Hello
Experts PLEASE HELP ME, i am desperate, i can not fix this problem for six months already
i Have 2 sets of this RAM: Avexir Blitz 1.1 Original 8GB (2x4GB) DDR3 PC3-22400C12 2800MHz Dual Channel Memory Kit (AVD3UH28001204G-2BZ1)
http://http://www.overclockers.co.uk/showproduct.php?prodid=MY-066-AR&groupid=701&catid=8&subcat=1392
this motherboard: Gigabyte Z87X-OC Force Intel Z87
http://www.overclockers.co.uk/showproduct.php?prodid=CP-539-IN&groupid=701&catid=6&subcat=567
Machine was running with 4770k with no problem using XMP profile on RAM and had 0 problems. Now i have upgraded to 4790k and whenever i set frequency higher than 1600Mhz it crashes. Windows still loads but there are many errors due to RAM. I tried to use XMP, tried to set manually, set higher timings up to 20-20-20-40 but nothing helps.
I have updated bios to beta f10b, did not help, returned back to f9, the same.
I put the 4770k back and it runs Memtest86+ and SuperPI like charm, no crashes. No problem using XMP or set settings manually.
I tried this on Asus Z97 Deluxe Intel Z97 board as well, same story.
I am going to throw 4790k in the bin or sending it back
Any ideas guys?
Last update: I have managed to run them at 2400Mhz 12,16,16,36 1,65volts
BTW this MOBO Gigabyte Z87X-OC Force is biggest rubbish i ever have seen (have 5 PC's running at the moment and not one gives me problems like this one)
Any ideas guys?
