black @ £99.95 inc VAT
CINEMA SCREEN design delivers an incredibly immersive viewing experience. This artistic narrow bezel is now much slimmer. LG IPS Monitor features consistency and less changes in colour temperature, it realize a colour impression identical to its original image. Smooth colour change allows you to enjoy any content, such as action movies, web surfing and RPG games for a long time in comfort. Experts have conducted colour calibration tests at the production line for accurate colour. LG IPS Monitor provides the most accurate and lifelike colour for your advanced viewing pleasure. By reducing blue light to protect your eyes, Reader Mode provides optimal condition for reading. With just a touch of a button, you can comfortably read on the monitor for longer periods of time without straining your eyes. LG Monitor TV allows you to enjoy lifelike picture quality without any colour shift whether you are standing or lying down. SUPER+ Resolution technology helps to detect rough edges and blurring in contents when enlarged, offering improved quality with a better sense of high resolution.
Features:
- IPS Monitor
- Minimalistic Design with Cinema Screen
- Reader Mode
- Flicker-safe
Specification:-
- Screen Size: 22 in
- Viewable screen size: 21.5 in
- Screen technology: In Plane Switching (IPS)
- Colours: 16.7 Million
- Pixel Pitch: 0.24795 mm
- Brightness: 250 cd/m2
- View Angle: (Horizontal - Max) 178 °
- View Angle: (Vertical - Max) 178 °
- Anti-Glare / Anti-Static: Anti-glare 3H
- Contrast Ratio - Dynamic: 5,000,000:1
- Response time: 5 ms
- Tilt (Forward/Backward): -5 to +20 °
- Resolution (Native): 1920 x 1080 Pixels
- Resolution Type (Native): Full HD
- HD Support: Yes
- Connectivity: 1x HDMI, 1x VGA
- Warranty: 2yr
Was [£109.99] Inc. VAT
ORDER NOW
AOC G2460PQU 24" Widescreen 144Hz 1ms Gaming LED Monitor - Gunmetal @ £181.99 inc VAT
This display will make any gaming enthusiast´s heart beat faster: the stylish g2460Pqu will impress you with crystal-clear pictures. Enjoy fast-paced action sequences from the latest games or movies – crisp and blur-free due to an ultra-fast response time of just one millisecond and a refresh rate of 144 Hz. The strong typical contrast (1000:1) and high brightness (350 cd/m²) provide brilliant images. This gamers´ dream-come-true sports numerous connectivity options, such as D-Sub, DVI Dual Link, HDMI, DisplayPort and an integrated USB hub. These enable you to comfortably plug in several devices at the same time and display hi-res content on the large 61 cm (24") screen. Also on board: an integrated USB hub with 4 ports, including a fast-charge USB port for mobile devices. In addition, the Full HD display is equipped with LED backlights, making it particularly economical despite its great performance.
Product Review
- Won Kitguru "Worth Buying" Award
- Full Review Here: http://www.kitguru.net/peripherals/monitors/zardon/aoc-g2460pqu-144hz-24-inch-monitor-review/
Specification:-
- Height Adjust Stand
- USB Hub
- Monitor Size: 24"
- Visible Screen Size: 61 cm
- Screen Format: 16:9
- Brightness: 350 cd/m² (typ)
- Contrast Ratio Dynamic: 80.000.000:1
- Contrast Ratio Typical: 1000:1
- Pixel / Dot / Pitch: 0.276 (H) x 0.276 (V)
- Display Area: 531.36 (H) x 298.89 (V)
- Viewing Angle: 170°/160° (CR 10)
- Response Time: Up to 1 ms GtG
- Maximum Resolution: 1920 x 1080@144 Hz (DVI Port)
- Recommend Resolution: 1920 x 1080@144 Hz
- Colors: 16.7 M
- HDCP compatible: yes
- Inputs: Analogue, DVI-D, HDMI & DisplayPort
- Dimensions (WxHxD): 565.4 x 393.6 (+130) x 244.58 mm
- Warranty: 3yr
Only £181.99 inc VAT.
ORDER NOW
BenQ RL2455HM 24" Widescreen LED Monitor - Black/Red @ £129.95 inc VAT
The RL2455HM is a professional gaming monitor suited for RTS game play. This 24¨W LED monitor is packed with the latest features: the Black eQualizer, RTS Mode, Display Mode, Smart Scaling, 1ms GTG, HDMI and 12M:1 dynamic contrast ratio.
Poor visibility in dark scenes can cost even the most skillful gamers their game. The Black eQualizer color engine technology is designed to offer an unprecedented level of control and visibility. Dark scenes are brightened without over-exposing the bright areas to preserve vital details, enabling gamers to spot their enemies easily in critical combat and react quickly in any situation.
Every feature and function of the rl2455HM was meticulously throught out to provide RTS gamers with vital visibility and command to achieve peak performance. This out-of- the-box preset automatically fine-tunes your monitor accordingly for optimum RTS gaming, allowing you to see your enemies more visibly among the distractions and darkened areas. Built to give you the competitive edge, the exclusive RTS Mode will be your ultimate secret weapon. Now, we offer the two modes for players options: the RTS 1 mode for StarCraft II and the RTS 2 for Dota II. The exclusive preset RTS Mode will be your ultimate secret weapon.
The Display Mode and Smart Scaling features allow you to change the monitor view to suit your liking and to simulate any in-game experience.
Interchange instantly between four different screen sizes from 17", 19" and 19"W, 21.5"W, 22"W, 23"W to 24"W using the Display Mode. Or take advantage of the Smart Scaling feature and enjoy the flexibility to freely scale the screen content to any custom size. You can certainly use the two features together to get the best possible view for any application or game.
Fast response time of 1ms GTG means speed without the smear. Fast-moving action and dramatic transitions will be rendered smoothly - without smearing or ghosting. Control your gaming destiny and don't leave it in the hands of slow display.
Specification:-
- Screen Size: 24"W, TN LED
- Resolution (max.): 1920 x 1080
- Pixel Pitch: 0.276 mm
- Contrast Ratio: 1000:1
- DCR: 12M:1
- Response Time: 1 ms GTG
- Display Color: 16.7 million
- Viewing Angle (L/R;U/D) (CR>=10): 170 / 160
- Terminals: D-sub / DVI-D / HDMI x2 / Headphone jack / Line in
- TN LED Technology
- Senseye® Human Vision Technology (plus Senseye 3)
- Black eQualizer
- Advanced Motion Accelerator (AMA)
- HDCP Support
- Speaker: 1W x2
- VESA Wall Mounting (mm): 100 x 100 mm
- K Locker: Yes
- Warranty: 2yr
Was [£149.99] Inc. VAT
Only £129.95 inc VAT.
ORDER NOW
BenQ XL2420Z 24" TRUE 144Hz 3D Vision 2.0 Widescreen LED Monitor - Black/Red /w Flicker FREE Technology @ £259.99 inc VAT
A gaming monitor that gives you no excuse to lose – the 24-inch XL2420Z brings fluidity with perfect motion and an unprecedented level of control to help you conquer any enemy in FPS gaming. The BenQ monitor is built with the latest Motion Blur Reduction technology , Low Blue Light, Gaming-comfort Flicker-free, Gaming Refresh rate Optimization Management (GROM), and Display Pilot feature, offering agile performance, viewing comfort and convenience in one package! With the XL2420Z, you’ll be up for any challenge coming your way!
For a long time, the refresh rate of regular LCD displays has always been the key factor that puts professional gamers off from switching their CRT screens. Now, with BenQ’s new Motion Blur Reduction technology, gamers can finally set their mind at ease! Following is a simulated in-game video, you will see how BenQ Motion Blur Reduction helps you aim down targets with more precision comparing to the screen without.
Practice long hours with clear, comfortable vision or compete with top-notch vision condition with BenQ’s new Low Blue Light. The blue spectrum light, which is produced by regular computer screens, is a critical cause of eye damage, eyestrain, headaches and sleeping disorders. Now with the offering of various adjustable low blue light levels, gamers can better protect their eyes. So there would be no need for yellow tinted eyeglasses for additional eye protection, and gameplay can be clear, comfortable and hassle-free!
Developed in collaboration with pro gamers, the XL2420Z has been upgraded to eliminate flickering at all brightness levels. This effectively reduces eye fatigue and elevates gaming performance through extreme visual comfort for even the most hardcore gamers enrolling long hours in action. Armed with the Gaming-comfort Flicker-free Technology, the BenQ Gaming Monitor is an epic weapon over your ultimate rivals.
As the world’s leading brand in gaming monitor, BenQ has managed to provide more than just refresh rate feature when having different resolutions reaching more levels of optimal refresh rates(100/120/144Hz) with Gaming Refresh-rate Optimization Management (GROM), thus bring to users the scenario of incomparable gaming performance. With gamer-driven GROM which is collaborating with Display Mode and Smart Scaling strengths, BenQ offers a total solution on refresh rate for gaming enthusiasts.
The secret is out. Download special gaming preset calibrations used by well-known gamers so you can see what the pros see. Each mode is fine-tuned, so you can steal these exclusive presets used by pro gamers to your own advantage. You can even save your favorites on the S Switch for quick access and game play. More presets will be released in the future to keep you on top of your game.
The newly upgraded Display Pilot function allows users to make all the on-screen display adjustments, plus provides them with direct access to the Game Mode Loader feature for downloading and installing the preset display settings of their favorite game or professional gamer’s screen instantly.
Poor visibility and judgment can cost even the most skillful gamers their game. The Black eQualizer color engine technology is designed to offer an unprecedented level of control and visibility.
Fast response time of 1ms GTG means speed without the smear for an enhanced gaming experience. Fast-moving action and dramatic transitions will be rendered smoothly without the annoying effects of smearing or ghosting. Control your gaming destiny and don’t leave it in the hands of slow display.
The S Switch is a distinct remote controller that comes with three preset buttons, so you’re able to customize and save your display settings for gaming, work or entertainment purposes. It eliminates the tedious process of adjusting your monitor calibrations, so switching between the presets is as easy as 1-2-3. The S Switch also comes with a scroll button for quick OSD navigation and setting.
The newly designed OSD includes physical touch keys that enable you to conveniently change your settings in an intuitive horizontal slide-out display. This simplistic design makes it easier to navigate between options and settings.
The Display Mode and Smart Scaling features allow you to change the monitor view to suit your preference and to simulate any in-game experience. Using the Display Mode function, the monitor can be easily changed between 7different screen sizes, from 17”, 19”, 19”W, 21.5”, 22”W, 23”W and 24”W.
If you’re looking to customize your screen size further, you can also take advantage of the Smart Scaling feature. The Smart Scaling feature gives you the flexibility to freely scale the screen content to any custom size. With just one monitor, you can simulate any game play and practice under different display sizes for tournaments. Use the Display Mode and Smart Scaling together to get the possible view for any application or game.
The Height Adjustment Stand can be operated with just one finger so you can effortlessly adjust the height of the monitor to suit your sight level. Have the monitor way up high, or change it to sit flat on the table. The monitor can also be turned vertically or horizontally and comes with a quick-release VESA mount design. In addition, the sleek headphones hook at the back keeps your desk top neat and tidy.
Meet your secret winning strategy. The FPS Mode was co-developed with gaming legends to let you tap into the fundamental insights of pro gamers and view the game how a gaming legend would see it. This out-of-the-box preset automatically adjusts your monitor calibrations to provide you with optimal brightness, contrast, sharpness and color tint. Being able to spot your enemies and track their move carefully in every situation put you at an advantage over your opponents.There are two variations to this special mode: the FPS1 mode is designed to configure and optimize the display for Counter-Strike 1.6 and the FPS2 mode for Counter-Strike Source as recommended by BenQ. The perfect combination of form and function provides gamers with the vantage point to always be one step ahead of the game.
Certified as NVIDIA® 3D Vision™ 2-ready with the new NVIDIA 3D LightBoost™ technology to provide you with brighter and clearer 3D images. Now you can experience gaming and entertainment like never before with total realism and intensive 3D graphic display.
Specification:-
- Back Light Unit: LED
- LCD Size: 24"W
- Vertical Refresh Rate: 100 / 120 / 144Hz
- Resolution (max.): 1920 × 1080
- Display Area(mm): 531 x 298
- Pixel Pitch (mm): 0.276
- Brightness (typ.): 350 cd/m
- Contrast (typ.): 1000:1
- DCR (typ.): (Dynamic Contrast Ratio): 12M:1
- Panel Type: TN
- Viewing Angle: (L/R;U/D) (CR>=10): 170° / 160°
- Response Time: (Tr+Tf) typ. 1ms (GTG)
- Display Colors: 16.7 million
- Color Gamut: 72% NTSC
- Input / Output Connector: D-sub / DVI-DL(Dual-Link) / HDMIx2 / DP1.2 / Headphone jack
- Power Supply: (90~264 AC) Built-in
- Power Consumption: (Base on Energy star ): 24W
- (Power saving mode): 0.5W
- Kensington Lock: Yes
- Dimensions: (HxWxD mm) 516 x 571 x 149
- Net Weight (kg): 6.1
- Motion Blur Reduction: Yes
- Low Blue Light: Yes (10 levels)
- Black eQualizer: Yes
- Game Mode Loader: Yes
- Display Mode: 17" / 19" / 19"W / 21.5"W / 22"W / 23"W / 24"W
- Smart Scaling: Yes
- FPS / RTS Mode: Yes / Yes
- Flicker-free Technology: Yes
- Display Pilot: Yes
- Senseye: Senseye 3
- AMA: Yes
- Win7: Yes
- Win8: Yes
- Height Adjustment: Stand (mm) 130(adjustable down to the base)
- Warranty: 2yr
Only £259.99 inc VAT.
ORDER NOW
BenQ XL2430T 24" TRUE 144Hz Widescreen LED Monitor - Black/Red /w Flicker FREE Technology @ £275.99 inc VAT
BenQ’s new Motion Blur Reduction technology further enhances an ultra-smooth, free-of-blur gaming experience, particularly for action-packed FPS games where every millisecond count. With Motion Blur Reduction, gamers no longer suffer from time and gaming comfort lost to poor vision quality created by motion blur and lagging. Instead, they have everything to gain with more reaction time advantage on their side to achieve ultimately a flawless victory.
Fast response time of 1ms GTG means speed without the smear for an enhanced gaming experience. Fast-moving action and dramatic transitions will be rendered smoothly without the annoying effects of smearing or ghosting. Control your gaming destiny and don't leave it in the hands of slow display.
