Got mine in last night look forward to seeing if it's an improvement over xfire 280x
Think you're gonna be disappointed unless you bought a pair...
SLI is![]()
Maybe around xmas If I can get a decent deal on a 4k monitor
Anyone recommend an overclocking tool?
not sure if the cooling option supplied with this card will allow for much overclocking headroom, but we shall see next week I guess..!
so far its seems really good. But no clue what to use for OCING nvidia anymore,
MSI Afterburner appears to work good, and reporting like 40degrees![]()
Did you opt for Saturday delivery?
MSI afterburner is fine.
You can search some threads here or google for overclocking tips, but essentially you just crank up the settings gradually and run a stress test, keep going til you run into problems, then turn it down a few notches from there.
I'm curious to see what type of temps it gets at factory settings at 100% load anyway. I doubt mine will get anywhere near 100% load while gamin atm xD (unless testing DSR out).
Can't wait to play Borderlands with alllll the eye candy / PhysX turned up to max ^_^
