Razer copperhead replacement
13 Jan 2013
County Durham
I've had my copperhead now for about 8 years now and although it still works I think it's abit long in the tooth (get the pun) so wondering what would a good replacement?
I quite like the look of the logitech g502 is the anything out there that you's guys recommend.
how do you use your mouse? palm or claw? and how big are your hands? i went for the deathadder as have large hands and use both palm and claw at times. Also went in and tried about 100 mice before i decided that :D
I've got average size hands and use a mix between Palm and claw if that helps.My copperhead feels comfortable is the g502 bigger in size?
Got the same problem. Love my copperhead, even after having to strip it down and fix the notches caused by years of clicking.
When we moved house I dropped it and it now the sensor sometimes has a mind of its own.. Currently waiting on a Corsair M65 RGB (was ordering K70 keyboard at same time). I'd have bought another copperhead straight away if I could have done tho. Hopefully I can get used to the M65, on paper it seems to match my use style.