As the world’s leading brand in gaming monitor, BenQ manages to provide more than just the refresh rate feature for different resolutions to reach more levels of optimal refresh rates (100/120/144Hz) with Gaming Refresh rate Optimization Management (GROM), which aims to bring users the incomparable gaming performance. With the gamer-driven GROM that collaborates with Display Mode and Smart Scaling strengths, BenQ offers a total refresh rate solution for gaming enthusiasts.
It is absolutely vital that the XL2430T give you the flexibility you need to get the color performance you seek. This is why BenQ built into the monitor 20 levels of Color Vibrance setting to meet gamers’ specific viewing requirements and preferences for all types of gameplay. This unique feature is accessible via On Screen Display (OSD) or Display Pilot for added convenience.
To ensure that gamers can duplicate the exact same monitor set-up with the highest accuracy, efficiency and convenience, BenQ made a few additions to the XL2430T’s Adjustment Scale Design. The adjustable height stand is now scaled with 14 height levels trackable by a moving marker. Trackable scales are also added to the screen, which tilts forward and backward to 0°, 10° and 20v, and swivels left and right to a wide range of angles. Every XL2430T can be your personal XL2430T.
The newly improved Black eQualizer Dynamic color engine technology takes visibility optimization to a whole new level with automatic brightness adjustments. The XL2430T is able to detect the input source and automatically fine-tune the amount of brightness enhancement within the range of the brightness level selected by the user. Now, gamers can spot their enemies in critical combat effortlessly and react to any situation quickly without having to lift a finger for manual adjustments.
The secret is out. Download special gaming presets used by the professional players so you can see what the pros see. Each mode is fine-tuned so you can leverage these exclusive presets used by pro gamers to your own advantage. They can also be saved on your S Switch for quick access and game play. More presets from professional gamers will be released in the future so you can always stay on top of your game.
The Auto Game Mode enables the XL2430T to detect the genre of the game being played and switch the display setting to the corresponding game mode automatically. It is also designed to make new game mode recommendations for download. This unique feature is accessible through the On Screen Display (OSD) setting as well as the Display Pilot software or the S Switch Arc that has a quick key built in for this mode.
To save gamers the hassle of having to re-download and reset game modes, the XL2430T allows gamers to store game modes onto a USB flash drive for easy and simple carriage. They can also share their own game modes with everyone via cloud storage or social media platforms. This innovative feature allows gaming communities to share, collaborate and bond freely with ease.
The S Switch Arc is an external controller that comes with preset buttons that can be customized with personal display settings for gaming, work or entertainment use. The S Switch Arc not only sports a quick key for the Auto Game Mode but also a rounder look for a more natural and comfortable grip that enables gamers to best navigate between game modes.
Sporting the latest angular, compact base that aligns perfectly parallel to the desk surface and a monitor stand meticulously placed in golden ratio to counter balance the display, the next-generation base stand design offers a new level of stability for the steadiest gameplay – with stringent swivel and shock testing results to prove it. Additionally, the reduced width and depth further shortens the distance between the keyboard and the monitor, bringing you closer than ever to the game.
The aluminum alloy coated monitor stand sends off a sophisticated yet mysterious metallic appeal that conjures up the majesty of the game. On top of that, it is ergonomically optimized with a widened and thickened top handle that’s comfortable to grip, making the monitor much easier to carry from one place to another.
Placing a retractable headphone hook on the left side of the monitor display conveniently puts your headphones within arm’s reach. The material of the headphone hook, which has been upgraded to aluminum alloy, offers extra hardness and strength for improved durability.
Developed in collaboration with pro gamers, the XL2430T has been upgraded to eliminate flickering at all brightness levels. This effectively reduces eye fatigue and elevates gaming performance through extreme visual comfort for even the most hardcore gamers enrolling long hours in action. Armed with the Gaming-comfort Flicker-free Technology, the BenQ Gaming Monitor is an epic weapon over your ultimate rivals.
Specification:-
- LCD Size: 24"W
- Panel Type: TN
- Input / Output Connector: D-sub / DVI-DL(Dual-Link) / HDMIx2 / DP1.2 / Headphone jack / USB Hub
- AMA: Yes
- Win7: Yes
- Win8: Yes
- Full Specification: http://gaming.benq.com/gaming-monitor/xl2430t/specification/#skip
- Warranty: 2yr
Was [£289.99] Inc. VAT
Only £275.99 inc VAT.
ORDER NOW
LG 24GM77 24" TRUE 144Hz Widescreen LED Monitor - Black /w Flicker FREE Technology **OcUK Exclusive** @ £215.99 inc VAT
For the smoothest gaming experience, MOTION 240 creates an effect similar to changing a frame 240 times and eliminates afterimages whilse minimizing motion blur. It also improves response time and delivers ultra-smooth playback by performing at a speed faster than 1ms, the speed that gamers are looking for.
A Dynamic Action Sync Mode, make real-time commands and strike fast. Gamers can catch every single moment in real-time with dynamic action sync mode. It synchronizes your senses with real-time scenes happening in a fast-paced game by minimizing input lag. Make timely commands to win!
A Black Stabilizer, enhanced gamer visilbility to win in pitch black areas. Black stabilizer gives gamers full visibility even in deep-dark scenes. It automatically senses the darkest side and makes it brighter so that you can find the enemies hiding and waiting to attack you in the dark.
A Convenient game mode and game pad. Quick and easy customizable settings for your perfect gaming display environment.
Features:-
- Gaming without blurring and ghosting with "Smooth Motion"
- Detect enemies one step faster with "Swift Action"
- Personalized gaming environment with "Rapid * Easy Settings"
- Motion 240
- Dynamic Action Sync
- Black Stabilizer
Specification:-
- Height adjust and swivel stand.
- LCD Size: 24"W
- Panel Type: TN
- Response Time: (Tr+Tf) typ. under 1ms (GTG)
- Brightness: 350cd/m2
- VESA: Yes 100x100
- Warranty: 3yr
Only £215.99 inc VAT.
ORDER NOW
BenQ XL2720Z 27" TRUE 144Hz 3D Vision 2.0 Widescreen LED Monitor - Black/Red @ £329.99 inc VAT
Built for competitive FPS game play, the XL2720Z takes the explosive thrills of perfect motion gaming to a 27” screen. The stunning monitor is equipped with the latest Motion Blur Reduction technology, Low Blue Light, Gaming-comfort Flicker-free, Gaming Refresh rate Optimization Management (GROM), and Display Pilot feature to deliver agile performance, viewing comfort and convenience all at once – for your victory and entertainment.
Developed in collaboration with pro gamers, the XL2720Z has been upgraded to eliminate flickering at all brightness levels. This effectively reduces eye fatigue and elevates gaming performance through extreme visual comfort for even the most hardcore gamers enrolling long hours in action. Armed with the Gaming-comfort Flicker-free Technology, the BenQ Gaming Monitor is an epic weapon over your ultimate rivals.
Interchange instantly between different screen sizes, from 17" (4:3), 19" (4:3), 19"W (16:10), 21.5"W (16:9), 22"W (16:10), 23"W (16:9), 23.6"W (16:9), 24"W (16:9) to 27"W(16:9), using the Display Mode.
Specification:-
- LCD Size: 27"W
- Display Area(mm): 598 x 336
- Pixel Pitch (mm): 0.311
- Brightness (typ.): 300 cd/m
- DCR (typ.) (Dynamic Contrast Ratio): 12M:1
- Panel Type: TN
- Viewing Angle (L/R;U/D) (CR>=10): 170° / 160°
- Input Connector: D-sub / DVI / HDMIx2 / DP1.2 / Headphone jack
- Power Consumption: (Base on Energy star ) 27W
- Dimensions: (HxWxD mm) 548 x 642 x 273
- Net Weight (kg): 7.5
- Display Mode: 17" / 19" / 19"W / 21.5"W / 22"W / 23"W / 23.6"W / 24"W / 27"W
- AMA: Yes
- Win7: Yes
- Win8: Yes
- Height Adjustment Stand (mm): 130(adjustable down to the base)
- Warranty:
Was [£349.99] Inc. VAT
Only £329.99 inc VAT.
ORDER NOW
Samsung SyncMaster S27D390H 27" Widescreen Slim Bezel LED Monitor - Black @ £166.99 inc VAT
Samsung’s newest Touch of Colour design is sure to command attention. Upholding Samsung’s ToC design legacy, the SD390 was crafted to catch the light of its surroundings in various beautiful ways, but brings a narrow bezel, slim and sleek black body and transparent neck to create a sophisticated and tasteful look that’s finished off perfectly with a subtle hint of soft pure blue along the bezel – making this unique monitor illuminate light and stand out in a way you’ve never seen before.
On or off, the stylish SD390 is sure to stand out wherever it is. Its narrow bezel design lets you see more of the screen while illuminating a subtle hint of soft pure blue that sets an elegant glow around the monitor. Its transparent crystal neck gently gleams in the light with a beautiful touch of blue and raises the screen to the perfect viewing level. The tilt feature increases your field of vision and maximises your viewing comfort. The SD390 will no doubt fulfill your every design desire.
Get perfect viewing for games with just one touch of a button. Game Mode adjusts your monitor’s settings instantly to give you an optimised gaming experience. Game Mode smartly detects the changes in scenes, enhances the colour and alters the screen’s contrast to make dark spots darker and light spots lighter so you can see all the action at all times. There is less lag thanks to a faster video response time that ensures that the picture keeps up with action and won’t let you down.
Get the best view from any angle with the SD390. Unlike conventional monitors, your Samsung LED Monitor has an extra-wide viewing angle of 178 degrees, vertically and horizontally. This means great picture quality from even more perspectives – whether you’re sitting down low and playing games or if several people are sitting around the monitor to watch a video. Whatever the situation, you can enjoy great viewing.
Magic Upscale improves image quality to such a level that you will only receive a better picture. Enjoy enhanced image quality no matter what the original picture quality is. Magic Upscale prevents image degradation when scaling up and gives only brilliant and pristine colours and images. And it also makes images on the monitor appear clearer and sharper than on a notebook. Shine with the SD390.
The Samsung SD390 monitor gives you all the connections you need to make the most of all your entertainment and other content. HDMI compatibility gives you access to games consoles, Blu-ray players and other AV devices, while a D-Sub connection mean you can plug in most PCs. You can easily connect your devices and use the monitor for working, gaming, viewing content and more.
Specification:-
- Screen Size: 27
- Panel Type: PLS
- BLU Type: LED
- Brightness (Typical): 300cd/m²
- Peak Luminance Ratio: 99%
- Dynamic Contrast Ratio: Mega
- Resolution: 1920 x 1080
- Response Time: 5ms (GTG)
- Viewing Angle (H/V): 178° / 178°
- Color Support: 16.7M
- Connectivity: 1x Analogue & 1x HDMI
- Full Spec: http://www.samsung.com/uk/consumer/pc-peripherals/monitors/essential/LS27D390HS/XU
- Warranty: 2yr
Was [£179.99] Inc. VAT
Only £166.99 inc VAT.
ORDER NOW
Samsung S27A850TS 27" Widescreen Ultra Thin LED Professional PLS Monitor - Matte Black @ £299.99 inc VAT
Engineered with the ecologically responsible homeowner in mind, the Samsung monitor reduces power consumption by 40%;, making it much more efficient than conventional monitors. By reducing the number of LED and defaulting to standby power, which requires less than 0.3W as opposed to the typical 1.0W, the Samsung monitor is poised to make a difference. How big a difference? If your monitor saves 120W each day, that’s the annual equivalent of eliminating 10.8kg of CO2 emitted from an oil-burning power plant—which produces the same effect as planting four pine trees.
Choose a monitor that allows you to reduce financial and environmental costs as well as increasing productivity. The Samsung SA850 LED Business Monitor is designed to use less power, so you can cut bills and be kinder to the planet. A high 2560 x 1440 pixel resolution also makes sure you’ve got screen space for all your work and lets you see it all in greater detail. You’ll see images and video with stunningly natural colour thanks to sRGB support, and a 178 degree viewing angle gives great viewing from a wider range of perspectives, so it’s perfect for sharing presentations and more.
The Samsung SA850 Monitor showcases an astounding WQHD display with 2560 x 1440 pixel resolution, which is four times the resolution of HD (720p). It is perfect for businesses and industries that rely on access to extremely fine monitor detail. The wide screen, which features dual link DVI and display port, allows for more detail to be viewed and is ideal for work places such as hospitals, clinics and studios. The enhanced screen resolution provides greater efficiency and quality, and really is the must-have business tool.
Whether it’s video from an HD camcorder or photos from your digital camera, sRGB support makes sure that nature looks just as natural on your Samsung Monitor as it did when you shot it or filmed it. No matter what digital device the image was captured on, it’s as picture perfect on screen as Mother Nature intended it to be. So you can view, edit, and save images in their original format with no picture quality degradation whatsoever — which translates to 100%; pure digital satisfaction.
Provide employees with an optimal viewing experience in the office with the reasonably priced Samsung Business Monitor. While conventional monitors have a viewing angle of 170 degrees horizontally, the Samsung monitor has an extra wide viewing angle of 178 degrees. The additional 8 degrees is particularly useful when sharing on-screen information with one or more coworkers or presenting your ideas to clients. The Samsung Business Monitor has improved its vertical viewing angles by 18 degrees, making it the perfect display for giving presentations in front of a large audience or when viewing other content such as a video.
Maximise your viewing experience with Samsung’s superior PLS technology (Plane to Line Switching). Regular screens suffer from what is called Colour Shift, which reduces the picture quality and colour when viewed from an acute angle. The SA850, which can cover an amazing 178° viewing angle both vertically and horizontally, boasts a crisp and detailed picture by maintaining true-to-life colour, even when viewed from extreme angels, so the experience is always vivid and brilliant.
The Samsung LED Business Monitor SA850 has been designed to help boost work efficiency, delivering a tailored experience with its choice of viewer settings. The height-adjustable stand ensures that the screen can always be set at the optimal eye level, which enhances the visual experience while also helping maintain the viewer’s body posture. Other features include the tilt and pivot capabilities, which not only increase comfort levels but also introduce new ways of working. The SA850 Monitor can rotate 90°°° degrees, allowing for more appropriate view depending on the work. So, now you can take convenience and efficiency to amazing heights with the Samsung LED Business Monitor SA850.
If you need a work monitor that uses office space efficiently, then Samsung LED Business Monitor SA850 is the perfect choice. It features an innovative new detachable adaptor, which allows the monitor to be easily moved and installed. From physically moving the monitor with the carrying handle to quickly installing, the SA850 is ready to deliver an efficient and clean work space. The SA850 is also equipped and prepared for you as a VESA Wall mount, providing a multi-screen or wall mounted monitor. Optimising your office space is now easily achieved with the Samsung LED Business Monitor SA850
Utilising Samsung’s dual input feature, two PCs can now be viewed simultaneously on the one monitor screen. The SA850’s Picture by Picture capabilities allow for a far more flexible approach to work and ensure that content can be easily accessed, even if they require different PC access. This is perfect for businesses handling large and complex content from two PCs, but prefer to view it on one convenient screen.
