HI there
When you buy an AMD Radeon R9 290 series from OcUK for a limited time only you will get FREE:-
AMD PROMO: Sid Meier's Civilization Beyond Earth PC Game @ £29.99 inc VAT
Get the latest Sid Meier's Civilization Beyond Earth PC Game with qualifying AMD Radeon R9 290 Series graphics cards.
Only £29.99 inc VAT.
ORDER NOW
AMD Radeon GOLD Reward Ticket (Emailed) @ £89.99 inc VAT
Choose 3 FREE Games from AMD between now and end of this year with this GOLD Reward for purchasing an R9 295/290/280 series graphics card.
1. www.AMD.com/radeonrewards
2. Sign in or create an account
3. Follow the instructions to redeem your offer with the code on the ticket
4. This voucher will automatically attached to your order when ordering a qualifying car
5. Ensure you put a valid email address when placing your order as your Golden Ticket will be emailed her or you can retrieve by logging into your account at OcUK.
Only £89.99 inc VAT.
ORDER NOW
Just some of the qualifying cards:
Sapphire AMD Radeon R9 295 X2 8192MB GDDR5 PCI-Express Graphics Card @ £659.99 inc VAT
No matter what the game or the resolution you can now select the maximum settings even at 4k resolution and enjoy fluid ultimate smooth framerates in latest games such as Titanfall, Diablo 3, Watchdogs and even potential upcoming games such as GTA V and Half Life 3 should they surface.
Featuring a pair of 290X Hawaii GPU's fused onto a single PCB with an advanced PLX chip along with only requiring 2x 8-Pin power connectors.
The other major feature of the 295 X2 is its cooling solution which truly does keep the cards temperatures around 60c even after gaming for hours and it also manages to do this in more or less silence with zero throttling of the cores themselves. Making it one of the smoothest, quietest and easily most powerful graphics card on the market today. If you really crave the most powerful and have or are considering a 4k monitor for gaming then the 295 X2 is the card for you.
If your demands are truly the most powerful experience possible then these cards work great in Crossfire (4 GPU's) and you will be able to smash benchmarks to pieces and have no slow downs in games.
Specification:-
- GPU: 2x Hawaii XT
- Hybrid Liquid Cooling
- Litecoin Hash Rate: 1600-2000
- Stream Processors: 5632
- ROPS: 128
- Core Speed: 1018MHz
- Memory Speed: 5000Mhz
- Memory interface: 1024-Bit (2x 512-Bit)
- Memory capacity: 8192MB GDDR5
- PCI-Express X16 lane required
- 850W or greater PSU required with genuine 8-Pin PCI-E cables such as Silverstone 1500W
- Case capable of fitting such a long card and support for a 120mm radiator
- Dimensions: Card is 307x111x65mm and Cooler is 153x120x63mm
- Power Connectors: 2x 8-pin
- Display Outputs: 1x Dual Link DVI, 4x Mini-DisplayPort
- Warranty: 2yr
Only £659.99 inc VAT.
ORDER NOW
MSI Radeon R9 290 Gaming Edition 4096MB GDDR5 PCI-Express Graphics Card @ £227.99 inc VAT
AMD Radeon R9 290 is a new graphics card powered by the latest AMD Radeon™ R9 290 graphics-processing unit (GPU). 4GB of super-fast GDDR5 memory for the best gaming experience at the highest resolutions including 4k and incorporates AMD Eyefinity and TrueAudio technologies to enable expansive multi-display setups and more accurate environmental sounds. R9 290 also includes support for both DirectX® 11.2 and AMD's new Mantle application programming interface (API) for great handling of even the most-demanding PC games.
Specification:
- Radeon R9 290
- Backplate included: Yes
- GPU: Hawaii Pro
- Litecoin Hash Rate: 800-950
- Stream Processors: 2560
- Core Speed: 977MHz
- Memory interface: 512-Bit
- Memory capacity: 4096MB GDDR5
- Cooling: MSI Twin FrozR Gaming
- 600W or greater PSU required
- Power Connectors: 8-pin + 6-pin required
- Display Outputs: 2x Dual Link DVI, 1x HDMI, 1x DisplayPort
- Warranty: 3yr
Only £227.99 inc VAT.
ORDER NOW
MSI Radeon R9 290X Gaming Edition 4096MB GDDR5 PCI-Express Graphics Card @ £275.99 inc VAT
AMD Radeon R9 290X is a new graphics card powered by the latest AMD Radeon™ R9 290X graphics-processing unit (GPU). 4GB of super-fast GDDR5 memory for the best gaming experience at the highest resolutions including 4k and incorporates AMD Eyefinity and TrueAudio technologies to enable expansive multi-display setups and more accurate environmental sounds. R9 290X also includes support for both DirectX® 11.2 and AMD's new Mantle application programming interface (API) for great handling of even the most-demanding PC games.
