- 5 Aug 2006
- Derbyshire
My 2007 Focus Ghia has 205 55 R16 Michelin Primacy HPs all round.
Why?
Well I bought the car from my Dad just after he had put new Primacy HPs on the back, so six months later when the fronts needed doing I put the same on the front.
The fronts need replacing ASAP. The rears are probably 40-50% worn.
The tyre has been pretty good but not outstanding.
Do I put new Primacy HPs on the front to keep the same tyre all round?
Do I go with a better tyre for the price? Looking to spend up to £80. I do lots of motorway miles in all weather so I have no interest in cheap rubbish.
I will most likely be using Black Circles.
EDIT: Kwikfit are £141.20- for two Efficient Grip Performance tyres fitted plus £20 cash back.
Why?