As the work environment becomes increasingly modernised, it is essential that monitor also have the latest technology. Samsung SA850's USB Hub with USB 3.0 technology, which provides super-speed data transmissions, is the ideal solution for connecting all of your mobile devices. With a maximum speed of 5GB per second and uncompressed Full HD video transmissions, the USB Hub effortlessly brings your content together on one convenient monitor.
Eco saving makes saving energy easy, it adjusts the brightness of your Samsung monitor based on how much energy you want to save. And with the choice of three energy saving modes (50%;, 25%; and Power Saving off), you can really tailor your monitor use to meet your own personal needs. Samsung’s commitment to saving energy is designed to help both you and the environment, and with up to 50%; saving on consumption, you can really make a positive impact on your eco footprint. Take the effort out of saving energy and take control with Eco saving.
Take the guess work out of eco savings with Samsung’s new Energy Tree feature. For the first time, you can now know exactly how much energy you are saving through your eco modes such as the Eco light sensor and the Eco motion sensor. Through an intuitive energy saving status, which can be displayed either intuitively or graphically, you can keep tabs on your efforts to make the world a better place.
Features:-
- 27" (16:9)
- 300cd/m² Brightness
- DCR Mega 8 Dynamic Contrast Ratio
- 2560 x 1440 Resolution
- 5ms Respond Time
- 178° / 178° Viewing Angle
- 16.7 Million Colour Support
- Inputs: 1x Dual Link DVI, 1x DisplayPort, 1x HDMI
- 3x USB
- HAS (150mm)
- Tilt / Swivel / Pivot
- VESA: (100 x 100, 100 x 200) Available
- USB 3.0 Super Power
- 2yr Warranty
Was [£559.99] Inc. VAT
Only £299.99 inc VAT.
ORDER NOW
BenQ BL3200PT 32" Widescreen LED Professional/Gaming Slim Bezel Flicker FREE Monitor - Black @ £469.99 inc VAT
Accurate Color Gamut that brings your imagination to life, A Large Screen that extends your design space, High Resolution to view the smallest details, Ergonomic Features that ease your eye and neck strain... Result, A monitor that meets all your CAD/CAM needs!
With a 2560x1440 WQHD resolution and extra working space mean less scrolls for zooming in and out. Start using BenQ CAD/CAM Monitor now and boost your work efficiency!
The unique CAD/CAM Mode is specially designed to enhance work efficiency and reducing eye fatigue for all CAD/CAM users. By making the color contrast higher, every displayed line will be perfectly distinguished. With BenQ CAD/ CAM Monitors, you will never miss a line again in your designed work.
To clearly distinguish detailed textures in the darkest areas, BenQ developed Animation Mode that enhances brightness in dark areas without overexposing bright areas. With ten levels of brightness, the Animation Mode provides the comfort and freedom that every designer will welcome with open arms.
With the BenQ’s advanced 100% sRGB screen technology, every color is delivered with the finest precision in every detail and at every possible viewing angle. Get and share a professional viewing experience.
Auto Pivot detects the rotation of the monitor and dynamically rotates displayed content automatically. All windows will be equally portioned and displayed on the screen when clicking on the Desktop Partition icon, which allows you to compare all design works with just, one simple click. Moreover, you can preset different picture modes to each frequently used software. Display Pilot will automatically switch to your preferred picture mode in different user scenarios.
Unique control device docked to the stand of every BL3200PT monitor remotely accesses the OSD menu. Three pre-set hot-keys allow quick switching between 1. sRGB Mode, 2. CAD/CAM Mode, 3. Low Blue Light Mode, or let you assign your own set of display modes providing ultimate user flexibility.
Large screen monitors usually take a noticeable amount of space on the working desk. BL 3200 is designed to save as much of your workspace as possible. Compact stand architecture enables the screen to sit at the very edge of the desk and maximize your working space and comfort.
I/O ports on the side of the screen effortlessly bring all your content together in one convenient package. 2x USB 3.0 and SD card reader provide super-speed data transmissions.
The slim bezel makes the monitor look lighter and larger. In a multi-display setup with two or more units, thin bezels are less intrusive and effectively expand your work-space.
An extensive range of monitor adjustments – height, tilt, pivot, stroke and swivel – tailor your own unique working station that is best suited for your height and viewing habits with a maximum 150mm distance between the screen bottom and the base.
The Flicker-free technology eliminates flickering at all brightness levels and effectively reducing eye fatigue. Conventional LCD screens flicks 200 times per second. Your eyes may not see flickers, but they can certainly feel them. Free your eyes from flickers by switch to CAD/ CAM Monitors and let your eyes do less work while you are working on CAD/ CAM designs.
Every Monitor produces a strain of blue spectrum light that is one of the critical causes of eye damage, eye strain, headaches and sleeping disorders. BenQ's unique Low Blue Light technology is designed to deal with the everyday problem of blue light exposure and allows a healthier time spent in front of your computer. Switch to one of the four preset Low Blue Light Modes from OSD hot key (Multimedia – 30% reduction, Web-surfing – 50% reduction, Office – 60% reduction, Reading – 70% reduction), and reward your eyes without having to lose the visual enjoyment. Corporate users are frequently required to read documents from a monitor. Reading Mode adjusts the screen brightness, contrast ratio and sharpness to make your eyes feel as easy as reading directly from hard copies without wasting any paper.
Specification:-
- Screen Size: 32"W, VA LED
- Resolution (max.): 2560 x 1440
- Brightness: 300 cd/m2
- Contrast Ratio: 3000:1
- DCR: 20M:1
- Response Time: 4 ms GTG
- Display Color: 1.07 billion
- Viewing Angle (L/R;U/D) (CR>=10): 178 / 178
- Terminals: D-sub / DVI-D / HDMI / DisplayPort
- Flicker FREE technology
- VA (AMVA+) LED Technology
- HDCP Support
- Speaker: 5W x2
- USB Hub: Yes
- Dimensions(HxWxD mm) HIGH: 640.16*740.28*232.48mm
- Warranty: 2yr
Was [£499.99] Inc. VAT
Only £469.99 inc VAT.
ORDER NOW
Dell UltraSharp U3014 30" Widescreen LED Monitor - Midnight Grey @ £749.99 inc VAT
Users will experience outstanding color accuracy, precision and performance with the Dell UltraSharp U3014 30-inch monitor with PremierColor. The U3014 is Dell’s flagship high performance monitor with a 16:10 aspect ratio, suitable for the fine level of detail required for color-critical work such as CAD/CAM, graphic design, desktop publishing, gaming or media creation. In addition, users will experience stunning high-definition details and the ability to view more onscreen content with 2560 x 1600 resolution. More than just a high performance monitor, the U3014 offers flexible viewing options, versatile digital connectivity and is designed for exceptional efficiency with an eco-design that meets the latest environmental standards like EPEAT®, ENERGY STAR® and TCO Certified Displays.
Features:-
- IPS (in-plane switching) technology for minimal color deviation across a wide viewing angle
- 30" (76cm) display with 2560x1600 resolution and 16:10 aspect ratio for clear images and exceptional multitasking
- Easy, versatile adjustability and some of the latest connectivity options, including HDMI, DisplayPort, DVI-D, USB ports and a 7-in-1 media card reader
Specification:-
- 30" Widescreen
- Light AG coating
- About 52.5% more screen area than Dell 2407WFP-HC
- The only 4 mega pixels monitor that shows true resolution of mega pixel pixel photos
- Higher definition than HD Television to meet the most stringent video needs
- 2560 x 1600 (WQXGA) Optimum Resolution (Dual Link capable DVI-D graphics card required)
- 1.07 Billion Colours
- 10-Bit Colour
- 1000:1 Contrast Ratio
- 6ms Response Time (6ms Grey-TO-Grey)
- 350 cd/m2 Brightness
- DVI-D Input with HDCP support
- HDMI Input
- Display Port Input
- Height adjustable stand, tilt and swivel (100mm travel)
- VESA mounting compatible / Security slot : Yes (100mm) / Yes
- Integrated powered USB 3.0 hub : 4 downstream / 1 upstream ports
- Integrated powered 9-in-2 Smart Card Reader: Compact Flash 1&2, Secure Digital, MMC, Smart Media and Microdrive
- Warranty : 3 year next business day exchange supplied by Manufacturer. (Call Dell on 0870 9080800 and have the work number from the original packaging handy, request to speak to the Dell Warranty Monitor Line)
- Product Review @ TFT Central: http://www.tftcentral.co.uk/reviews/dell_u3014.htm
Was [£799.99] Inc. VAT
Only £749.99 inc VAT.
ORDER NOW
LG Flatron 29UB65-P 29" WideScreen Super-Wide LED Monitor @ £259.99 inc VAT
The 21:9 ratio is the perfect professional fit for software engineers, video / sound editors, and graphic designers. Imagine 2 conventional high quality monitors attached for multi-tasking, but their screens connect and extend seamlessly. Now you can use a program with long-range panoramic view in full length, without any bezel in the middle or dragging cursors. No longer divide your focus into separate monitors, the 29UB65 is the perfect companion for your profession.
Like other smart devices, the 29UB65's Pivot & Height Adjustable feature allows you to simply rotate the screen to fit vertically long images or files. When pivoting, you can easily adjust its height too. Leave dragging and scrolling behind. Let the monitor adjust to your images and needs.
Connect two devices to a single monitor with Dual Link-up that allows an HDMI + HDMI link. Now you and your colleague can simply bring each other's devices and connect to a single monitor to share and compare information. Freely show and control your screen while watching your partner doing the same on the opposite side of the monitor. Don't bother installing annoying projectors in your small room or worry when your conference room is occupied, the 29UB65 is here for you.
With its wide screen ratio, now you can open 4 programs on a single screen to see your information in a single glance while working. The size of sub screens is user-controlled. The 29UB65 is compatible with Mac® and not only provides convenience but also productivity in a single click, you can split your screen into 2 to 4 subscreens.
Reducing blue light to protect your eyes, Reader Mode provides optimal condition for reading. With just a touch of a button, you can comfortably read on the monitor for as long as you would like to.
As LG IPS Monitor features consistency and less changes in colour temperature, it offers a colour impression identical to that of the original image. You can enjoy lifelike picture picture quality without any colour shift whether you are standing or lying down. It allows you to enjoy any content, such as action movies, web surfing and RPG games for a long time in comfort.
Protect your eyes from exhausting flickers and blue lights. LG's new Flicker Safe system is always on to reduce the flicker level to almost-zero. In addition, activate the Reader Mode to minimize harmful blue lights with a simple touch of a hot-key. Spend as long as you want working, gaming, or watching movies without burdening your eyes. Use the convenient and easy hot keys for more satisfaction.
The joystick is a harmony of accurate menu controls and analogue sensitivity. With the fun control of a conventional joystick, its modern technology and design allow for simple control with a pleasant touch. In addition, intuitive UI with no overlapping is easier to understand and select menus.
Specification:-
- Screen size (inches): 29"
- Panel Type: IPS
- Aspect Ratio: 21:9
- Resolution: 2560*1080
- Brightness (cd/m2): 300
- Contrast Ratio: 100000000:1
- Viewing Angle (°): 178/178
- Colour Depth (Num of Colours): 16.7M (8-Bit)
- Pixel Pitch (mm): 0.315 x 0.310
- Colour Gamut: sRGB
- Surface Treatment: Hard Coating (3H), Anti-Glare
- Connectivity: 1x DVI-D, 2x HDMI, 1x DisplayPort
- Speakers: 2x 7W
- Warranty: 2yr
Was [£281.99] Inc. VAT
ORDER NOW
LG Flatron 29UM65-P 29" WideScreen Super-Wide LED Monitor @ £239.99 inc VAT
The 29UM65 satisfies your demands for viewing pleasure and entertainment. Put high spec games on the 21:9 wide screen with astonishing picture quality of UltraWide Full HD (2560x1080) accompanied by 7W stereo speakers and satisfy your desire for the most realistic gaming experience and movie adventures.
With a 21:9 wide screen ratio, now you can multitask with 4 programs on one screen at the same time. This 4-Screen Split feature conveniently divides your screen from 2 to 4 customizable subscreens of your preferred size, without any overlapping of windows. Compatible with Mac®, it provides 8 different screen ratios, changeable by a single click, and increases not only your convenience but also productivity.
The Dual Link-up feature allows two devices to be displayed simultaneously on a single screen. With the monitor, you can connect and watch a movie from a Blu-ray player while working on an Excel spreadsheet from your PC. With the 29UM65's upgraded Dual Link-up, it enables HDMI+HDMI links, now you can connect devices more conveniently.
Reducing blue light to protect your eyes, Reader Mode provides optimal condition for reading. With just a touch of a button, you can comfortably read on the monitor for as long as you would like to. Enjoy your movies or games with realistic stereo sound. With the built in stereo speaker, there is no need for extra speakers around your monitor.
Specification:-
- Panel Type: IPS
- Contrast Ratio: 50000000:1
- Warranty: 2yr
ORDER NOW
LG Flatron 34UM95-P 34" WideScreen Super-Wide LED Monitor @ £719.99 inc VAT
The UltraWide 21:9 aspect ratio makes movies and games more immersive than ever. Need to get some work done, too? All of that UltraWide real estate makes it easy to view multiple documents at the same time, so you don't need to flip back and forth between them.
The 3440X1440 UltraWide QHD display offers amazingly sharp picture quality. Its pixel area is about 1.8 times larger than an UltraWide Full HD 21:9 monitor, and about 2.4 times larger than a Full HD 16:9 monitor. It provides an efficient environment in using Microsoft Office programs showing 47 columns and 63 rows in excel.
sRGB is the standard color space of ideal color reproduction. So, with over 99% coverage of the sRGB spectrum, this LG monitor is a great solution for professional photographers, graphic designers or anyone looking for highly accurate color.
Multitasking doesn't have to mean shuffling back and forth between windows*. With a single click, the 4-Screen Split feature divides the screen into as many as four customizable segments, two-by-two. Now you can see four different windows at the same time.
The Dual Linkup feature allows two compatible portable devices--such as a computer, camera, phone, or Blu-ray player--to be connected to the monitor, and both can be viewed on the same screen simultaneously.
