The AMDs have poor power efficiency though. Spend the bit extra on an i5 and you'll make it back in lower power bills.
So for me it's Pentium, FX 6300, FX 8320, I5 4690k, I7 4790k etc.
Perfect answer grounded in facts.
At stock speeds the difference is around about 100 W. If you ran your CPU at full load 24 hours a day 7 days a week that would be a difference on your bill of about £10 a month, or about 1 p an hour.
In other words, to make the £80 outlay back that you claim he will would take over 8 months of constant 100% usage.
http://www.xbitlabs.com/articles/cpu/display/fx-8350-8320-6300-4300_8.html
Fair point, however the i5 is about 25% faster than the 8320 at stock speeds, and the price difference is £43 at OcUK...
I'm not here for a fight, or points scoring. I couldn't give a toss about CPU brand loyalty. I'd buy an i5 given the OPs requirements.
25% faster? At the very most in games the i5 is 15% faster (minimum FPS). 0-10% is more common. Compare the i5-4690 to the 7850K (an APU that's got half as many cores as the 8320):
http://www.anandtech.com/show/7963/...iew-core-i7-4790-i5-4690-and-i3-4360-tested/9
(That minimum in F1 looks dubious, I'd be much more inclined to trust the 99th percentile charts.)
This isn't a fight, I just think people should get accurate advise backed up by data.
So given £150 to buy the best bang per buck gaming CPU, you'd buy a £108 AMD and hand back £42?
Depends on the whole budget. If the budget is tight that £42 should go on a better GPU. That's almost the difference between a 280 and a 290 for example, and you'll get way better FPS with an 8320 + 290 than a locked i5 + 280 (up to 50% more).
It really depends what he will be spending most of his time playing.
What is the point of overspending on a GPU if he is playing CPU intensive games?
Just the same as the reverse...what would the point be in overspending on a CPU if he is mainly playing GPU intensive games?
Hey all,
What is currently the best bang for buck gaming cpu for around £150 mark,
