Asus Strix 980 Covered By Warranty Removing Heatsink ?
Yes asus cover this I asked myself (As long as you don't break any stickers/seals) most of their GPUS come with stickers or warranty void on a part that wont make it break when taking the heatsink off
Brilliant thanks bud, Will be replacing the stock TIM with some IC-Diamond, Based off of other people and IC's testing themselves it has dropped load temps by as much as 4-6'c depending on the scenario.
Sorry to hijack but would this apply to the Asus 280X as well?
Yeah, I would assume so.
TBH I no longer ask or take any of this into consideration when removing heatsinks. As long as they can't/don't know there is nothing to worry about. Most of the warranty void stickers can be bypassed (MSI ones are super easy) and OcUK support are always there to help you.