This monitor's Thunderbolt input/output port allows you to connect up to six compatible devices, moving data between them with incredible speed. The two channels of 10-gigabits-per-second throughput in both directions are up to 20X faster than USB 2.0. Thunderbolt is an exciting innovation for both expansion and premium video display.
The DisplayPort digital video interface is used to connect a high-performance video source to a high-resolution monitor. Thanks to its sophisticated design, a DisplayPort cable can also be used to carry audio, USB signals and other data as well.
LG’s LED backlighting delivers exceptional brightness and amazing image clarity. You'll see richer colors and deeper blacks too, and LEDs offer greater energy efficiency compared to conventional LCD monitors.
IPS (In-Plane Switching) technology enhances thA dynamic contrast ratio of 5,000,000:1 is your assurance of strong video performance, with deep blacks, bright whites and pleasing colors.e performance of liquid crystal displays. Response times are shortened, color reproduction is improved, and users can now view the screen at virtually any angle.
Looking for the ultimate in fine-tuning for your LG monitor? This model is designed to work with compatible calibration devices* that take specific readings and guide you through precise adjustments of color, brightness and more.
Specification:-
- Screen Size Class (diagonal): 34"
- Panel Type: IPS
- Resolution: 3440x1440
- Color Gamut (CIE1931): sRGB 99%
- Brightness (typical): 320 cd/m2
- Contrast Ratio(Original): 1000:1
- Viewing Angle (CR>10): 178/178
- Colour Depth (Num of Colours): 1.07B (8-Bit+FRC)
- Pixel Pitch (mm): 0.2325
- Surface Treatment: Anti-Glare 3H
- Connectivity: 2x HDMI, 1x DisplayPort & 2x ThunderBolt
- Warranty: 2yr
Was [£769.99] Inc. VAT
Only £719.99 inc VAT.
ORDER NOW
All these deals end on Monday and pricing shall return to previous sold price, grab a great deal this Halloween weekend guys!
Some more Halloween deals for the weekend guys, check them out:
GIGABYTE P25X v2-CF2 Gamer 15.6" Full HD IPS Display, Intel Core i7-4710MQ, 16GB DDR3L, 2 x 256GB SSD & 1TB 7200TPM HDD, NVIDIA GTX880M 8192MB GDDR5 - Windows 8.1 @ £1,559.99 inc VAT
Unrivaled Performance with the all new Intel® Core™ Processor
Experience revolutionary battery life improvement, super-speed performance, ultra-fast image / graphics processing, and many other security protection capabilities with the Haswell platform 4th generation Intel® Core™ Processor. Built on the 22nm architectural process making use of the latest 3D Tri-Gate transistor technology allows for unrivaled performance.
Incredibly Powerful Gaming Discrete Graphics Revealed
Features a highest level NEW NVIDIA® GeForce® GTX 880M GDDR5 8GB graphics processor that supports NVIDIA® FXAA, Adaptive V-Sync technology! With the latest Ultra Boost technology you can easily choose the Extreme mode through an intuitive interface.
Vivid Visual Enjoyment with the 1080p Full HD IPS Matte Display
The 1080p Full HD matte display panel features a light scattering anti-glare layer, which diffuses light, eliminating reflections and delivering a sublime gaming experience. Adding IPS Wide Angle Display, it literally bring games to life from any direction you look at it
Electroluminescence Backlit Keyboard
The P25X epitomizes an automatic light sensing backlit keyboard. This significant feature adjusts the light to external conditions and makes typing and gaming in dimly lit rooms and dark conditions better and easier.
High Performance, Massive Storage System
The P25X is able to pack up to two mSATA 512GB SSD and 1 huge 1TB HDD. It provides massive storage options and delivers super fast performance of 1000MB/s and 850MB/s read/write rate for gamers with mSATA SSD super RAID 0 technology supported. Use the power of Raid 0 technology to your advantage for co-op or sharing games, giving gamers an experience like never before.
Dynamic Sound, Truly Amazing
The unique 4 Dual-channel Stereo Speakers are designed to provide dynamic and realistic sound effects, along with a subwoofer that boosts the deep, punchy bass. The result is a high-fidelity audio experience that is perfect for gaming and multimedia.
Rear Dual Air Vent Design Provides Effective Cooling
The P25W adopts a unique dual heat sink design with dual air vents (one for the CPU and the other for the GPU), increasing its gaming stability. The unique venting system is able to effectively keep the laptop from overheating despite the powerful features under the hood in this machine.
Specification
- Display: 15.6", 1920*1080 Full HD
- Processor Type: Intel Core i7 4710MQ
- Processor Cores: 4 (8 Threads)
- Processor Clock Speed: 2.40GHz (3.40GHz Turbo Mode)
- Hard Drive Supplied: 1 x 1000GB
- Hard Drive Size: 1000GB
- Solid State Drive: 256GB SSD x 2
- Hard Drive Speed: 7200RPM
- Memory Supplied: 2 x 8GB
- Memory Size: 16GB
- Memory Type: DDR3L
- Memory Speed: 1600
- Memory Socket: 2 x SO-DIMM
- Max. Memory Support: 16GB
- Operating System: Windows 8.1
- Graphics Chipset: NVIDIA GeForce GTX 880M
- Graphics Memory: 8GB GDDR 5
- Chipset: Intel HM87 Express
- Optical Drive: BluRay ReWritable Drive
- Microphone: Built-in
- LAN: 10/100/1000Mbps
- Wireless: 802.11 ac
- Bluetooth: v4.0
- USB 3.0 Port(s): 2
- eSATA/USB 2.0 Port(s): 1
- HDMI Port(s): 1
- VGA Port(s): 1
- Microphone Jack(s): 1
- Headphone Jack(s): 1
- LAN Port(s): 1
- Card Reader: SD
- Web Camera:1.0MP
- Keyboard: Backlight LED
- Dimension: 392 x 263 x 32.1~38.3mm
- Battery: Li-ion 8-cell, 5700mAh, 86.18Wh
- Product Weight (g): ~2.6Kgs
- Warranty: 2 Years
Was [£1799.99] Inc. VAT
Only £1,559.99 inc VAT.
ORDER NOW
MSI GS60 2QE-017UK, 15.6" 2880x1620 FHD Anti-Glare IPS Screen, Intel Core i7-4710HQ, 16GB DDR3, 1 x 128 M2 SSD RAID + 1TB 7200RPM HD, NVIDIA GTX 970M 3GB GDDR5 - Windows 8.1 @ £1,499.99 inc VAT
NVIDIA GTX 970M: Insanely Powerful. Discrete Graphics Card with GDDR5 6GB VRAM
The NVIDIA Geforce GTX 970M Series brings extreme, next-generation graphics performance to serious gaming notebooks. As the first graphics solution to reach a score of over 9,000 in 3DMark 11, the GeForce GTX 970M delivers extremely fast and fluid gameplay at the highest settings and resolutions in a lightweight and portable design.
The NVIDIA GTX 970 scored 28.2% higher than a GTX 870M GPU & 8.3% higher than the GTX 880M GPU in 3DMark 11.
Mega Storage & Speed with SUPER RAID 2
Unlock stunning graphics, silky-smooth motion, and higher frame rates on the go with innovative twin SSD in M.2 form factor. New M.2 SATA interface substantially minimizes access time, guaranteeing seamless gaming. Super RAID 2 design gives the storage performance up to 1500MB/s reading performance on MSI GS series, the reading, writing and saving speeds is 15x faster than a single 1TB 7200rpm HDD. And one more HDD can be installed in the same laptop without the need to expand the size to put recovery system, to backup and put more data.
The latest 4th generation Intel® Core™ i7 Processor
The latest 4th generation quad core processor platform, representing superior performance over previous generations. The CPU performance has increased by 3%~7%, while the overall platform is 15% more powerful. Additionally, the GPU performance of 2d and 3D visuals, is even more noteworthy, with an average increase of over 30%. There have also been significant advances in user experience and battery life. Moreover, it employs a more advanced encryption program to help businesses enhance information security and to protect your BIOS/FW from attacks by malware.
3K Display
3K wide-view LCD display takes image clarity to a whole new level with higher pixel resolution. Compare to full HD LCD display, the images are amazingly much more sharp and vivid with 40% more contrast level and 40% more brightness level than regular TN panel. When you're playing games, you will have breathtaking and brilliantly true-to-life viewing experience.
Matrix Display
Matrix display features up to 2 external displays, allowing you to output to 3 displays simultaneously using HDMI 1.4, mini Display-Port 1.2 and VGA port. Users can work with multi-task at the same time. (Overall 3 monitors include notebook's monitor on GS series).
Killer LAN: Zero Latency Is the only way in GAMING
The benefit of the Killer Gaming LAN is the "Advanced Game Detect™" technology, which recognizes online game data packs and processes them first, accelerating them in the process. The best weapon against stuttering characters, freeze-ups, and lagging, it vastly improves all the online experience. Whether FPS or MMO gaming, you'll have that advantage to response faster to get victorious.
802.11ac: 45% - 70% faster than regular 802.11n
802.11ac, the next generation of wireless, promises intensified signals and more stable connections. Experience wireless gaming like never before! Enjoy stronger throughput, extended coverage, less speed decline, and above all, freedom to play anywhere with your MSI GT70.
SteelSeries Engine
SteelSeries Engine is the App to combine all frequent functions for gamers in order to easily customize every individual key and functions to personalize every gamer's play style, including KLM, multiple devices management (for example, headset, mouse, and keyboard), key press macros, and text macros.
Friendly UI design
The SteelSeries Engine is easy to understand by using pictorial representations of devices along with basic drag-and-drop techniques to assign key presses, complex macros, device profiles and buttons. Also features intuitive macro creation with customizable colors, fonts, and names for everything.
4 keyboard layers options!!
There are 4 layers for gamers to set 4 usage scenario or game. Not only that, while playing the game, gamers can easily and quickly switch layer*, such as a chat screen with friends. Communication with friends is not interrupted!!
Intelligent keypress macro capabilities
There are virtually unlimited key press macro creation capabilities. Anything you can do on a mouse or a keyboard can be programmed along with specific event timing. You can even program mouse events into keyboard macros. Your macros will be running at a high priority in your computers Operating System, yet it does NOT interfere with your real time actions during gameplay.
KLM (Keyboard light management)
Depending on your mood and desires, you can choose from more than 1,000 color combinations and five different scenario modes for the keyboard, enabling you to be the coolest gamer at any LAN party!
Statistics to analyze and improve
Whether you're playing an FPS or editing in Photoshop, being better and more efficient is something we want to help you achieve. Use the Statistics module to record your keyboard or mouse actions. Then review the peripheral heat map, which shows with both color and numbers the frequency of your key or button presses. You can then use this information to fine tune your macros as well as your key and mouse button assignments to optimize your tools to play (and work).
Sound by Dynaudio
MSI worked with Dynaudio, world-class name in sound system design from Denmark, studying electrical circuits, dozens of speaker drivers, and how to best arrange internal parts and components to optimize sound. For over a year, they tweaked the sound and developed electrical circuits and materials with the best sound response. The results of their studies have been incorporated into MSI's high-end GT Series gaming NBs--the laptops with the best stereo sound in the industry. The GT Series, the only laptops in the industry with a Dynaudio sound system, clearly leads the industry not simply in terms of volume, but also in terms of stereo and crisp, clear sound for a more enjoyable gaming and multimedia experience.
Windows Start button
On the SteelSeries keyboard there is a change to the usual keyboard layout, the CTRL key is moved to the left of the keyboard and has been made larger as this is an important key for gamers and is now more accessible. The windows key has moved to the right of the keyboard so while your gaming you don't press it by accident, so now you won't quit your game in the middle of a battle!
Product Specification:
- Product Code: GS60 2QE(Ghost Pro 3K)-017K
- OS: Windows 8.1
- CPU: Sharkbay Core i7-4710MQ (2.5GHz - 3.5GHz)
- Display: 15.6" 3K (2880x1620) wide-view IPS LCD Display
- Max Memory Support: 16GB
- Graphics Chipset: NVIDIA GeForce GTX970M
- Graphics Memory: GDDR5 3GB
- Storage: 1 x 128GB M.2 SSD + 1TB 7200RPM
- Keyboard Type: SteelSeries FULL back lit keyboard with SteelSeries Engine
- USB3.0 Ports: 3
- HDMI Port(s): 1
- Mini Display port(s): 1
- LAN Port(s): 1
- Headphone Jack(s) (SPDIF): 1
- Card Reader: SD
- Audio: -Sound by Dynaudio
- LAN: Killer™ E2200 Game Networking LAN
- Wireless: 802.11ac
- Bluetooth: V4.0
- Webcam: FHD Camera 1080p
- Security: Kensington Lock
- Battery: 6-Cell Li-Polymer(4840mAh 52Wh)
- Dimension: 390 X 256 X 19.9
- Weight: 1.96Kg (With Battery)
- Warranty : 2 YR's Collect & Return (1 YR Global)
Was [£1559.99] Inc. VAT
Only £1,499.99 inc VAT.
ORDER NOW
Kingston Predator 16GB (4x4GB) DDR4 PC4-24000C15 3000MHz Quad Channel Kit - Black (HX430C15PB2K4/16) @ £239.99 inc VAT
Kingston Predator DDR4 is some of the most aggressive looking DDR4 available and looks menacing. Make your opponents fear you with Kingston Predator DDR4.
Specification:-
- CPU Compatibility: Intel Haswell-E ( LGA 2011-3 )
- Chipset: Intel X99
- Capacity: 16GB (4GBx4)
- Quad Channel kit: Yes
- Tested Speed: DDR4-3000 MHz (PC4-24000)
- Tested Latency: 15-16-16-36
- Tested Voltage: 1.25V-1.45V
- Registered/Unbuffered: Unbuffered
- Error Checking: Non-ECC
- Type: 288-pin UDIMM
- SPD Speed: 2133 MHz
- SPD Voltage: 1.2V
- Features: Intel XMP 2.0(Extreme Memory Profile)Ready
- Warranty: Lifetime
Was [£269.99] Inc. VAT
Only £239.99 inc VAT.
ORDER NOW
TeamGroup Elite 32GB (4x8GB) DDR4 PC4-19200C16 2400MHz Quad Channel Kit - Black (TPKD432GM2400HC16QC01) @ £337.99 inc VAT
TeamGroup Elite DDR4 offers great value and great performance with superb looks with all black PCB and heatspreader design,.
Specification:-
- Capacity: 32GB (8GBx4)
- Tested Speed: DDR4-2400 MHz (PC4-19200)
- Tested Latency: 16-16-16-36
- Tested Voltage: 1.2V
- SPD Voltage: 1.2V
Was [£359.99] Inc. VAT
Only £337.99 inc VAT.
