Permabanned
- 15 Dec 2008
Been playing with my 970's over the last few weeks and more specifically, DSR.
As we all know certain games are performance hogs when using traditional multi-sample anti-aliasing.
This is mainly due to pretty much every modern game moving to a deferred renderer, which is only going to become the norm for game engines.
That's where DSR comes in, from my testing it's actually much cheaper from a performance point of view to run 2xMSAA+2xTrSAA with at least 1.2x DSR factor then running straight 4xMSAA and 8xMSAA.
And because of what DSR is you end up with better image quality then MSAA can produce anyway. Higher IQ with higher frame rates can't be bad can it?
Case in point, Hitman Absolution, a game that's known to eat VRAM and performance for breakfast when you run 4xMSAA or higher.
My 970's actually run faster with 2xMSAA+2xTrSSAA+2.0x DSR factor ( Rendering at 4k ) then running the game with straight 4xMSAA or 8xMSAA at my native resolution at 1440p. Even my old R290 had a massive drop when running 4xMSAA or above.
In fact at the above the settings the game is locked at 60fps with V-sync I've halfway through the game and have yet to see it drop.
So my lovelies, learn to LOVE and use DSR and the next time you turn on MSAA and your frame rate dies, turn the MSAA down and try turning DSR on
