<<<<< BLACK FRIDAY DEAL: MASSIVE SAVINGS ON DDR3 & DDR4 !!! >>>>>
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
I've now finished all my memory deals for Black Friday, that means pricing goes back up Tuesday next week, grab a memory kit bargain this weekend:
Kingston HyperX Savage Red 16GB (2x8GB) DDR3 PC3-19200C11 2400MHz Dual Channel Kit (HX324C11SRK2/16) @ £123.95 inc VAT
Attack the competition with HyperX® Savage memory. Its unique, asymmetrical red heat spreader is made from high-quality aluminum and has a black PCB and a diamond cut finish to make your game shine and help you stand out in the crowd. The heat spreader dissipates heat so your system stays cool and reliable and its low profile fits under oversized CPU coolers. HyperX Savage is XMP Ready and comes in a range of speeds from 1600MHz to 2400MHz. Its trend-setting design puts you and your system ahead of the game.
Features:-
- Fast - top-performing modules available with low-profile heat spreader
- Unique - red, asymmetrical heat spreader sets new trends for PC builds
- Quality - aluminium die-cast heat spreader with a diamond cut finish
- Design - low profile to fit under oversized CPU coolers
- Reliable - 100-percent factory tested
- Guaranteed - lifetime warranty, free technical support
Specification:-
- Capacity 4GB-8GB (single), 8GB-32GB (kits)
- Frequency Speed 1600MHz, 1866MHz, 2133MHz and 2400MHz
- CAS Latency CL9-CL11
- Voltage 1.5V, 1.65V
- Operating Temperature 0°C to 85°C
- Storage Temperature -55°C to 100°C
- Dimensions 133.35mm x 32.8mm
- Compatible with H67, H97, P67, Z68, Z77, Z87, Z97 and H61 Intel chipsets, as well as A75, A87, A88, A89, A78 and E35 AMD chipsets
- Warranty: Lifetime
Was [£149.99] Inc. VAT
Only £123.95 inc VAT.
ORDER NOW
TeamGroup Xtreem LV 16GB (2x8GB) DDR3 PC3-21300C11 2666MHz Dual Channel Kit (TXD316G2666HC11CDC01) @ £109.99 inc VAT
Team Xtreem LV is the most popular overclocking and gaming gear in the LAN party. Based on the memory architecture evolution on Intel Core i7, Team raises the frequency of the Xtreem LV DDR3 by 20% from 2000MHz to 2400MHz. Also, by continuing the high frequency and low latency tradition of the Xtreem LV memory, the Xtreem LV DDR3 2400 can fully display the configuration 9-11-11-28 (tCL-tRCD-tRP-tRAS) at a low operating voltage at 1.65V without sacrificing either performance or stability. All these have witnessed the extraordinary R&D capacity and capability of Team. In addition to the unchanged genuine chip policy, Team ensures chip quality with the exclusive sorting technology to screen chips. In order to further ensure the optimal performance and flawless quality of the Xtreem LV DDR3 2400, Team applies the 24-hour burn-in test and industry-approved MemTest software to perform the OQC inspection of all modules before shipping to assure the stability and exceptional performance of every Xtreem LV DDR3 2400. The Xtreem LV DDR3 2400 from Team has a conventional 8-layered PCB design and is covered with the X-mark heat-sink labeled for the Xtreem series. In addition to the clean appearance as found in all Team Xtreem memory modules, a groove has been added to the heat-sink for power users to install fans on top to enhance ventilation. For more information on this product, please visit the Team Group website at: www.teamgroup.com.tw.
Features:-
- Module Type 240Pin Unbuffered DIMM Non ECC
- CL-tRCD-tRP-tRAS 11-13-13-35
- DRAM Density 128x8 / 256x8 / 512x8
- Data transfer bandwidth 21,300MB/Sec (PC3 21300)
- Heat Sink Aluminum heat-sink
- Working voltage 1.65V
- Warranty Lifetime warranty
- Note Intel XMP1.3, compatible with series Intel 7 chipsets and higher.
Was [£139.99] Inc. VAT
Only £109.99 inc VAT.
