Hi there
I am very proud to say that OcUK is the only UK company with stock of 8GB 290X and also has the largest range of 8GB cards available compared to our competitors who mostly have zero range.
Sapphire Radeon R9 290X Vapor-X OC 8192MB GDDR5 PCI-Express Graphics Card **OcUK WorldWide Exclusive** @ £379.99 inc VAT
OcUK has a worldwide exclusive on the only 8GB 290X in existence, but this is not any 290X it's a highly fine tuned machine being the Vapor-X edition with near silent cooling solution. Running with a 1060MHz core clock and with memory clocked at 5600MHz makes this card absolutely perfect for a 4K setup, even more so with a pair or three of these in Crossfire. That means you could play games like Skyrim with expansion packs at 4k resolution and still not run out of VRAM.
Based on the award-winning Graphics Core Next (GCN) architecture from AMD with 2816 Stream Processors, the SAPPHIRE R9 290X Vapor-X is an Overclocked edition which boasts 8GB of the latest GDDR5 memory running at 1400 MHz (5.60GB/s effective) and high speed engine clocks of 1060MHz.
SAPPHIRE’s innovative Vapor-X cooling technology allows products to run not only cooler but also much quieter. A Vapor-X product means a virtually silent gaming experience and more headroom to explore performance tweaking!
Choke is an important component of the graphics card. By working with the component engineer, Sapphire’s patent pending choke is 10% cooler and offers 25% more power efficiency than a normal choke. The graphics card will be more reliable and save energy.
Improved reliability and better overclocking are possible by using only high-polymer, aluminum capacitors which posses far superior characteristics than regular aluminum capacitor for a longer product life. When operational temperatures drop by 20°C, the product life span is extended by a factor of ten, when the operational temperature increases by 20°C, the product life span only decreases by 10%.
Along the edge of the card the PCB is extended and one of the copper layers left exposed. An additional heatsink mounted directly to this copper layer allows heat absorbed into the PCB from the GPU and other components to be transferred to the heatsink and cooled by the airflow. This feature alone can reduce core temperature by 2 degree C.
Specification:-
- GPU: Hawaii XT
- Litecoin Hash Rate: 850-1000
- Stream Processors: 2816
- ROPS: 64
- Core Speed: 1030MHz
- Memory Speed: 5500Mhz
- Memory interface: 512-Bit
- Memory capacity: 8192MB GDDR5
- PCI-Express X16 lane required
- 600W or greater PSU required
- Power Connectors: 2x 8-pin required
- Display Outputs: 2x Dual Link DVI, 1x HDMI, 1x DisplayPort
- Warranty: 2yr
Was [£389.99] Inc. VAT
Only £379.99 inc VAT.
ORDER NOW
MSI Radeon R9 290X Gaming Edition 8192MB GDDR5 PCI-Express Graphics Card @ £379.99 inc VAT
AMD Radeon R9 290X is a new graphics card powered by the latest AMD Radeon™ R9 290X graphics-processing unit (GPU). 4GB of super-fast GDDR5 memory for the best gaming experience at the highest resolutions including 4k and incorporates AMD Eyefinity and TrueAudio technologies to enable expansive multi-display setups and more accurate environmental sounds. R9 290X also includes support for both DirectX® 11.2 and AMD's new Mantle application programming interface (API) for great handling of even the most-demanding PC games.
Specification:
- Radeon R9 290X
- Backplate included: Yes
- GPU: Hawaii XT
- ROPS: 64
- Core Speed: 1040MHz
- Memory Speed: 5000Mhz
- Cooling: MSI Twin FrozR Gaming Cooling
- Power Connectors: 8-pin + 6-pin required
- Warranty: 3yr
ORDER NOW
Powercolor Radeon R9 290X PCS+ OC 8192MB GDDR5 PCI-Express Graphics Card **OcUK Exclusive** @ £379.99 inc VAT
PCS+ Version features Powercolor's amazing tri-fan cooler, for much lower noise levels whilst offering superior cooling. Along with a great overclock out the box, this card runs at 1050MHz core and 5400MHz memory.
AMD Radeon R9 290X is a new graphics card powered by the latest AMD Radeon™ R9 290X graphics-processing unit (GPU). 8GB of super-fast GDDR5 memory for the best gaming experience at the highest resolutions including 4k and incorporates AMD Eyefinity and TrueAudio technologies to enable expansive multi-display setups and more accurate environmental sounds. R9 290X also includes support for both DirectX® 11.2 and AMD's new Mantle application programming interface (API) for great handling of even the most-demanding PC games.
Specification:
- Radeon R9 290X
- GPU: Hawaii XT
- ROPS: 64
- Cooling: 2-Slot Blower Fan
- 750W or greater PSU required
- Comes with BF4 Voucher included in the box
- Warranty: 2yr
ORDER NOW
Sapphire Radeon R9 290X 8192MB GDDR5 PCI-Express Graphics Card **OcUK WorldWide Exclusive** @ £359.99 inc VAT
As requested by our customers and actioned by us here at OcUK this is the worlds ONLY reference PCB and reference blower cooler 8GB card available and only exclusively from OcUK in the world. Perfect for customers who want to run 3-way or 4-way crossfire or fit waterblocks. Once again OcUK delivers because we listen to our customers!
Specification:-
- Radeon R9 290X
- GPU: Hawaii XT
- ROPS: 64
- Core Speed: 1000MHz
- Fan Speed: 20% - 40% (Quiet Mode) & 20%-55% (Uber Mode)
- Warranty: 2yr
Only £359.99 inc VAT.
ORDER NOW
OcUK owning the market yet again!
The Sapphire Vapor-X is IN STOCK and a great deal as it comes with four games making it even better value for money.
Specification:-
- GPU: Hawaii XT
- ROPS: 64
- Warranty: 2yr
ORDER NOW
Specification:
- Radeon R9 290X
- GPU: Hawaii XT
- ROPS: 64
- Warranty: 3yr
ORDER NOW
Specification:
- Radeon R9 290X
- GPU: Hawaii XT
- ROPS: 64
- Warranty: 2yr
ORDER NOW
Specification:-
- Radeon R9 290X
- GPU: Hawaii XT
- ROPS: 64
- Warranty: 2yr
ORDER NOW