ORDER NOW
TeamGroup Elite Black 8GB (2x4GB) DDR3 PC3-12800C11 1600MHz Dual Channel Kit (TPKD38G1600HC11DC01) @ £53.99 inc VAT
Keeping abreast with the latest trend to launch new products to replace the old, Team Group is now offering a new choice of superb value expansion with its ELITE DDR3. ELITE DDR3 features outstanding product quality that users have come to expect from Team Group and the product has also passed the strictest tests for quality assurance. Not only that, Team Group’s ELITE DDR3 is manufactured with full compliance to the specifications prescribed by JEDEC (Joint Electron Device Engineering Council) and has gone through extensive burn-in tests. ELITE DDR3 features standard 240 Pin design and operates on 1.5V of power to achieve low power consumption with a truly eco-friendly specification. In addition, TEAM ELITE also comes in a variety of selections with varying frequencies and capacities to satisfy consumers with different needs.
Features:-
- Module Type 240Pin L-DIMM 1600
- CL-tRCD-tRP-tRAS 11-11-11-28
- DRAM Density 256x8 / 512x8
- Data transfer bandwidth 12,800MB/Sec (PC3 12,800)
- Heat Sink Aluminum heat-sink
- Working voltage 1.5V± 0.075V
- Warranty Lifetime warranty
Was [£59.99] Inc. VAT
Only £53.99 inc VAT.
ORDER NOW
TeamGroup Elite Black 16GB (2x8GB) DDR3 PC3-12800C11 1600MHz Dual Channel Kit (TPKD316G1600HC11DC01) @ £99.95 inc VAT
Features:-
Was [£119.99] Inc. VAT
Only £99.95 inc VAT.
ORDER NOW
Sapphire AMD Radeon R9 295 X2 8192MB GDDR5 PCI-Express Graphics Card @ £599.99 inc VAT
No matter what the game or the resolution you can now select the maximum settings even at 4k resolution and enjoy fluid ultimate smooth framerates in latest games such as Titanfall, Diablo 3, Watchdogs and even potential upcoming games such as GTA V and Half Life 3 should they surface.
Featuring a pair of 290X Hawaii GPU's fused onto a single PCB with an advanced PLX chip along with only requiring 2x 8-Pin power connectors.
The other major feature of the 295 X2 is its cooling solution which truly does keep the cards temperatures around 60c even after gaming for hours and it also manages to do this in more or less silence with zero throttling of the cores themselves. Making it one of the smoothest, quietest and easily most powerful graphics card on the market today. If you really crave the most powerful and have or are considering a 4k monitor for gaming then the 295 X2 is the card for you.
If your demands are truly the most powerful experience possible then these cards work great in Crossfire (4 GPU's) and you will be able to smash benchmarks to pieces and have no slow downs in games.
Specification:-
- GPU: 2x Hawaii XT
- Hybrid Liquid Cooling
- Litecoin Hash Rate: 1600-2000
- Stream Processors: 5632
- ROPS: 128
- Core Speed: 1018MHz
- Memory Speed: 5000Mhz
- Memory interface: 1024-Bit (2x 512-Bit)
- Memory capacity: 8192MB GDDR5
- PCI-Express X16 lane required
- 850W or greater PSU required with genuine 8-Pin PCI-E cables such as Silverstone 1500W
- Case capable of fitting such a long card and support for a 120mm radiator
- Dimensions: Card is 307x111x65mm and Cooler is 153x120x63mm
- Power Connectors: 2x 8-pin
- Display Outputs: 1x Dual Link DVI, 4x Mini-DisplayPort
- Warranty: 2yr
Was [£659.99] Inc. VAT
Only £599.99 inc VAT.
ORDER NOW
XFX Radeon R9 290 DD 4096MB GDDR5 PCI-Express Graphics Card (R9-290A-EDFD) @ £229.99 inc VAT
AMD Radeon R9 290 is a new graphics card powered by the latest AMD Radeon™ R9 290 graphics-processing unit (GPU). 4GB of super-fast GDDR5 memory for the best gaming experience at the highest resolutions including 4k and incorporates AMD Eyefinity and TrueAudio technologies to enable expansive multi-display setups and more accurate environmental sounds. R9 290 also includes support for both DirectX® 11.2 and AMD's new Mantle application programming interface (API) for great handling of even the most-demanding PC games.
OcUK has negotiated special RMA terms with XFX which allows OcUK to express RMA any XFX item purchased from ourselves within 48 hours. Also exclusive to OcUK we allow the removal of the stock cooler for those wishing to water-cool their XFX product or change the cooler.
Specification:-
- GPU: Hawaii Pro
- Stream Processors: 2560
- ROPS: 64
- Core Speed: 947MHz
- Memory interface: 512-Bit
- Memory capacity: 4096MB GDDR5
- 600W or greater PSU required
- Power Connectors: 8-pin + 6-pin required
- Display Outputs: 2x Dual Link DVI, 1x HDMI, 1x DisplayPort
- Card Dimension (cm) : 29.5 x 14.3 x 4.2
- Card Dimension (inch) : 11.61 x 5.63 x 1.65
- Warranty: 2yr
Was [£229.99] Inc. VAT
Only £199.99 inc VAT - WITH VOUCHER CODE XFX290PROMO
ORDER NOW
Sapphire Radeon R9 280 Dual-X 3072MB GDDR5 PCI-Express Graphics Card @ £149.99 inc VAT
With 3GB of the latest GDDR5 memory and 1792 stream processors, and support for DirectX 11.2, the architecture is built to play the very latest games with perfectly smooth action even at higher resolutions such as 2560 x 1440. In fact its Ultra HD graphics processor can feed even the latest 4K displays with the HDMI 1.4a interface. The R9 280 family represents a breakthrough in cost
erformance.Specification:-
- Litecoin Hash Rate: 500-700
- PCI-E 3.0 Ready: Delivers double the bandwidth per lane of PCIe GEN2 for faster GPU- CPU
- Hugely overclockable
- Core Clock Speed: 850MHz
- Boost Clock Speed: 940MHz
- Shader Architecture: GCN
- Stream Processors: 1792
- Texture Units: 128
- ROPS / Z-Stencil: 32 / 128
- Frame Buffer / Memory: 3GB GDDR5
- Memory Width / Speed: 384 bit / 5000MHz
- Display Outputs: 2x DVI + 1x DP + 1x HDMI
- Power: 250W TDP
- 2yr Warranty
Was [£187.99] Inc. VAT
Only £149.99 inc VAT.
ORDER NOW
Powercolor Radeon R9 280X TurboDUO 3072MB GDDR5 PCI-Express Graphics Card @ £179.99 inc VAT
Powercolor R9 280X has the performance to power the latest games with ease but at a very aggressive price point making it incredible value for money.
Equipped with TurboDUO near silent cooling solution meaning you can game in near silence whilst keeping the card nice and cool.
Features:-
- Multi Phase Design: 8 Power Phases for improved OC ability
- Digital PWM
- Ferrite Core Choke: Decreases ripple to deliver more stable voltage
- DirectFET
- Patent GSG- Shape Heat Pipes Design: Reduces temperatures by upto 17% and noise reduction of upto 19%
- Pure Copper Base
- Backplate included
Specification:-
- Litecoin Hash Rate: 550-750
- Core Clock Speed: 880MHz
- Boost Clock Speed: 1030MHz
- Stream Processors: 32 CU / 2048 ALU
- Memory Width / Speed: 384 bit / 6000MHz
- Display Outputs: 1x DVI + 1x DP + 1x HDMI
- Power: 250W TDP
- 2yr Warranty
Was [£199.99] Inc. VAT
Only £179.99 inc VAT.
ORDER NOW
MSI GeForce GTX 760 OC Gaming Edition 2048MB GDDR5 PCI-Express Graphics Card @ £149.99 inc VAT
GeForce® GTX 760 is the new weapon of choice for gamers—a powerful graphics card that gives you fast, smooth, quiet performance in all your favorite titles. It’s packed with next-gen technology innovations, engineering, and features that let you crank up the settings and resolutions in graphics-intensive games like Splinter Cell: Blacklist.
Take hyper-realistic gameplay to a whole new level with NVIDIA GPU Boost 2.0 for max clock speeds, PhysX® and TXAA™ for great graphics, and NVIDIA® SHIELD™ compatibility for incredible portable gaming. Plus, instantly access the latest game-ready drivers automatically—the day a game launches—and optimize settings with one click using GeForce Experience™. Even auto-record all your greatest gaming moments with NVIDIA ShadowPlay.
Specification:
- Core Clock: 1085MHz (GK104)
- Core Boost Clock: 1150MHz
- Memory: 2048MB GDDR5
- Memory Clock: 6008MHz (Effective)
- Memory Interface: 256-Bit
- Processing Cores: 1152
- Shader Clock: 2116MHz
- Bus Type: PCI-Express GEN 3.0 (Backwards compatible)
- Display Connectors: 2x Dual-Link DVI-I, 1x HDMI 1.4a 1x Displayport
- SLI Ready (Upto 3-Way SLI Supported)
- HDCP Capable
- DirectX 11 Support
- OpenGL 4.0 Support
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- NVIDIA Surround Enabled
- Lower power consumption (Maximum consumption 170 watts at stock speed)
- 1x 8-pin & 1x 6-Pin PCI-E Connectors required
- Winner of CustomPC Premium Grade AWARD with 93% overall score!
- Warranty: 3 Years
Was [£169.99] Inc. VAT
ORDER NOW
BenQ DL2215 21.5" Widescreen LED Monitor - Black @ £79.99 inc VAT
Whether you're catching up on the latest show on the Internet or viewing documents, the BenQ DL2215 LED monitor is the perfect choice for you in style! Featuring aspect ratio 16:9 and 100% dot-to-dot image quality, this 21.5"W LED monitor delivers every image detail with the best viewing quality.
- Screen Size: 21.5"W
- Aspect Ratio: 16:9
- Resolution (max.): 1920x1080
- Pixel Pitch (mm) 0.248
- Brightness ( typ.) 200 cd/m²
- Native Contrast ( typ. ) 600:1
- Panel Type TN
- Viewing Angle (L/R;U/D) (CR>=10) 90°/65°
- Response Time(Tr+Tf) typ. 5ms
- Display Colors 16.7million
- Color Gamut 72% NTSC
- Input Connector D-Sub/ DVI
- Power Supply (90~264 AC) Built-in
- Power Consumption (On mode) 20.7W
- Dimensions(HxWxD mm) 369 x 515 x 178
- Net Weight (kg) 2.8kg
- Gross Weight (kg) 3.9kg
Was [£85.99] Inc. VAT
Only £79.99 inc VAT.
ORDER NOW
BenQ VW2245Z 21.5" Widescreen LED Flicker-Free Slim Bezel Monitor - Black @ £79.99 inc VAT
Simply elegant and stylish, the Ultra Slim V40 Series is a perfect combination of aesthetics and technology that adds a touch of subtle splendor and sophisticated minimalism to your modern home décor.
The BenQ V40 Series Monitors, with the ultra-slim sleek design,deliver rich and exquisite visual performance that please your eyes. A masterpiece that is truly beautiful from inside out.
The Flicker-free technology eliminates flickering at all brightness levels and effectively reducing eye fatigue. Conventional LCD screens flicks 200 times per second. Your eyes may not see flickers, but can certainly feel them. Free your eyes from flickers by switching to Flicker-free Monitors and let your eyes do less work. The Reading Mode recreates the comfortable experience of reading actual books by adjusting the monitor's color temperature and brightness, as well as balancing its contrast ratio and sharpness, to simulate the look of paperback paper.
Experience the truest colors of the world with the BenQ Senseye® Human Vision Technology. With the help of its six proprietary calibration techniques, Senseye® 3 delivers only the best viewing quality in each of its pre-set viewing modes – Standard, Movie, Game, Photo, sRGB, Reading, M-book and ECO – with the ECO Mode especially design to save power and money.
Specification:-
- Back Light Unit LED
- LCD Size 21.5"W
- Aspect Ratio 16:9
- Resolution (max.) 1920 x 1080
- Display Area(mm) 476.64 x 268.11
- Brightness ( typ.) 250 cd/m²
- Native Contrast ( typ. ) 3000:1
- DCR (Dynamic Contrast Ratio) (typ.) 20M:1
- Panel Type VA
- Viewing Angle (L/R;U/D) (CR>=10) 178°/178°
- Response Time(Tr+Tf) typ. 25ms, 6ms (GTG)
- Connectivity: 1x DVI, 1x Analogue
- Warranty: 2yr
Was [£89.99] Inc. VAT
ORDER NOW
LG 22MP65HQ-P 22" LED IPS HDMI Monitor - Black @ £99.95 inc VAT
CINEMA SCREEN design delivers an incredibly immersive viewing experience. This artistic narrow bezel is now much slimmer. LG IPS Monitor features consistency and less changes in colour temperature, it realize a colour impression identical to its original image. Smooth colour change allows you to enjoy any content, such as action movies, web surfing and RPG games for a long time in comfort. Experts have conducted colour calibration tests at the production line for accurate colour. LG IPS Monitor provides the most accurate and lifelike colour for your advanced viewing pleasure. By reducing blue light to protect your eyes, Reader Mode provides optimal condition for reading. With just a touch of a button, you can comfortably read on the monitor for longer periods of time without straining your eyes. LG Monitor TV allows you to enjoy lifelike picture quality without any colour shift whether you are standing or lying down. SUPER+ Resolution technology helps to detect rough edges and blurring in contents when enlarged, offering improved quality with a better sense of high resolution.
Features:
- IPS Monitor
- Minimalistic Design with Cinema Screen
- Reader Mode
- Flicker-safe
Specification:-
- Screen Size: 22 in
- Viewable screen size: 21.5 in
- Screen technology: In Plane Switching (IPS)
- Colours: 16.7 Million
- Pixel Pitch: 0.24795 mm
- Brightness: 250 cd/m2
- View Angle: (Horizontal - Max) 178 °
- View Angle: (Vertical - Max) 178 °
- Anti-Glare / Anti-Static: Anti-glare 3H
- Contrast Ratio - Dynamic: 5,000,000:1
- Response time: 5 ms
- Tilt (Forward/Backward): -5 to +20 °
- Resolution (Native): 1920 x 1080 Pixels
- Resolution Type (Native): Full HD
- HD Support: Yes
- Connectivity: 1x HDMI, 1x VGA
- Warranty: 2yr
Was [£109.99] Inc. VAT
ORDER NOW
AOC G2460PQU 24" Widescreen 144Hz 1ms Gaming LED Monitor - Gunmetal @ £181.99 inc VAT
This display will make any gaming enthusiast´s heart beat faster: the stylish g2460Pqu will impress you with crystal-clear pictures. Enjoy fast-paced action sequences from the latest games or movies – crisp and blur-free due to an ultra-fast response time of just one millisecond and a refresh rate of 144 Hz. The strong typical contrast (1000:1) and high brightness (350 cd/m²) provide brilliant images. This gamers´ dream-come-true sports numerous connectivity options, such as D-Sub, DVI Dual Link, HDMI, DisplayPort and an integrated USB hub. These enable you to comfortably plug in several devices at the same time and display hi-res content on the large 61 cm (24") screen. Also on board: an integrated USB hub with 4 ports, including a fast-charge USB port for mobile devices. In addition, the Full HD display is equipped with LED backlights, making it particularly economical despite its great performance.
