Hi,
I just got an i5 750 as a replacement for my i3 530 from eBay, sold as tested and working. Put it into my machine last night and it wouldn't power up or post. Some leds flash on the motherboard and the fans momentarily spin up, however it doesn't beep or post.
Took the chip out and checked all the socket pins with a loupe and they look ok, put the i3 back in and it posts/boots fine including the 4.6 ghz overclock.
I tried all combinations of ram and gpu with the i5 to no avail, even just the cpu on its own have the same result with no beep codes. The cmos was reset multiple times.
Is it possible that the psu might not be giving the cpu enough juice on startup? The i5 uses 22w more than the i3 but I wouldn't have thought this would manifest as a problem posting? My psu is an old ocz modstream 520 which whilst pretty long in the tooth these days has never given me any problems in the past. I can probably borrow a modern psu from work to test but is it likely or am I clutching at straws? The eBay seller does have a returns policy so not the end of the world but it is annoying.
Any advice would be much appreciated