ORDER NOW
TeamGroup Xtreem LV "Frost Edition" 16GB (2x8GB) DDR3 PC3-21300C11 2666MHz Dual Channel Kit @ £129.95 inc VAT
Team Group Inc. has once again led the industry and released the world’s limited dual-channel Xtreem DDR3 2666. Intel’s latest Series Z77/Z87 chipsets. As it adopts strictly selected chips from original factories and has to pass through stringent tests and verification procedures, it is able to enhance even further its support capabilities after teaming up with the latest Intel XMP V1.3 version. In addition, it is also collocated with eight-layer PCB in order to increase its stability performance by up to 16GB (4GBx4) large capacity. Its built-in ultra-high clock design is able to allow the computer operation to reach an unimpeded speed.
Features:-
- Black PCB
- White Heatsink
- DRAM Density 256x8
- Data transfer bandwidth 21,328MB/Sec (PC3 21300)
- Heat Sink Yes
Was [£169.99] Inc. VAT
Only £129.95 inc VAT.
ORDER NOW
TeamGroup Xtreem LV "Frost Edition" 8GB (2x4GB) DDR3 PC3-19200C10 2400MHz Dual Channel Kit @ £59.99 inc VAT
Team Xtreem LV is the most popular overclocking and gaming gear in the LAN party. Based on the memory architecture evolution on Intel Core i7, Team raises the frequency of the Xtreem LV DDR3 by 20% from 2000MHz to 2400MHz. Also, by continuing the high frequency and low latency tradition of the Xtreem LV memory, the Xtreem LV DDR3 2400 can fully display the configuration 10-12-12-31 (tCL-tRCD-tRP-tRAS) at a low operating voltage at 1.65V without sacrificing either performance or stability. All these have witnessed the extraordinary R&D capacity and capability of Team. In addition to the unchanged genuine chip policy, Team ensures chip quality with the exclusive sorting technology to screen chips. In order to further ensure the optimal performance and flawless quality of the Xtreem LV DDR3 2400, Team applies the 24-hour burn-in test and industry-approved MemTest software to perform the OQC inspection of all modules before shipping to assure the stability and exceptional performance of every Xtreem LV DDR3 2400. The Xtreem LV DDR3 2400 from Team has a conventional 8-layered PCB design and is covered with the X-mark heat-sink labeled for the Xtreem series. In addition to the clean appearance as found in all Team Xtreem memory modules, a groove has been added to the heat-sink for power users to install fans on top to enhance ventilation. For more information on this product, please visit the Team Group website at: www.teamgroup.com.tw.
Features:-
- Black PCB
- White Heatspreader
- CL-tRCD-tRP-tRAS 10-12-12-31
- Data transfer bandwidth 19,200MB/Sec (PC3 19200)
Was [£71.99] Inc. VAT
Only £59.99 inc VAT.
ORDER NOW
TeamGroup Vulcan RED 16GB (2x8GB) DDR3 PC3-19200C11 2400MHz Dual Channel Kit (TLRED316G2400HC11CDC01) @ £107.99 inc VAT
Named after the god of fire in Greek mythology, the Team Vulcan is the combination of high-end craftsmanship and top-notch technology. The short version heat sink of Team Vulcan prevents difficulty in installation due to large and bulky heat dissipation device of motherboard. The arrow-shaped opening design helps increase heat dissipation. In addition, the explosively red color combined with diamond cut pattern not only shows great texture but also the crazy sensation of over-clocking speed.
Made of chips from major manufacturers, Team Vulcan passes series of harsh testing and verification procedures which have proven its stability and durability. Currently, DDR3 2400 CL10, DDR3 2133 CL11, DDR3 1866 CL9/10/11 and DDR3 1600 CL9 are available to cover the mainstream Dual- and Quad-channel specifications that pretty much satisfy the demands of players of all levels.
Features:-
- Working voltage 1.55V-1.65V
- Haswell & AMD Richland compatible
Only £107.99 inc VAT.
