Hey people,
So I have been working with a customer who wanted some wifi extenders put it but wanted them wired up. All the rooms in the 3 story house have 2 CAT5E cables with 1 on them terminated to a wall faceplate, the other is loose inside the wall.
The room where all these cables go to is a small cupboard but only about 3 of them are labelled. Not only this but these cables are solid core and I can't for the life of me seem to fit a RJ45 connector on the end of them without crossing wires somewhere. This made the whole evening of fitting these extenders worthless.
I have spoken to the client and suggested we wire all of the ends up to a patch bay but we would also need a cabinet to house the patch bay in. He said it would be even better if all of these cables were wired so they could be used instantly. So this means a switch as well.
So I'm assuming my materials list is this:
Wall Mounted Cabinet
1x 24 Port switch
1x Patch Bay
24x Patch Cables
He already has 1 switch for the CCTV cameras so I said how all the equipment they have can be put in the cabinet. He seems quite happy to do this and knows the cost.
I would just like to ask if anyone has any recommendations as to cabinets, switches or perhaps would like to suggest anything else?
I was thinking about creating a short cable with one end bare and plugging it into a cable tester and touching the bare ends to the ends of the cables but because it's solid care cable I would still have to strip the cable and this doesn't really speed up the process when I could just punch the cable into a patch bay. It's really annoying that they are not labelled
but I can see how an electrician doesn't really care and all that was asked was the cable to be fitted.
Thoughts?
1x 24 Port switch
1x Patch Bay
24x Patch Cables
but I can see how an electrician doesn't really care and all that was asked was the cable to be fitted.Thoughts?
