Wanted - Laptop for travel and photography.
8 Sep 2009
Hi there, I'm looking for a laptop to travel with and use with my portable photography and I'm not really on point with whats available and whats worth looking at.
Its got to -
be portable (13 or 15 inch?)
have a nice screen
be able to handle tetherered shooting, capture one or lightroom
be able to handle basic lightroom editing, main editing done on home desktop
have hdmi out
for watching films and surfing net.
Any pointers would be appreciated, I wont be gaming on it and I have a mid sized budget. I don't like macs either.
Thanks
Hi blasted,
From looking at your requirements, you should consider:
AORUS X3
AORUS X3 Plus
and also P34G fits your criteria quite nicely.
Hope that helps,
Regards,
Gigabyte UK NB Team
Its got to -
have a nice screen
have hdmi out
Thanks
Hi there, what's your budget on this?
Regards
edit*
ahh I mis-read. This should be ok for basics. The i5 is a half decent CPU for sure. No dedicated GPU tho.
If you spent a little bit more, you could get that.
ARJiBEAR
Is a dedicated graphics gpu be something I should get? the next version of this model up has better graphics and 16gb of ram but weighs in at about £750.
