Currently have 2x4GB Corsair Vengeance CMZ8GX3M2A1866C9 running at 1866. Was looking to step up to 16GB but I'm not sure whether to just add another 2x4 or replace with 2x8. I've heard rumours that 4x4 is either unstable or slower on this chipset. Can anyone confirm that?
If I'm looking at replacing with 2x8, what would you recommend?
Spec claims dual-channel at 1600/1866/2133. Current RAM runs CL9 but the 2133's available are mostly CL11. Am I out of date in thinking that the net result will not be any faster? CPU is i7-2600K running at stock underwater but with the turbo up to 4200MHz so it runs either at 1600 or 4200 depending on load. It'll quite happily sit at 4200 continuously as I found out when I realised that Windows' "High Performance" power setting just kicks the turbo in full-time.
Many thanks,
Gareth
Many thanks,
Gareth
