The time is nigh V2
Already ordered. xD
kpu5UQDzp
depending on the time you orders because you used amazon your parts may be with you today.
I doubt it, it still would have been dispatched by Overclockers and they only spec Saturday delivery, unless DPD are being generous :p.
If anything he should get it tomorrow as they do have a Saturday pickup belongs it was shipped before lunchtime.
I've been emailed that it will be delivered on Monday.
1440p would be ideal for it. If you've got the cash why not go ROG Swift surround? (1440p + 144hz).
To be honest you should be looking at doing a custom loop for it. Its gonna get hot and possibly loud.
For me, I dont think the ROG Swift is worth it for me. Not only is the 3D, but I've never experienced the screen tearing that gsync fixes
Except graphic cards.... Caviar Greens with 3k setup.. really (should take Toshibas instead) ?
OEM operating system means (AFAIK, but I might be wrong in case of Win 8) selling PC = you have to sell OS as well.
Where is DVD drive ? :)
And good sound card ;-)
Please actually look at one of these monitors in action before discounting them. I know they are expensive but the experience of 144hz @ 1440 is something I didn't really "get" till it was in front of me and my face was like :eek:
HAVE A LOOK AT THIS THREAD (BEGINNING) to learn a bit more about G-Sync. It's the overall smoothness that is affected - Something that would definitely be a positive if pushing 3 x 1440 monitors even with your 3 way SLI 980's. You will hammer your 4GB cards at that resolution I would imagine! But that is what it's all about.
Also - Nice build :cool:Get it water-cooled though as mentioned :D
Also not to be negative - I would have personally gone for Reference 980's - 3 way SLI is going to dump SO much heat into your case and I'm guessing the "gaming edition" may use a non reference PCB making watercooling more difficult? - Reference coolers are by far the best at getting that heat out of your case in my experience.
