X99 Dual Channel vs Quad Channel
8 Aug 2010
Essex
I'm set on going X99. CPU ordered and decided on pretty much everything but the RAM.
Should I get 2X8GB sticks (Crucial Ballistix) or 4x4GB (other brand)?
The former will give me more expandability, although I don't see myself maxing out the memory on this platform (64GB on Asus X99-S) unless memory prices drastically drop.
I'm just wondering if the potential benefits of Quad Channel outweigh the drawbacks of DIMM capacity.
Cheers.
Cheers.
AFAIK - if you run only two sticks of ram they will only run in dual channel mode, which somewhat defeats the object of going for X99. I would suggest you go for a 4x4Gb ram set. That said the performance loss of dual v quad will probably not be really noticeable except in benching etc. Depends on your usage really etc.
Mark
If I bought a quad channel board and only used it in dual channel, I wouldn't sleep right.
Even if it's a 1% performance increase, I'd have to get quad channel.
Mark
I didn't think there would be a noticeable difference.
Would you be able to sleep at night running 32GB on a board capable of handling 64GB? ;)
That's the way I'm seeing it. Getting 4GB modules wouldn't allow me the possibility of maxing out the memory down the line without selling the existing modules.
If quad channel was all that 1150 would support it IMO.
I wouldn't lose any sleep over it. Triple channel made barely any difference over dual channel when it was released.
if the performance difference of 2 channel was minor...and the expected price trajectory of ddr4 (steeply) downwards.....and the affordability in short term restricted..and the expected performance/specification of ddr4 development (steeply) upwards...then may be a good case to go for two sticks..
would need to seem some analysis of real workloads to establish the 2 channel vs 4 data point...
For me (games playing, transcoding and encoding), i cant forsee the need to increase beyond 16Gb for my needs, i dont think specification increases will make enough of a difference to care, its affordable enough..
4x4 is still expandable if necessary (but by that time..there may be very little residual value in the 4x4 in any case)
so i will go for 4x4...
X99 is all about bandwidth, why sacrifice
not really imho, more about the 6 core processors and pci -e lane counts that actually make sense for multiple gpus.
While I'm sure quad channel is nice, most of the advantage is just from the move to higher speed DDR4. Outside of synthetic benches I wouldn't expect more than a 5% improvement.
Struggling to find any non synthetic benches that compare single/dual/quad channel, but expect most sites are not allowed to if covered by Intel's reviewing guidelines.
Man buys brand new Ferrari...... AND:
Puts 95 RON supermarket petrol in it, fits the cheapest tyres he can find, and gets it "cleaned" by the £5 guys in the shopping centre carpark.
Mmmmmm savings!;)