Specification:
<b>Radeon R9 290X
- GPU: Hawaii XT
- Litecoin Hash Rate: 850-1000
- Stream Processors: 2816
- ROPS: 64
- Core Speed: 1040MHz
- Cooling: MSI Twin FrozR Gaming Cooling
- Warranty: 3yr
Only £275.99 inc VAT.
ORDER NOW
MSI Radeon R9 290X Gaming Edition 8192MB GDDR5 PCI-Express Graphics Card @ £379.99 inc VAT
Specification:
- Radeon R9 290X
- GPU: Hawaii XT
- ROPS: 64
- Warranty: 3yr
Only £379.99 inc VAT.
ORDER NOW
MSI Radeon R9 290X Lightning Edition 4096MB GDDR5 PCI-Express Graphics Card @ £319.99 inc VAT
The MSI R9 290X Lightning is a genuine contender as a powerful gaming card. Not quantified by "for a Radeon", this thing is fast, full stop. Easy, and rewarding to overclock with a fantastic cooler and every option you could want. It's Brilliant. It's Rapid. It's Yellow. It's a worthy winner of our OC3D Gold Award and the best Radeon card on the market today.
Features:-
- Triple Level Signals: Show the real time GPU load by different colours
- TriFrozr Thermal Design: Triple PWM fans with independent control system on
- Pure Digital PWM Control: Digitally controlled GPU, Memory and VDDC.
- Twin BIOS: Seperated BIOS chips for regular use and LN2 overclocking.
- Enhanced Power: 12 GPU phases and 3 memory phases on a custom designed 12 layers PCB for amazing overclocking potential.
- Military Class 4 Components pass MIL-STD-810G certificatiomn for best stability and quality.
- Equipped with CopperMOS, Hi-C CAPS, New SFC and All Dark Solid CAPs.
- Triple Overvoltage: Total control with GPU, Memory and PLL voltage adjustment.
- Triple Temp Monitor: Real time monitoring of GPU, Memory and PLL Conditions.
- V-Check point: For direct and accurate read-out of GPU, memory and PLL voltage.
Specification:-
- Radeon R9 290X
- GPU: Hawaii XT
- ROPS: 64
- Core Speed: 1080MHz
- Memory Speed: 5000Mhz (Samsung IC)
- 750W or greater PSU required
- Power Connectors: 2x 8-pin + 1x 6-pin required
- Warranty: 3yr
- Download PDF Presentation: https://www.dropbox.com/s/9kkxjuw2a0n421v/R9 290X LIGHTNING Infokit 1_0 - PDF Version.pdf
Only £319.99 inc VAT.
ORDER NOW
Powercolor Radeon R9 290 PCS+ OC 4096MB GDDR5 PCI-Express Graphics Card @ £215.99 inc VAT
PCS+ Version features Powercolor's amazing tri-fan cooler, for much lower noise levels whilst offering superior cooling. Along with a great overclock out the box, this card runs at 1040MHz core and 5400MHz memory.
Specification:
- Radeon R9 290
- Coil Whine Reduction Technology (Exclusive to Powercolor)
- GPU: Hawaii Pro
- Memory Speed: 5400Mhz
- Cooling: 2-Slot Blower Fan
- Warranty: 2yr
Only £215.99 inc VAT.
ORDER NOW
Powercolor Radeon R9 290X 4096MB GDDR5 PCI-Express Graphics Card @ £221.99 inc VAT
Specification:
- Radeon R9 290X
- GPU: Hawaii XT
- ROPS: 64
- Core Speed: 1030MHz
- Fan Speed: 20% - 40% (Quiet Mode) & 20%-55% (Uber Mode)
- Warranty: 2yr
Only £221.99 inc VAT.
ORDER NOW
Powercolor Radeon R9 290X PCS+ OC 8192MB GDDR5 PCI-Express Graphics Card **OcUK Exclusive** @ £379.99 inc VAT
PCS+ Version features Powercolor's amazing tri-fan cooler, for much lower noise levels whilst offering superior cooling. Along with a great overclock out the box, this card runs at 1050MHz core and 5400MHz memory.
