I want my PC to be quicker
Thanks so much guys
I am going to buy the SSD Stu recommended
Have we worked out what Ram will be ideal for me?? The ram Stu said is out of stock
Thanks
Can you just open the pc up and look on the board at the make an model number, it will be so much easier.
belarc advisor is good at pulling all system spec !
However dont do straight copy/paste as it also pulls all Serial Keys for installed programs as well
Copy/paste Stulids link above and for memory you get:
Memory upgrade information
Dual channel memory architecture
Two DDR3 DIMMs (240-pin) sockets
PC3-8500 (DDR3-1066)
PC3-10600 (DDR3-1333)
Non-ECC memory only, unbuffered
Supports 1GB, 2GB, and 4GB DDR3 DIMMs
Supports up to 4 GB on 64-bit PCs
Supports up to 4 GB on 32-bit PCs
*32-bit PCs cannot address a full 4.0 GB of memory.
Maximum memory only if using 4GB DDR3 DIMM modules
Processor
Motherboard supports the following processor upgrades:
NOTE:Only Socket AM3 processors are supported with this motherboard.
Max TDP: up to 95W
AMD Phenom II X4 9xx/9xxe/8xx Quad-Core (Deneb core)
AMD Phenom II X3 7xx/7xxe Triple-Core (Heka core)
AMD Phenom II X2 5xx (Callisto core)
AMD Athlon X4 6xx/6xxe (Propus)
AMD Athlon X3 4xx/4xxe (Rana)
AMD Athlon X2 2xx/2xxe (Regor)
AMD Sempron Single Core Processor 1xx (Sargas core)
