Guys.
I've just ordered a B Grade Gigabyte GTX 970 G1 on OCUK. It was £50 less than a new one, this seems like quite a good saving. I know these are likely to be returns, maybe due to coil whine? I'm not too worried about this though (unless it's really really loud).
When I get it, I just want to run a quick test on it to make sure it's all ok. Is there a good diagnostic application that I can use to do this? Is GPUz sufficient? I don't want to stress test it or anything (I've never OCd my graphics cards), I just want to make sure the card is ok and working within normal parameters/temperatures etc.
I can return it within 14 days if there are any issues.
Any advice from you gurus would be appreciated.
I would not have ordered B Grade from anywhere else, I trust OCUK so happy to take a chance.
Thanks.
Thanks.