AMD Radeon R9 290X is a new graphics card powered by the latest AMD Radeon™ R9 290X graphics-processing unit (GPU). 8GB of super-fast GDDR5 memory for the best gaming experience at the highest resolutions including 4k and incorporates AMD Eyefinity and TrueAudio technologies to enable expansive multi-display setups and more accurate environmental sounds. R9 290X also includes support for both DirectX® 11.2 and AMD's new Mantle application programming interface (API) for great handling of even the most-demanding PC games.
Specification:
- Radeon R9 290X
- GPU: Hawaii XT
- ROPS: 64
- Memory Speed: 5500Mhz
- Comes with BF4 Voucher included in the box
- Warranty: 2yr
ORDER NOW
Sapphire Radeon R9 290 Tri-X OC 4096MB GDDR5 PCI-Express Graphics Card (11227-00-40G) @ £221.99 inc VAT
Specification:
- Radeon R9 290
- GPU: Hawaii Pro
- Core Speed: 1000MHz
- Memory Speed: 5200Mhz
- Warranty: 2yr
ORDER NOW
Sapphire Radeon R9 290 Vapor-X OC 4096MB GDDR5 PCI-Express Graphics Card (11227-04-40G) @ £233.99 inc VAT
Sapphires 290 Vapor-X is the fastest 290 on the market with a core clock of 1050MHz but even more impressive is the 5600MHz memory clock and with 4GB of RAM making this card perfect for 4K resolution and latest games such as Titanfall, Diablo 3 etc.
The Vapor-X cooler is simply the best cooler available full stop on any 290 card, it operates in near silence but has incredibly powerful cooling ability making this a great card for both gamers and overclockers.
Specification:-
- Radeon R9 290
- GPU: Hawaii Pro
- Litecoin Hash Rate: 800-950 <br />
- Memory Speed: 5600Mhz
- Power Connectors: 2x 8-pin required
- Warranty: 2yr
- Kitguru Review: http://www.kitguru.net/components/g...280x-vapor-x-oc-and-r9-290-vapor-x-oc-review/
Only £233.99 inc VAT.
ORDER NOW
Sapphire Radeon R9 290X Tri-X 4096MB GDDR5 PCI-Express Graphics Card (11226-03-40G) @ £259.99 inc VAT
Specification:
- Radeon R9 290X
- GPU: Hawaii XT
- ROPS: 64
- Warranty: 2yr
Only £259.99 inc VAT.
ORDER NOW
Sapphire Radeon R9 290X Vapor-X 4096MB GDDR5 PCI-Express Graphics Card (11226-10-40G) @ £287.99 inc VAT
The SAPPHIRE R9 290X Vapor-X OC features several of the company’s industry-leading technologies and a factory overclock to deliver best in class performance with very low noise.
Based on the award-winning Graphics Core Next (GCN) architecture from AMD with 2816 Stream Processors, the SAPPHIRE R9 290X Vapor-X is an Overclocked edition which boasts 4GB of the latest GDDR5 memory running at 1410 MHz (5.64GB/s effective) and high speed engine clocks of 1080MHz.
SAPPHIRE’s innovative Vapor-X cooling technology allows products to run not only cooler but also much quieter. A Vapor-X product means a virtually silent gaming experience and more headroom to explore performance tweaking!
Choke is an important component of the graphics card. By working with the component engineer, Sapphire’s patent pending choke is 10% cooler and offers 25% more power efficiency than a normal choke. The graphics card will be more reliable and save energy.
Improved reliability and better overclocking are possible by using only high-polymer, aluminum capacitors which posses far superior characteristics than regular aluminum capacitor for a longer product life. When operational temperatures drop by 20°C, the product life span is extended by a factor of ten, when the operational temperature increases by 20°C, the product life span only decreases by 10%.
Along the edge of the card the PCB is extended and one of the copper layers left exposed. An additional heatsink mounted directly to this copper layer allows heat absorbed into the PCB from the GPU and other components to be transferred to the heatsink and cooled by the airflow. This feature alone can reduce core temperature by 2 degree C.
Specification:-
- GPU: Hawaii XT
- ROPS: 64
- Core Speed: 1030MHz >
- Memory Speed: 5300Mhz
- Warranty: 2yr
Only £287.99 inc VAT.
ORDER NOW
Sapphire Radeon R9 290X 8192MB GDDR5 PCI-Express Graphics Card **OcUK WorldWide Exclusive** @ £359.99 inc VAT
As requested by our customers and actioned by us here at OcUK this is the worlds ONLY reference PCB and reference blower cooler 8GB card available and only exclusively from OcUK in the world. Perfect for customers who want to run 3-way or 4-way crossfire or fit waterblocks. Once again OcUK delivers because we listen to our customers!
