Just a couple of questions, on my 970 MSI im running my main monitor on DP and second on DVI.
As soon as I turn my PC on, the DVI monitor is showing bios etc... the monitor on DP is just sat there waiting for a signal. Once in windows it works.
I just cleaned out my old nvidia drivers and then booted back into windows to install the new ones. The monitor on the DP would not work. So I take it, it needs drivers for the DP to work? This seems rubbish if you had one monitor on DP only.