Product Review
- Won Kitguru "Worth Buying" Award
- Full Review Here: http://www.kitguru.net/peripherals/monitors/zardon/aoc-g2460pqu-144hz-24-inch-monitor-review/
Specification:-
- Height Adjust Stand
- USB Hub
- Monitor Size: 24"
- Visible Screen Size: 61 cm
- Screen Format: 16:9
- Brightness: 350 cd/m² (typ)
- Contrast Ratio Dynamic: 80.000.000:1
- Contrast Ratio Typical: 1000:1
- Pixel / Dot / Pitch: 0.276 (H) x 0.276 (V)
- Display Area: 531.36 (H) x 298.89 (V)
- Viewing Angle: 170°/160° (CR 10)
- Response Time: Up to 1 ms GtG
- Maximum Resolution: 1920 x 1080@144 Hz (DVI Port)
- Recommend Resolution: 1920 x 1080@144 Hz
- Colors: 16.7 M
- HDCP compatible: yes
- Inputs: Analogue, DVI-D, HDMI & DisplayPort
- Dimensions (WxHxD): 565.4 x 393.6 (+130) x 244.58 mm
- Warranty: 3yr
Only £181.99 inc VAT.
ORDER NOW
BenQ RL2455HM 24" Widescreen LED Monitor - Black/Red @ £129.95 inc VAT
The RL2455HM is a professional gaming monitor suited for RTS game play. This 24¨W LED monitor is packed with the latest features: the Black eQualizer, RTS Mode, Display Mode, Smart Scaling, 1ms GTG, HDMI and 12M:1 dynamic contrast ratio.
Poor visibility in dark scenes can cost even the most skillful gamers their game. The Black eQualizer color engine technology is designed to offer an unprecedented level of control and visibility. Dark scenes are brightened without over-exposing the bright areas to preserve vital details, enabling gamers to spot their enemies easily in critical combat and react quickly in any situation.
Every feature and function of the rl2455HM was meticulously throught out to provide RTS gamers with vital visibility and command to achieve peak performance. This out-of- the-box preset automatically fine-tunes your monitor accordingly for optimum RTS gaming, allowing you to see your enemies more visibly among the distractions and darkened areas. Built to give you the competitive edge, the exclusive RTS Mode will be your ultimate secret weapon. Now, we offer the two modes for players options: the RTS 1 mode for StarCraft II and the RTS 2 for Dota II. The exclusive preset RTS Mode will be your ultimate secret weapon.
The Display Mode and Smart Scaling features allow you to change the monitor view to suit your liking and to simulate any in-game experience.
Interchange instantly between four different screen sizes from 17", 19" and 19"W, 21.5"W, 22"W, 23"W to 24"W using the Display Mode. Or take advantage of the Smart Scaling feature and enjoy the flexibility to freely scale the screen content to any custom size. You can certainly use the two features together to get the best possible view for any application or game.
Fast response time of 1ms GTG means speed without the smear. Fast-moving action and dramatic transitions will be rendered smoothly - without smearing or ghosting. Control your gaming destiny and don't leave it in the hands of slow display.
Specification:-
- Screen Size: 24"W, TN LED
- Resolution (max.): 1920 x 1080
- Pixel Pitch: 0.276 mm
- Contrast Ratio: 1000:1
- DCR: 12M:1
- Response Time: 1 ms GTG
- Display Color: 16.7 million
- Viewing Angle (L/R;U/D) (CR>=10): 170 / 160
- Terminals: D-sub / DVI-D / HDMI x2 / Headphone jack / Line in
- TN LED Technology
- Senseye® Human Vision Technology (plus Senseye 3)
- Black eQualizer
- Advanced Motion Accelerator (AMA)
- HDCP Support
- Speaker: 1W x2
- VESA Wall Mounting (mm): 100 x 100 mm
- K Locker: Yes
- Warranty: 2yr
Was [£149.99] Inc. VAT
Only £129.95 inc VAT.
ORDER NOW
BenQ XL2420Z 24" TRUE 144Hz 3D Vision 2.0 Widescreen LED Monitor - Black/Red /w Flicker FREE Technology @ £259.99 inc VAT
A gaming monitor that gives you no excuse to lose – the 24-inch XL2420Z brings fluidity with perfect motion and an unprecedented level of control to help you conquer any enemy in FPS gaming. The BenQ monitor is built with the latest Motion Blur Reduction technology , Low Blue Light, Gaming-comfort Flicker-free, Gaming Refresh rate Optimization Management (GROM), and Display Pilot feature, offering agile performance, viewing comfort and convenience in one package! With the XL2420Z, you’ll be up for any challenge coming your way!
For a long time, the refresh rate of regular LCD displays has always been the key factor that puts professional gamers off from switching their CRT screens. Now, with BenQ’s new Motion Blur Reduction technology, gamers can finally set their mind at ease! Following is a simulated in-game video, you will see how BenQ Motion Blur Reduction helps you aim down targets with more precision comparing to the screen without.
Practice long hours with clear, comfortable vision or compete with top-notch vision condition with BenQ’s new Low Blue Light. The blue spectrum light, which is produced by regular computer screens, is a critical cause of eye damage, eyestrain, headaches and sleeping disorders. Now with the offering of various adjustable low blue light levels, gamers can better protect their eyes. So there would be no need for yellow tinted eyeglasses for additional eye protection, and gameplay can be clear, comfortable and hassle-free!
Developed in collaboration with pro gamers, the XL2420Z has been upgraded to eliminate flickering at all brightness levels. This effectively reduces eye fatigue and elevates gaming performance through extreme visual comfort for even the most hardcore gamers enrolling long hours in action. Armed with the Gaming-comfort Flicker-free Technology, the BenQ Gaming Monitor is an epic weapon over your ultimate rivals.
As the world’s leading brand in gaming monitor, BenQ has managed to provide more than just refresh rate feature when having different resolutions reaching more levels of optimal refresh rates(100/120/144Hz) with Gaming Refresh-rate Optimization Management (GROM), thus bring to users the scenario of incomparable gaming performance. With gamer-driven GROM which is collaborating with Display Mode and Smart Scaling strengths, BenQ offers a total solution on refresh rate for gaming enthusiasts.
The secret is out. Download special gaming preset calibrations used by well-known gamers so you can see what the pros see. Each mode is fine-tuned, so you can steal these exclusive presets used by pro gamers to your own advantage. You can even save your favorites on the S Switch for quick access and game play. More presets will be released in the future to keep you on top of your game.
The newly upgraded Display Pilot function allows users to make all the on-screen display adjustments, plus provides them with direct access to the Game Mode Loader feature for downloading and installing the preset display settings of their favorite game or professional gamer’s screen instantly.
Poor visibility and judgment can cost even the most skillful gamers their game. The Black eQualizer color engine technology is designed to offer an unprecedented level of control and visibility.
Fast response time of 1ms GTG means speed without the smear for an enhanced gaming experience. Fast-moving action and dramatic transitions will be rendered smoothly without the annoying effects of smearing or ghosting. Control your gaming destiny and don’t leave it in the hands of slow display.
The S Switch is a distinct remote controller that comes with three preset buttons, so you’re able to customize and save your display settings for gaming, work or entertainment purposes. It eliminates the tedious process of adjusting your monitor calibrations, so switching between the presets is as easy as 1-2-3. The S Switch also comes with a scroll button for quick OSD navigation and setting.
The newly designed OSD includes physical touch keys that enable you to conveniently change your settings in an intuitive horizontal slide-out display. This simplistic design makes it easier to navigate between options and settings.
The Display Mode and Smart Scaling features allow you to change the monitor view to suit your preference and to simulate any in-game experience. Using the Display Mode function, the monitor can be easily changed between 7different screen sizes, from 17”, 19”, 19”W, 21.5”, 22”W, 23”W and 24”W.
If you’re looking to customize your screen size further, you can also take advantage of the Smart Scaling feature. The Smart Scaling feature gives you the flexibility to freely scale the screen content to any custom size. With just one monitor, you can simulate any game play and practice under different display sizes for tournaments. Use the Display Mode and Smart Scaling together to get the possible view for any application or game.
The Height Adjustment Stand can be operated with just one finger so you can effortlessly adjust the height of the monitor to suit your sight level. Have the monitor way up high, or change it to sit flat on the table. The monitor can also be turned vertically or horizontally and comes with a quick-release VESA mount design. In addition, the sleek headphones hook at the back keeps your desk top neat and tidy.
Meet your secret winning strategy. The FPS Mode was co-developed with gaming legends to let you tap into the fundamental insights of pro gamers and view the game how a gaming legend would see it. This out-of-the-box preset automatically adjusts your monitor calibrations to provide you with optimal brightness, contrast, sharpness and color tint. Being able to spot your enemies and track their move carefully in every situation put you at an advantage over your opponents.There are two variations to this special mode: the FPS1 mode is designed to configure and optimize the display for Counter-Strike 1.6 and the FPS2 mode for Counter-Strike Source as recommended by BenQ. The perfect combination of form and function provides gamers with the vantage point to always be one step ahead of the game.
Certified as NVIDIA® 3D Vision™ 2-ready with the new NVIDIA 3D LightBoost™ technology to provide you with brighter and clearer 3D images. Now you can experience gaming and entertainment like never before with total realism and intensive 3D graphic display.
Specification:-
- Back Light Unit: LED
- LCD Size: 24"W
- Vertical Refresh Rate: 100 / 120 / 144Hz
- Resolution (max.): 1920 × 1080
- Display Area(mm): 531 x 298
- Pixel Pitch (mm): 0.276
- Brightness (typ.): 350 cd/m
- Contrast (typ.): 1000:1
- DCR (typ.): (Dynamic Contrast Ratio): 12M:1
- Panel Type: TN
- Viewing Angle: (L/R;U/D) (CR>=10): 170° / 160°
- Response Time: (Tr+Tf) typ. 1ms (GTG)
- Display Colors: 16.7 million
- Color Gamut: 72% NTSC
- Input / Output Connector: D-sub / DVI-DL(Dual-Link) / HDMIx2 / DP1.2 / Headphone jack
- Power Supply: (90~264 AC) Built-in
- Power Consumption: (Base on Energy star ): 24W
- (Power saving mode): 0.5W
- Kensington Lock: Yes
- Dimensions: (HxWxD mm) 516 x 571 x 149
- Net Weight (kg): 6.1
- Motion Blur Reduction: Yes
- Low Blue Light: Yes (10 levels)
- Black eQualizer: Yes
- Game Mode Loader: Yes
- Display Mode: 17" / 19" / 19"W / 21.5"W / 22"W / 23"W / 24"W
- Smart Scaling: Yes
- FPS / RTS Mode: Yes / Yes
- Flicker-free Technology: Yes
- Display Pilot: Yes
- Senseye: Senseye 3
- AMA: Yes
- Win7: Yes
- Win8: Yes
- Height Adjustment: Stand (mm) 130(adjustable down to the base)
- Warranty: 2yr
Only £259.99 inc VAT.
ORDER NOW
BenQ XL2430T 24" TRUE 144Hz Widescreen LED Monitor - Black/Red /w Flicker FREE Technology @ £275.99 inc VAT
BenQ’s new Motion Blur Reduction technology further enhances an ultra-smooth, free-of-blur gaming experience, particularly for action-packed FPS games where every millisecond count. With Motion Blur Reduction, gamers no longer suffer from time and gaming comfort lost to poor vision quality created by motion blur and lagging. Instead, they have everything to gain with more reaction time advantage on their side to achieve ultimately a flawless victory.
Fast response time of 1ms GTG means speed without the smear for an enhanced gaming experience. Fast-moving action and dramatic transitions will be rendered smoothly without the annoying effects of smearing or ghosting. Control your gaming destiny and don't leave it in the hands of slow display.
As the world’s leading brand in gaming monitor, BenQ manages to provide more than just the refresh rate feature for different resolutions to reach more levels of optimal refresh rates (100/120/144Hz) with Gaming Refresh rate Optimization Management (GROM), which aims to bring users the incomparable gaming performance. With the gamer-driven GROM that collaborates with Display Mode and Smart Scaling strengths, BenQ offers a total refresh rate solution for gaming enthusiasts.
It is absolutely vital that the XL2430T give you the flexibility you need to get the color performance you seek. This is why BenQ built into the monitor 20 levels of Color Vibrance setting to meet gamers’ specific viewing requirements and preferences for all types of gameplay. This unique feature is accessible via On Screen Display (OSD) or Display Pilot for added convenience.
To ensure that gamers can duplicate the exact same monitor set-up with the highest accuracy, efficiency and convenience, BenQ made a few additions to the XL2430T’s Adjustment Scale Design. The adjustable height stand is now scaled with 14 height levels trackable by a moving marker. Trackable scales are also added to the screen, which tilts forward and backward to 0°, 10° and 20v, and swivels left and right to a wide range of angles. Every XL2430T can be your personal XL2430T.
The newly improved Black eQualizer Dynamic color engine technology takes visibility optimization to a whole new level with automatic brightness adjustments. The XL2430T is able to detect the input source and automatically fine-tune the amount of brightness enhancement within the range of the brightness level selected by the user. Now, gamers can spot their enemies in critical combat effortlessly and react to any situation quickly without having to lift a finger for manual adjustments.
The secret is out. Download special gaming presets used by the professional players so you can see what the pros see. Each mode is fine-tuned so you can leverage these exclusive presets used by pro gamers to your own advantage. They can also be saved on your S Switch for quick access and game play. More presets from professional gamers will be released in the future so you can always stay on top of your game.
The Auto Game Mode enables the XL2430T to detect the genre of the game being played and switch the display setting to the corresponding game mode automatically. It is also designed to make new game mode recommendations for download. This unique feature is accessible through the On Screen Display (OSD) setting as well as the Display Pilot software or the S Switch Arc that has a quick key built in for this mode.
