Hi there
These are pretty much the fastest GTX 900 cards available with excellent overclocking potential and absolutely stunning looks. These have to be some of the best looking cards ever and would look amazing in white themed computers:-
GALAX GeForce GTX 980 "Hall of Fame Edition" 4096MB GDDR5 PCI-Express Graphics Card @ £499.99 inc VAT
GALAX, a leading manufacturer and innovator of extreme performance gaming hardware, today announced the long awaited successors to the world renowned Hall of Fame lineage with the release of the GTX 980 HOF and GTX 970 HOF. Following in the HOF tradition, each card is factory tuned with the highest core clock in its class. The true dominance of the GALAX HOF Series cards, however, lay in their completely unbridled potential for overclocking.
Only the best of the best GeForce GPUs make the cut for HOF edition products, and GALAX has taken every possible step with their in-house designed white PCB, ultra-premium components and an incredible 7 heat-pipe triple fan cooler to ensure that overclockers' skill and determination is the only thing standing between them and a new world record. GALAX exclusive Hyper Boost technology acts like a hardware turbocharger, increasing the maximum power delivered to the GPU with the push of a button. Dual BIOS further simplifies the tweaking process by enabling risk-free firmware updates and customization.
Key Features:
- Completely redesigned PCB layout from the ground up, optimized for GM204
- 10 layer manufacturing process in HOF signature pure white color
- Extended PCB width for optimized layout and cleaner signal
- Advanced GALAX exclusive "Triple Force" cooler
- 2x 80mm fan + 1x 90mm fan
- 4x 8mm heat pipes + 3x 6mm heat pipes (total 7 nickel-plated heat pipes)
- Copper base cooler
- Integrated MOSFET heatsink
- Customizable top HOF LED (control blanking frequency, brightness with GFE)
- Plastic cover with premium die-cast aluminum accents
- Anodized aluminum backplate protects components and reinforces PCB
- Next generation IR3595 Digital PWM controller provides 2X switching frequency vs. previous generation
- 8 phase GPU + 2 phase memory power
- IR3555 with next gen DrMOS and 60A output
- Aerospace-grade GALAX Extreme Power Inductors provide ultra-long life, high endurance and low noise vs. normal power inductors
- Hyper Boost technology acts like a hardware turbocharger, increasing fan speed and maximum power delivered to the GPU with the push of a button
- Voltage tool (developed by enthusiasts) allows voltage beyond stock limits
- Hardware dual BIOS simplifies the tweaking process by enabling risk-free firmware updates and customization
- Prelim internal overclocking results: >1.5-1.6GHz on air, >2.1GHz on LN2
- Coil wine reduction technology
Specification:-
- Multi-layer ceramic capacitors (Helps reduce coil whine)
- GeForce GTX 980
- GPU: GeForce GTX 980 (GM204)
- Process: 28nm
- Core Base Clock: 1304MHz
- Core Boost Clock: 1418MHz
- Memory Clock: 7010MHz
- Memory Size: 4096MB GDDR5
- Bus Type: PCI Express 3.0
- Memory Bus: 256-bit
- CUDA Cores: 2048
- DirectX 12: Yes
- DVI Port: 1x Dual-Link DVI, 3x DisplayPort & 1x HDMI
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 2x 8-Pin
- 500W PSU Required
- 180W TDP
- Warranty: 2yr
Only £499.99 inc VAT.
ORDER NOW
GALAX GeForce GTX 970 "Hall of Fame Edition" 4096MB GDDR5 PCI-Express Graphics Card @ £319.99 inc VAT
Key Features:
Specification:-
- GeForce GTX 970
- GPU: GeForce GTX 970 (GM204)
- Core Base Clock: 1216MHz
- Core Boost Clock: 1380MHz
- CUDA Cores: 1664
- DirectX 12: Yes
- DVI Port: 2x Dual-Link DVI, 1x DisplayPort & 1x HDMI
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 1x 8-Pin & 1x 6-Pin
- 450W PSU Required
- 165W TDP
- Warranty: 2yr
Only £319.99 inc VAT.
ORDER NOW
The backplate on these cards is without doubt the nicest I have seen yet, go and take a look at the gallery for these cards on our website.
Key Features:
Specification:-
- GeForce GTX 980
- Process: 28nm
- CUDA Cores: 2048
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 2x 8-Pin
- 500W PSU Required
- 180W TDP
- Warranty: 2yr
ORDER NOW
Key Features:
Specification:-
- GeForce GTX 970
- CUDA Cores: 1664
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- 450W PSU Required
- 165W TDP
- Warranty: 2yr
ORDER NOW
