Help me play pes2015 online
31 Jul 2013
Edinburgh
Hi,
Struggling big time to play pes2015 online. I am unable to join match rooms and nobody can join any I create.
I am on a Virgin Media Superhub 2. When I change the hub to modem mode and plug the ps4 into the hub it works great (NAT Type 1) I can join games and play fine. The problem is when I'm in router mode. (NAT Type 2) I have tried forwarding all the correct ports, turned the firewall off, made the ps4 the dmz. Tried setting up the internet connection manually on the ps4. turned auto port off in the settings menu inside pes. tried connecting through wifi. Just cannot connect to others :(
Anyone got any ideas I could try?
Thanks
Isn't NAT type 2 open? I had PES last week and I couldn't connect to anyone but I thought it was an issue with the game.
NAT Type 1 (Open) – You are either NOT behind a router/firewall OR you have already DMZ enabled. You shouldn’t run into any issues whilst gaming, but this may cause security issues.
NAT Type 2 (Moderate) -Your PS3/PS4 is connected properly and you shouldn’t run into any issues.
NAT Type 3 (Strict) – You may be able to connect to the PSN and perform downloads/updates other functions may not work as intended.
It's all down to Konami and they are apparently working on it.
Great game offline but terrible online including button lag (again).