To save gamers the hassle of having to re-download and reset game modes, the XL2430T allows gamers to store game modes onto a USB flash drive for easy and simple carriage. They can also share their own game modes with everyone via cloud storage or social media platforms. This innovative feature allows gaming communities to share, collaborate and bond freely with ease.
The S Switch Arc is an external controller that comes with preset buttons that can be customized with personal display settings for gaming, work or entertainment use. The S Switch Arc not only sports a quick key for the Auto Game Mode but also a rounder look for a more natural and comfortable grip that enables gamers to best navigate between game modes.
Sporting the latest angular, compact base that aligns perfectly parallel to the desk surface and a monitor stand meticulously placed in golden ratio to counter balance the display, the next-generation base stand design offers a new level of stability for the steadiest gameplay – with stringent swivel and shock testing results to prove it. Additionally, the reduced width and depth further shortens the distance between the keyboard and the monitor, bringing you closer than ever to the game.
The aluminum alloy coated monitor stand sends off a sophisticated yet mysterious metallic appeal that conjures up the majesty of the game. On top of that, it is ergonomically optimized with a widened and thickened top handle that’s comfortable to grip, making the monitor much easier to carry from one place to another.
Placing a retractable headphone hook on the left side of the monitor display conveniently puts your headphones within arm’s reach. The material of the headphone hook, which has been upgraded to aluminum alloy, offers extra hardness and strength for improved durability.
Developed in collaboration with pro gamers, the XL2430T has been upgraded to eliminate flickering at all brightness levels. This effectively reduces eye fatigue and elevates gaming performance through extreme visual comfort for even the most hardcore gamers enrolling long hours in action. Armed with the Gaming-comfort Flicker-free Technology, the BenQ Gaming Monitor is an epic weapon over your ultimate rivals.
Specification:-
- LCD Size: 24"W
- Panel Type: TN
- Input / Output Connector: D-sub / DVI-DL(Dual-Link) / HDMIx2 / DP1.2 / Headphone jack / USB Hub
- AMA: Yes
- Win7: Yes
- Win8: Yes
- Full Specification: http://gaming.benq.com/gaming-monitor/xl2430t/specification/#skip
- Warranty: 2yr
Was [£289.99] Inc. VAT
Only £275.99 inc VAT.
ORDER NOW
LG 24GM77 24" TRUE 144Hz Widescreen LED Monitor - Black /w Flicker FREE Technology **OcUK Exclusive** @ £215.99 inc VAT
For the smoothest gaming experience, MOTION 240 creates an effect similar to changing a frame 240 times and eliminates afterimages whilse minimizing motion blur. It also improves response time and delivers ultra-smooth playback by performing at a speed faster than 1ms, the speed that gamers are looking for.
A Dynamic Action Sync Mode, make real-time commands and strike fast. Gamers can catch every single moment in real-time with dynamic action sync mode. It synchronizes your senses with real-time scenes happening in a fast-paced game by minimizing input lag. Make timely commands to win!
A Black Stabilizer, enhanced gamer visilbility to win in pitch black areas. Black stabilizer gives gamers full visibility even in deep-dark scenes. It automatically senses the darkest side and makes it brighter so that you can find the enemies hiding and waiting to attack you in the dark.
A Convenient game mode and game pad. Quick and easy customizable settings for your perfect gaming display environment.
Features:-
- Gaming without blurring and ghosting with "Smooth Motion"
- Detect enemies one step faster with "Swift Action"
- Personalized gaming environment with "Rapid * Easy Settings"
- Motion 240
- Dynamic Action Sync
- Black Stabilizer
Specification:-
- Height adjust and swivel stand.
- LCD Size: 24"W
- Panel Type: TN
- Response Time: (Tr+Tf) typ. under 1ms (GTG)
- Brightness: 350cd/m2
- VESA: Yes 100x100
- Warranty: 3yr
Only £215.99 inc VAT.
ORDER NOW
BenQ XL2720Z 27" TRUE 144Hz 3D Vision 2.0 Widescreen LED Monitor - Black/Red @ £329.99 inc VAT
Built for competitive FPS game play, the XL2720Z takes the explosive thrills of perfect motion gaming to a 27” screen. The stunning monitor is equipped with the latest Motion Blur Reduction technology, Low Blue Light, Gaming-comfort Flicker-free, Gaming Refresh rate Optimization Management (GROM), and Display Pilot feature to deliver agile performance, viewing comfort and convenience all at once – for your victory and entertainment.
Developed in collaboration with pro gamers, the XL2720Z has been upgraded to eliminate flickering at all brightness levels. This effectively reduces eye fatigue and elevates gaming performance through extreme visual comfort for even the most hardcore gamers enrolling long hours in action. Armed with the Gaming-comfort Flicker-free Technology, the BenQ Gaming Monitor is an epic weapon over your ultimate rivals.
Interchange instantly between different screen sizes, from 17" (4:3), 19" (4:3), 19"W (16:10), 21.5"W (16:9), 22"W (16:10), 23"W (16:9), 23.6"W (16:9), 24"W (16:9) to 27"W(16:9), using the Display Mode.
Specification:-
- LCD Size: 27"W
- Display Area(mm): 598 x 336
- Pixel Pitch (mm): 0.311
- Brightness (typ.): 300 cd/m
- DCR (typ.) (Dynamic Contrast Ratio): 12M:1
- Panel Type: TN
- Viewing Angle (L/R;U/D) (CR>=10): 170° / 160°
- Input Connector: D-sub / DVI / HDMIx2 / DP1.2 / Headphone jack
- Power Consumption: (Base on Energy star ) 27W
- Dimensions: (HxWxD mm) 548 x 642 x 273
- Net Weight (kg): 7.5
- Display Mode: 17" / 19" / 19"W / 21.5"W / 22"W / 23"W / 23.6"W / 24"W / 27"W
- AMA: Yes
- Win7: Yes
- Win8: Yes
- Height Adjustment Stand (mm): 130(adjustable down to the base)
- Warranty:
Was [£349.99] Inc. VAT
Only £329.99 inc VAT.
ORDER NOW
Samsung SyncMaster S27D390H 27" Widescreen Slim Bezel LED Monitor - Black @ £166.99 inc VAT
Samsung’s newest Touch of Colour design is sure to command attention. Upholding Samsung’s ToC design legacy, the SD390 was crafted to catch the light of its surroundings in various beautiful ways, but brings a narrow bezel, slim and sleek black body and transparent neck to create a sophisticated and tasteful look that’s finished off perfectly with a subtle hint of soft pure blue along the bezel – making this unique monitor illuminate light and stand out in a way you’ve never seen before.
On or off, the stylish SD390 is sure to stand out wherever it is. Its narrow bezel design lets you see more of the screen while illuminating a subtle hint of soft pure blue that sets an elegant glow around the monitor. Its transparent crystal neck gently gleams in the light with a beautiful touch of blue and raises the screen to the perfect viewing level. The tilt feature increases your field of vision and maximises your viewing comfort. The SD390 will no doubt fulfill your every design desire.
Get perfect viewing for games with just one touch of a button. Game Mode adjusts your monitor’s settings instantly to give you an optimised gaming experience. Game Mode smartly detects the changes in scenes, enhances the colour and alters the screen’s contrast to make dark spots darker and light spots lighter so you can see all the action at all times. There is less lag thanks to a faster video response time that ensures that the picture keeps up with action and won’t let you down.
Get the best view from any angle with the SD390. Unlike conventional monitors, your Samsung LED Monitor has an extra-wide viewing angle of 178 degrees, vertically and horizontally. This means great picture quality from even more perspectives – whether you’re sitting down low and playing games or if several people are sitting around the monitor to watch a video. Whatever the situation, you can enjoy great viewing.
Magic Upscale improves image quality to such a level that you will only receive a better picture. Enjoy enhanced image quality no matter what the original picture quality is. Magic Upscale prevents image degradation when scaling up and gives only brilliant and pristine colours and images. And it also makes images on the monitor appear clearer and sharper than on a notebook. Shine with the SD390.
The Samsung SD390 monitor gives you all the connections you need to make the most of all your entertainment and other content. HDMI compatibility gives you access to games consoles, Blu-ray players and other AV devices, while a D-Sub connection mean you can plug in most PCs. You can easily connect your devices and use the monitor for working, gaming, viewing content and more.
Specification:-
- Screen Size: 27
- Panel Type: PLS
- BLU Type: LED
- Brightness (Typical): 300cd/m²
- Peak Luminance Ratio: 99%
- Dynamic Contrast Ratio: Mega
- Resolution: 1920 x 1080
- Response Time: 5ms (GTG)
- Viewing Angle (H/V): 178° / 178°
- Color Support: 16.7M
- Connectivity: 1x Analogue & 1x HDMI
- Full Spec: http://www.samsung.com/uk/consumer/pc-peripherals/monitors/essential/LS27D390HS/XU
- Warranty: 2yr
Was [£179.99] Inc. VAT
Only £166.99 inc VAT.
ORDER NOW
Samsung S27A850TS 27" Widescreen Ultra Thin LED Professional PLS Monitor - Matte Black @ £299.99 inc VAT
Engineered with the ecologically responsible homeowner in mind, the Samsung monitor reduces power consumption by 40%;, making it much more efficient than conventional monitors. By reducing the number of LED and defaulting to standby power, which requires less than 0.3W as opposed to the typical 1.0W, the Samsung monitor is poised to make a difference. How big a difference? If your monitor saves 120W each day, that’s the annual equivalent of eliminating 10.8kg of CO2 emitted from an oil-burning power plant—which produces the same effect as planting four pine trees.
Choose a monitor that allows you to reduce financial and environmental costs as well as increasing productivity. The Samsung SA850 LED Business Monitor is designed to use less power, so you can cut bills and be kinder to the planet. A high 2560 x 1440 pixel resolution also makes sure you’ve got screen space for all your work and lets you see it all in greater detail. You’ll see images and video with stunningly natural colour thanks to sRGB support, and a 178 degree viewing angle gives great viewing from a wider range of perspectives, so it’s perfect for sharing presentations and more.
The Samsung SA850 Monitor showcases an astounding WQHD display with 2560 x 1440 pixel resolution, which is four times the resolution of HD (720p). It is perfect for businesses and industries that rely on access to extremely fine monitor detail. The wide screen, which features dual link DVI and display port, allows for more detail to be viewed and is ideal for work places such as hospitals, clinics and studios. The enhanced screen resolution provides greater efficiency and quality, and really is the must-have business tool.
Whether it’s video from an HD camcorder or photos from your digital camera, sRGB support makes sure that nature looks just as natural on your Samsung Monitor as it did when you shot it or filmed it. No matter what digital device the image was captured on, it’s as picture perfect on screen as Mother Nature intended it to be. So you can view, edit, and save images in their original format with no picture quality degradation whatsoever — which translates to 100%; pure digital satisfaction.
Provide employees with an optimal viewing experience in the office with the reasonably priced Samsung Business Monitor. While conventional monitors have a viewing angle of 170 degrees horizontally, the Samsung monitor has an extra wide viewing angle of 178 degrees. The additional 8 degrees is particularly useful when sharing on-screen information with one or more coworkers or presenting your ideas to clients. The Samsung Business Monitor has improved its vertical viewing angles by 18 degrees, making it the perfect display for giving presentations in front of a large audience or when viewing other content such as a video.
Maximise your viewing experience with Samsung’s superior PLS technology (Plane to Line Switching). Regular screens suffer from what is called Colour Shift, which reduces the picture quality and colour when viewed from an acute angle. The SA850, which can cover an amazing 178° viewing angle both vertically and horizontally, boasts a crisp and detailed picture by maintaining true-to-life colour, even when viewed from extreme angels, so the experience is always vivid and brilliant.
The Samsung LED Business Monitor SA850 has been designed to help boost work efficiency, delivering a tailored experience with its choice of viewer settings. The height-adjustable stand ensures that the screen can always be set at the optimal eye level, which enhances the visual experience while also helping maintain the viewer’s body posture. Other features include the tilt and pivot capabilities, which not only increase comfort levels but also introduce new ways of working. The SA850 Monitor can rotate 90°°° degrees, allowing for more appropriate view depending on the work. So, now you can take convenience and efficiency to amazing heights with the Samsung LED Business Monitor SA850.
If you need a work monitor that uses office space efficiently, then Samsung LED Business Monitor SA850 is the perfect choice. It features an innovative new detachable adaptor, which allows the monitor to be easily moved and installed. From physically moving the monitor with the carrying handle to quickly installing, the SA850 is ready to deliver an efficient and clean work space. The SA850 is also equipped and prepared for you as a VESA Wall mount, providing a multi-screen or wall mounted monitor. Optimising your office space is now easily achieved with the Samsung LED Business Monitor SA850
Utilising Samsung’s dual input feature, two PCs can now be viewed simultaneously on the one monitor screen. The SA850’s Picture by Picture capabilities allow for a far more flexible approach to work and ensure that content can be easily accessed, even if they require different PC access. This is perfect for businesses handling large and complex content from two PCs, but prefer to view it on one convenient screen.
As the work environment becomes increasingly modernised, it is essential that monitor also have the latest technology. Samsung SA850's USB Hub with USB 3.0 technology, which provides super-speed data transmissions, is the ideal solution for connecting all of your mobile devices. With a maximum speed of 5GB per second and uncompressed Full HD video transmissions, the USB Hub effortlessly brings your content together on one convenient monitor.
Eco saving makes saving energy easy, it adjusts the brightness of your Samsung monitor based on how much energy you want to save. And with the choice of three energy saving modes (50%;, 25%; and Power Saving off), you can really tailor your monitor use to meet your own personal needs. Samsung’s commitment to saving energy is designed to help both you and the environment, and with up to 50%; saving on consumption, you can really make a positive impact on your eco footprint. Take the effort out of saving energy and take control with Eco saving.
Take the guess work out of eco savings with Samsung’s new Energy Tree feature. For the first time, you can now know exactly how much energy you are saving through your eco modes such as the Eco light sensor and the Eco motion sensor. Through an intuitive energy saving status, which can be displayed either intuitively or graphically, you can keep tabs on your efforts to make the world a better place.
Features:-
- 27" (16:9)
- 300cd/m² Brightness
- DCR Mega 8 Dynamic Contrast Ratio
- 2560 x 1440 Resolution
- 5ms Respond Time
- 178° / 178° Viewing Angle
- 16.7 Million Colour Support
- Inputs: 1x Dual Link DVI, 1x DisplayPort, 1x HDMI
- 3x USB
- HAS (150mm)
- Tilt / Swivel / Pivot
- VESA: (100 x 100, 100 x 200) Available
- USB 3.0 Super Power
- 2yr Warranty
Was [£559.99] Inc. VAT
Only £299.99 inc VAT.
