Big upgrade advice
26 Apr 2014
Hello. I'm planning to upgrade my pc and I need advice if all the parts which I choose are good and compatible.
My budget is around 500£. That's what I choose atm:
Cpu: i5 4460 -
Mobo: Msi h81m-e35 -
Ram: 8gb Corsair ddr3 1600mhz -
Gpu: Evga gtx 770 2gb -
Psu: Cooler Master gm550w -
All together is around 520£
Case I have already (nzxt phantom 240) and hdd plus all peripherals also. Do u think that set up is good? Thx
Hi,
Buy from OcUK.
I think you can start with this bundle,
YOUR BASKET
1 x Asus H81M-K Intel Core i5 DIY Micro ATX Motherboard, CPU & RAM Bundle £225.97
Total : £235.57 (includes shipping : £8.00).
This PSU,
YOUR BASKET
1 x SuperFlower Golden Green HX 550W "80 Plus Gold" Power Supply - Black £59.99
Total : £69.59 (includes shipping : £8.00).
Then this GFX card,
YOUR BASKET
1 x XFX Radeon R9 290 DD 4096MB GDDR5 PCI-Express Graphics Card (R9-290A-EDFD) £229.99
Total : £239.59 (includes shipping : £8.00).
Which you can get £30 off - http://forums.overclockers.co.uk/showthread.php?t=18631947
But you will need to take the middle HDD cage out of the NZXT case to fit it in as it is 295mm long.
So all in all it comes to this,
YOUR BASKET
Total : £525.55 (includes shipping : £8.00).
And minus £30 for the gfx card deal and that's £500 which is your budget.
I would suggest you edit your post my friend as there is no mention of competitors in this forum, its in the rules. im suprised you missed this stulid.
It was hiding away. thanks for the spot.
I've edited out the name and competitor prices.
Sorry I just didn't know that. I will edit my post . The only reason why it's need to be from there is coz I want to take for pay monthly credit (can't afford to spend in one go) and I need it as soon as possible . With my current rig I can't play fc4 which I really want to play.
Then unfortunately you are on the wrong forum to be discussing this.
P.S OcUK do finance.
http://www.overclockers.co.uk/LP/fi...ner&utm_content=logolink&utm_campaign=finance
If it also helps here is a R9 290 vs GTX770 comparison - http://www.anandtech.com/bench/product/1068?vs=1037
There are some Bgrade items available if used parts doesn't worry you?
YOUR BASKET
1 x Intel Core i5-4690K 3.50GHz (Devil's Canyon) Socket LGA1150 Processor - Retail £173.99
1 x **B Grade** MSI Radeon R9 290 Gaming Edition 4096MB GDDR5 PCI-Express G (GX-239-MS) £169.99
1 x Gigabyte Z97P-D3 Intel Z97 (Socket 1150) DDR3 ATX Motherboard £61.99
1 x TeamGroup Xtreem LV "Frost Edition" 8GB (2x4GB) DDR3 PC3-21300C11 2666MHz Dual Channel Kit £59.99
Total : £535.55 (includes shipping : £8.00).
One final question is are all your drives SATA and not IDE?
