How fast is USB 3 meant to be?
20 Dec 2008
I bought an external HDD and I'm getting a top speed of 60MBps, this is after installing a USB 3 driver when previously it was using USB 2 with a speed of 28MBps. USB 3 is enabled in my BIOS. My motherboard is an MSI P67A-GD53.
625 MB/s, A normal hard drive is not going to reach anywhere near that though. 60MB/s could be about right for a 2.5" 5400rpm external.
Nope external HDD only maxed up to 100MB/s, if you want to get nearly USB 3.0's 625MB/s performance, you could need a 2.5 inch external caddy with SSD to achieve up to 550MB/s.
My USB 3.0 3.5" 2TB will hit just over 200 MB/s, my USB 3.0 500Gb Toshiba and 2TB WD Passport 2.5" HDD's hit around 100 MB/s.
Official USB site
SuperSpeed USB (USB 3.0) from the USB-IF
SuperSpeed USB has a 5 Gbps signaling rate
5Gbps = 625MBps.
Bear in mind with that write caching will give deceptive speeds on smaller transfers as you are writing at full speed to the drives cache to start with.
Combat squirrel, might be worth you benchmarking the external SSD to see if its performing properly.
Really? There are no 7200rpm consumer grade internal HDD's that will do that
Both HDD's are the same internal 2TB Seagate 7200rpm drives, but I use my own separate USB 3.0 enclosure for the external one.
External USB 3.0 Seagate 2TB 7200rpm.
Internal Seagate 2TB 7200rpm.