ORDER NOW
BenQ BL3200PT 32" Widescreen LED Professional/Gaming Slim Bezel Flicker FREE Monitor - Black @ £469.99 inc VAT
Accurate Color Gamut that brings your imagination to life, A Large Screen that extends your design space, High Resolution to view the smallest details, Ergonomic Features that ease your eye and neck strain... Result, A monitor that meets all your CAD/CAM needs!
With a 2560x1440 WQHD resolution and extra working space mean less scrolls for zooming in and out. Start using BenQ CAD/CAM Monitor now and boost your work efficiency!
The unique CAD/CAM Mode is specially designed to enhance work efficiency and reducing eye fatigue for all CAD/CAM users. By making the color contrast higher, every displayed line will be perfectly distinguished. With BenQ CAD/ CAM Monitors, you will never miss a line again in your designed work.
To clearly distinguish detailed textures in the darkest areas, BenQ developed Animation Mode that enhances brightness in dark areas without overexposing bright areas. With ten levels of brightness, the Animation Mode provides the comfort and freedom that every designer will welcome with open arms.
With the BenQ’s advanced 100% sRGB screen technology, every color is delivered with the finest precision in every detail and at every possible viewing angle. Get and share a professional viewing experience.
Auto Pivot detects the rotation of the monitor and dynamically rotates displayed content automatically. All windows will be equally portioned and displayed on the screen when clicking on the Desktop Partition icon, which allows you to compare all design works with just, one simple click. Moreover, you can preset different picture modes to each frequently used software. Display Pilot will automatically switch to your preferred picture mode in different user scenarios.
Unique control device docked to the stand of every BL3200PT monitor remotely accesses the OSD menu. Three pre-set hot-keys allow quick switching between 1. sRGB Mode, 2. CAD/CAM Mode, 3. Low Blue Light Mode, or let you assign your own set of display modes providing ultimate user flexibility.
Large screen monitors usually take a noticeable amount of space on the working desk. BL 3200 is designed to save as much of your workspace as possible. Compact stand architecture enables the screen to sit at the very edge of the desk and maximize your working space and comfort.
I/O ports on the side of the screen effortlessly bring all your content together in one convenient package. 2x USB 3.0 and SD card reader provide super-speed data transmissions.
The slim bezel makes the monitor look lighter and larger. In a multi-display setup with two or more units, thin bezels are less intrusive and effectively expand your work-space.
An extensive range of monitor adjustments – height, tilt, pivot, stroke and swivel – tailor your own unique working station that is best suited for your height and viewing habits with a maximum 150mm distance between the screen bottom and the base.
The Flicker-free technology eliminates flickering at all brightness levels and effectively reducing eye fatigue. Conventional LCD screens flicks 200 times per second. Your eyes may not see flickers, but they can certainly feel them. Free your eyes from flickers by switch to CAD/ CAM Monitors and let your eyes do less work while you are working on CAD/ CAM designs.
Every Monitor produces a strain of blue spectrum light that is one of the critical causes of eye damage, eye strain, headaches and sleeping disorders. BenQ's unique Low Blue Light technology is designed to deal with the everyday problem of blue light exposure and allows a healthier time spent in front of your computer. Switch to one of the four preset Low Blue Light Modes from OSD hot key (Multimedia – 30% reduction, Web-surfing – 50% reduction, Office – 60% reduction, Reading – 70% reduction), and reward your eyes without having to lose the visual enjoyment. Corporate users are frequently required to read documents from a monitor. Reading Mode adjusts the screen brightness, contrast ratio and sharpness to make your eyes feel as easy as reading directly from hard copies without wasting any paper.
Specification:-
- Screen Size: 32"W, VA LED
- Resolution (max.): 2560 x 1440
- Brightness: 300 cd/m2
- Contrast Ratio: 3000:1
- DCR: 20M:1
- Response Time: 4 ms GTG
- Display Color: 1.07 billion
- Viewing Angle (L/R;U/D) (CR>=10): 178 / 178
- Terminals: D-sub / DVI-D / HDMI / DisplayPort
- Flicker FREE technology
- VA (AMVA+) LED Technology
- HDCP Support
- Speaker: 5W x2
- USB Hub: Yes
- Dimensions(HxWxD mm) HIGH: 640.16*740.28*232.48mm
- Warranty: 2yr
Was [£499.99] Inc. VAT
Only £469.99 inc VAT.
ORDER NOW
Dell UltraSharp U3014 30" Widescreen LED Monitor - Midnight Grey @ £749.99 inc VAT
Users will experience outstanding color accuracy, precision and performance with the Dell UltraSharp U3014 30-inch monitor with PremierColor. The U3014 is Dell’s flagship high performance monitor with a 16:10 aspect ratio, suitable for the fine level of detail required for color-critical work such as CAD/CAM, graphic design, desktop publishing, gaming or media creation. In addition, users will experience stunning high-definition details and the ability to view more onscreen content with 2560 x 1600 resolution. More than just a high performance monitor, the U3014 offers flexible viewing options, versatile digital connectivity and is designed for exceptional efficiency with an eco-design that meets the latest environmental standards like EPEAT®, ENERGY STAR® and TCO Certified Displays.
Features:-
- IPS (in-plane switching) technology for minimal color deviation across a wide viewing angle
- 30" (76cm) display with 2560x1600 resolution and 16:10 aspect ratio for clear images and exceptional multitasking
- Easy, versatile adjustability and some of the latest connectivity options, including HDMI, DisplayPort, DVI-D, USB ports and a 7-in-1 media card reader
Specification:-
- 30" Widescreen
- Light AG coating
- About 52.5% more screen area than Dell 2407WFP-HC
- The only 4 mega pixels monitor that shows true resolution of mega pixel pixel photos
- Higher definition than HD Television to meet the most stringent video needs
- 2560 x 1600 (WQXGA) Optimum Resolution (Dual Link capable DVI-D graphics card required)
- 1.07 Billion Colours
- 10-Bit Colour
- 1000:1 Contrast Ratio
- 6ms Response Time (6ms Grey-TO-Grey)
- 350 cd/m2 Brightness
- DVI-D Input with HDCP support
- HDMI Input
- Display Port Input
- Height adjustable stand, tilt and swivel (100mm travel)
- VESA mounting compatible / Security slot : Yes (100mm) / Yes
- Integrated powered USB 3.0 hub : 4 downstream / 1 upstream ports
- Integrated powered 9-in-2 Smart Card Reader: Compact Flash 1&2, Secure Digital, MMC, Smart Media and Microdrive
- Warranty : 3 year next business day exchange supplied by Manufacturer. (Call Dell on 0870 9080800 and have the work number from the original packaging handy, request to speak to the Dell Warranty Monitor Line)
- Product Review @ TFT Central: http://www.tftcentral.co.uk/reviews/dell_u3014.htm
Was [£799.99] Inc. VAT
Only £749.99 inc VAT.
ORDER NOW
LG Flatron 29UB65-P 29" WideScreen Super-Wide LED Monitor @ £259.99 inc VAT
The 21:9 ratio is the perfect professional fit for software engineers, video / sound editors, and graphic designers. Imagine 2 conventional high quality monitors attached for multi-tasking, but their screens connect and extend seamlessly. Now you can use a program with long-range panoramic view in full length, without any bezel in the middle or dragging cursors. No longer divide your focus into separate monitors, the 29UB65 is the perfect companion for your profession.
Like other smart devices, the 29UB65's Pivot & Height Adjustable feature allows you to simply rotate the screen to fit vertically long images or files. When pivoting, you can easily adjust its height too. Leave dragging and scrolling behind. Let the monitor adjust to your images and needs.
Connect two devices to a single monitor with Dual Link-up that allows an HDMI + HDMI link. Now you and your colleague can simply bring each other's devices and connect to a single monitor to share and compare information. Freely show and control your screen while watching your partner doing the same on the opposite side of the monitor. Don't bother installing annoying projectors in your small room or worry when your conference room is occupied, the 29UB65 is here for you.
With its wide screen ratio, now you can open 4 programs on a single screen to see your information in a single glance while working. The size of sub screens is user-controlled. The 29UB65 is compatible with Mac® and not only provides convenience but also productivity in a single click, you can split your screen into 2 to 4 subscreens.
Reducing blue light to protect your eyes, Reader Mode provides optimal condition for reading. With just a touch of a button, you can comfortably read on the monitor for as long as you would like to.
As LG IPS Monitor features consistency and less changes in colour temperature, it offers a colour impression identical to that of the original image. You can enjoy lifelike picture picture quality without any colour shift whether you are standing or lying down. It allows you to enjoy any content, such as action movies, web surfing and RPG games for a long time in comfort.
Protect your eyes from exhausting flickers and blue lights. LG's new Flicker Safe system is always on to reduce the flicker level to almost-zero. In addition, activate the Reader Mode to minimize harmful blue lights with a simple touch of a hot-key. Spend as long as you want working, gaming, or watching movies without burdening your eyes. Use the convenient and easy hot keys for more satisfaction.
The joystick is a harmony of accurate menu controls and analogue sensitivity. With the fun control of a conventional joystick, its modern technology and design allow for simple control with a pleasant touch. In addition, intuitive UI with no overlapping is easier to understand and select menus.
Specification:-
- Screen size (inches): 29"
- Panel Type: IPS
- Aspect Ratio: 21:9
- Resolution: 2560*1080
- Brightness (cd/m2): 300
- Contrast Ratio: 100000000:1
- Viewing Angle (°): 178/178
- Colour Depth (Num of Colours): 16.7M (8-Bit)
- Pixel Pitch (mm): 0.315 x 0.310
- Colour Gamut: sRGB
- Surface Treatment: Hard Coating (3H), Anti-Glare
- Connectivity: 1x DVI-D, 2x HDMI, 1x DisplayPort
- Speakers: 2x 7W
- Warranty: 2yr
Was [£281.99] Inc. VAT
ORDER NOW
LG Flatron 29UM65-P 29" WideScreen Super-Wide LED Monitor @ £239.99 inc VAT
The 29UM65 satisfies your demands for viewing pleasure and entertainment. Put high spec games on the 21:9 wide screen with astonishing picture quality of UltraWide Full HD (2560x1080) accompanied by 7W stereo speakers and satisfy your desire for the most realistic gaming experience and movie adventures.
With a 21:9 wide screen ratio, now you can multitask with 4 programs on one screen at the same time. This 4-Screen Split feature conveniently divides your screen from 2 to 4 customizable subscreens of your preferred size, without any overlapping of windows. Compatible with Mac®, it provides 8 different screen ratios, changeable by a single click, and increases not only your convenience but also productivity.
The Dual Link-up feature allows two devices to be displayed simultaneously on a single screen. With the monitor, you can connect and watch a movie from a Blu-ray player while working on an Excel spreadsheet from your PC. With the 29UM65's upgraded Dual Link-up, it enables HDMI+HDMI links, now you can connect devices more conveniently.
Reducing blue light to protect your eyes, Reader Mode provides optimal condition for reading. With just a touch of a button, you can comfortably read on the monitor for as long as you would like to. Enjoy your movies or games with realistic stereo sound. With the built in stereo speaker, there is no need for extra speakers around your monitor.
Specification:-
- Panel Type: IPS
- Contrast Ratio: 50000000:1
- Warranty: 2yr
ORDER NOW
LG Flatron 34UM95-P 34" WideScreen Super-Wide LED Monitor @ £719.99 inc VAT
The UltraWide 21:9 aspect ratio makes movies and games more immersive than ever. Need to get some work done, too? All of that UltraWide real estate makes it easy to view multiple documents at the same time, so you don't need to flip back and forth between them.
The 3440X1440 UltraWide QHD display offers amazingly sharp picture quality. Its pixel area is about 1.8 times larger than an UltraWide Full HD 21:9 monitor, and about 2.4 times larger than a Full HD 16:9 monitor. It provides an efficient environment in using Microsoft Office programs showing 47 columns and 63 rows in excel.
sRGB is the standard color space of ideal color reproduction. So, with over 99% coverage of the sRGB spectrum, this LG monitor is a great solution for professional photographers, graphic designers or anyone looking for highly accurate color.
Multitasking doesn't have to mean shuffling back and forth between windows*. With a single click, the 4-Screen Split feature divides the screen into as many as four customizable segments, two-by-two. Now you can see four different windows at the same time.
The Dual Linkup feature allows two compatible portable devices--such as a computer, camera, phone, or Blu-ray player--to be connected to the monitor, and both can be viewed on the same screen simultaneously.
This monitor's Thunderbolt input/output port allows you to connect up to six compatible devices, moving data between them with incredible speed. The two channels of 10-gigabits-per-second throughput in both directions are up to 20X faster than USB 2.0. Thunderbolt is an exciting innovation for both expansion and premium video display.
The DisplayPort digital video interface is used to connect a high-performance video source to a high-resolution monitor. Thanks to its sophisticated design, a DisplayPort cable can also be used to carry audio, USB signals and other data as well.
LG’s LED backlighting delivers exceptional brightness and amazing image clarity. You'll see richer colors and deeper blacks too, and LEDs offer greater energy efficiency compared to conventional LCD monitors.
IPS (In-Plane Switching) technology enhances thA dynamic contrast ratio of 5,000,000:1 is your assurance of strong video performance, with deep blacks, bright whites and pleasing colors.e performance of liquid crystal displays. Response times are shortened, color reproduction is improved, and users can now view the screen at virtually any angle.
Looking for the ultimate in fine-tuning for your LG monitor? This model is designed to work with compatible calibration devices* that take specific readings and guide you through precise adjustments of color, brightness and more.
Specification:-
- Screen Size Class (diagonal): 34"
- Panel Type: IPS
- Resolution: 3440x1440
- Color Gamut (CIE1931): sRGB 99%
- Brightness (typical): 320 cd/m2
- Contrast Ratio(Original): 1000:1
- Viewing Angle (CR>10): 178/178
- Colour Depth (Num of Colours): 1.07B (8-Bit+FRC)
- Pixel Pitch (mm): 0.2325
- Surface Treatment: Anti-Glare 3H
- Connectivity: 2x HDMI, 1x DisplayPort & 2x ThunderBolt
- Warranty: 2yr
Was [£769.99] Inc. VAT
Only £719.99 inc VAT.
ORDER NOW
All these deals end on Monday and pricing shall return to previous sold price, grab a great deal this Halloween weekend guys!
the 2420Z still just out my range, anything on the 2411Z?
Though the 970 Inno3D deal doesn't help much probably
