What's the most banal or vapid thing you've said or heard recently?
Someone in the lift at work asked if I was "going down?"
The building only has 2 floors.
We were on the 1st floor.
"Wearing a coat?" - while wearing a coat in weather it's normal to wear one.
Must be secret code & you actually scored.
They weren't talking about the lift.
oWWWWW
So you were on the 1st floor you could have gone up or down, ground floor, 1st floor and 2nd floor.
No, ground floor is a floor too and is "ground floor", you can only go down from the 1st floor, the buttons on the lift actually state 1st or ground floor. Let's not re-introduce the banality of the escalator thread in here.
So you was on the 1st floor you could have gone up or down, ground floor, 1st floor and 2nd floor.
No.
He said the building has two floors which means Ground floor & First floor.
Quite why he didn't use the stairs though I don't know, lazy sod.
But if an airplane was on a treadmill would it take off?
You pose a good question....
No.
It's too cold to walk outside round to the other side to the door entry to the stairs via reception.
Lazy sod is about right then :p