Specification:-
- Radeon R9 290X
- GPU: Hawaii XT
- ROPS: 64
- Warranty: 2yr
Only £359.99 inc VAT.
ORDER NOW
Sapphire Radeon R9 290X Vapor-X OC 8192MB GDDR5 PCI-Express Graphics Card **OcUK WorldWide Exclusive** @ £379.99 inc VAT
OcUK has a worldwide exclusive on the only 8GB 290X in existence, but this is not any 290X it's a highly fine tuned machine being the Vapor-X edition with near silent cooling solution. Running with a 1060MHz core clock and with memory clocked at 5600MHz makes this card absolutely perfect for a 4K setup, even more so with a pair or three of these in Crossfire. That means you could play games like Skyrim with expansion packs at 4k resolution and still not run out of VRAM.
Based on the award-winning Graphics Core Next (GCN) architecture from AMD with 2816 Stream Processors, the SAPPHIRE R9 290X Vapor-X is an Overclocked edition which boasts 8GB of the latest GDDR5 memory running at 1400 MHz (5.60GB/s effective) and high speed engine clocks of 1060MHz.
Specification:-
- GPU: Hawaii XT
- ROPS: 64
- Warranty: 2yr
ORDER NOW
XFX Radeon R9 290 DD 4096MB GDDR5 PCI-Express Graphics Card (R9-290A-EDFD) @ £229.99 inc VAT
OcUK has negotiated special RMA terms with XFX which allows OcUK to express RMA any XFX item purchased from ourselves within 48 hours. Also exclusive to OcUK we allow the removal of the stock cooler for those wishing to water-cool their XFX product or change the cooler.
Specification:-
- GPU: Hawaii Pro
- ROPS: 64
- Core Speed: 947MHz
- Card Dimension (cm) : 29.5 x 14.3 x 4.2
- Card Dimension (inch) : 11.61 x 5.63 x 1.65
- Warranty: 2yr
Only £229.99 inc VAT - £199 with XFX290PROMO voucher code!!
ORDER NOW
My Recommendation
1. For price/value the XFX 290 at £199 is unbeatable, sell the FREE games for close to £100 and you just bagged yourself a 290 for £100, incredible!
2. For overclocking Sapphire Vapor-X or MSI Lightning!
3. For lowest possible noise, Powercolor PCS+ cards!
Overclockers UK is the only Etailor in the UK listing 8GB 290X and we also have stock (Sapphire Vapor-X), OcUK also has the lowest price points on 290 (£199) and 290X (£222), we are truly unbeatable and offer the best customer service.
GET YOUR WALLETS OUT!!
ORDER NOW
ORDER NOW
Specification:-
- GPU: 2x Hawaii XT
- ROPS: 128
- Warranty: 2yr
ORDER NOW
Specification:
- Radeon R9 290
- GPU: Hawaii Pro
- Warranty: 3yr
ORDER NOW
Specification:
<b>Radeon R9 290X
- GPU: Hawaii XT
- ROPS: 64
- Warranty: 3yr
ORDER NOW
Specification:
- Radeon R9 290X
- GPU: Hawaii XT
- ROPS: 64
- Warranty: 3yr
ORDER NOW
Features:-
Specification:-
- Radeon R9 290X
- GPU: Hawaii XT
- ROPS: 64
- Warranty: 3yr
ORDER NOW
Specification:
- Radeon R9 290
- GPU: Hawaii Pro
- Warranty: 2yr
ORDER NOW
Specification:
- Radeon R9 290X
- GPU: Hawaii XT
- ROPS: 64
- Warranty: 2yr
ORDER NOW
Specification:
- Radeon R9 290X
- GPU: Hawaii XT
- ROPS: 64
- Warranty: 2yr
ORDER NOW
Specification:
- Radeon R9 290
- GPU: Hawaii Pro
- Warranty: 2yr
ORDER NOW
Specification:-
- Radeon R9 290
- GPU: Hawaii Pro
- Warranty: 2yr
ORDER NOW
Specification:
- Radeon R9 290X
- GPU: Hawaii XT
- ROPS: 64
- Warranty: 2yr
ORDER NOW
Specification:-
- GPU: Hawaii XT
- ROPS: 64
- Warranty: 2yr
ORDER NOW
Specification:-
- Radeon R9 290X
- GPU: Hawaii XT
- ROPS: 64
- Warranty: 2yr
ORDER NOW
Specification:-
- GPU: Hawaii XT
- ROPS: 64
- Warranty: 2yr
ORDER NOW
Specification:-
- GPU: Hawaii Pro
- ROPS: 64
- Warranty: 2yr
ORDER NOW
My Recommendation
