and yes I'm on the internetes in traffic lol
Not really your place to be moaning about bad drivers then.
A lot of people seem to turn their headlight level to the highest setting. At that angle it's just as bad.
You mean the dial inside the car? All that does it lower the headlight beam, not raise it.
read what you just typed.
what happens to the headlights when you turn that dial the opposite way?
[TW]Fox;27201919 said:No, he's right - the default position, ie the correct one for normal driving, is maximum height. You use the lever to lower the headlights when the car is heavily loaded or towing a trailer.
Therefore people don't blind you because they've fiddled with the lever (Unless they have a caravan).
yeah, but not to sound pedantic the dial works both ways. to say it only lowers the headlights is incorrect. if the headlights are lowered then the dial will raise them. no?