ORDER NOW
TeamGroup Vulcan RED 8GB (2x4GB) DDR3 PC3-19200C11 2400MHz Dual Channel Kit (TLRED38G2400HC11CDC01) @ £56.99 inc VAT
Features:-
Was [£65.99] Inc. VAT
Only £56.99 inc VAT.
ORDER NOW
TeamGroup Vulcan ORANGE 8GB (2x4GB) DDR3 PC3-17100C11 2133MHz Dual Channel Kit (TLAD38G2133HC11ADC01) @ £55.99 inc VAT
Features:-
- CL-tRCD-tRP-tRAS 11-11-11-31
- Data transfer bandwidth 17,100MB/Sec (PC3 17100)
Only £55.99 inc VAT.
ORDER NOW
TeamGroup Elite Black 8GB (2x4GB) DDR3 PC3-12800C11 1600MHz Dual Channel Kit (TPKD38G1600HC11DC01) @ £50.99 inc VAT
Keeping abreast with the latest trend to launch new products to replace the old, Team Group is now offering a new choice of superb value expansion with its ELITE DDR3. ELITE DDR3 features outstanding product quality that users have come to expect from Team Group and the product has also passed the strictest tests for quality assurance. Not only that, Team Group’s ELITE DDR3 is manufactured with full compliance to the specifications prescribed by JEDEC (Joint Electron Device Engineering Council) and has gone through extensive burn-in tests. ELITE DDR3 features standard 240 Pin design and operates on 1.5V of power to achieve low power consumption with a truly eco-friendly specification. In addition, TEAM ELITE also comes in a variety of selections with varying frequencies and capacities to satisfy consumers with different needs.
Features:-
- Module Type 240Pin L-DIMM 1600
- CL-tRCD-tRP-tRAS 11-11-11-28
- DRAM Density 256x8 / 512x8
- Data transfer bandwidth 12,800MB/Sec (PC3 12,800)
- Working voltage 1.5V± 0.075V
Was [£59.99] Inc. VAT
Only £50.99 inc VAT.
ORDER NOW
TeamGroup Elite Black 16GB (2x8GB) DDR3 PC3-12800C11 1600MHz Dual Channel Kit (TPKD316G1600HC11DC01) @ £95.99 inc VAT
nonl2br
Keeping abreast with the latest trend to launch new products to replace the old, Team Group is now offering a new choice of superb value expansion with its ELITE DDR3. ELITE DDR3 features outstanding product quality that users have come to expect from Team Group and the product has also passed the strictest tests for quality assurance. Not only that, Team Group’s ELITE DDR3 is manufactured with full compliance to the specifications prescribed by JEDEC (Joint Electron Device Engineering Council) and has gone through extensive burn-in tests. ELITE DDR3 features standard 240 Pin design and operates on 1.5V of power to achieve low power consumption with a truly eco-friendly specification. In addition, TEAM ELITE also comes in a variety of selections with varying frequencies and capacities to satisfy consumers with different needs.<br /><br />
Features:-<br />
- Module Type 240Pin L-DIMM 1600 <br />
- CL-tRCD-tRP-tRAS 11-11-11-28 <br />
- DRAM Density 256x8 / 512x8 <br />
- Data transfer bandwidth 12,800MB/Sec (PC3 12,800) <br />
- Heat Sink Aluminum heat-sink <br />
- Working voltage 1.5V± 0.075V <br />
- Warranty Lifetime warranty <br />
Was [£119.99] Inc. VAT
Only £95.99 inc VAT.
ORDER NOW
Avexir Core Red Series 8GB (2x4GB) DDR3 PC3-12800C11 1600MHz Dual Channel Memory Kit (AVD3U16001104G-2IR) - Red Light @ £50.99 inc VAT
nonl2br
<p align="left">
Avexir Core Series is designed specifically for the extreme power users who focus on challenging the excellence in high performance gaming experience. The Core Series is developed by Avexir R&D team with 10+ years’ experience of researching in memory core technology and designed specifically for the power users and gamers who demand ultimate performance and extreme reliability gaming modules.</p>
<p align="left">
Mpower Red Series is designed to be a perfect visual match for Asus ROG, EVGA, Asrock Fatality and MSI Gaming mainboards, giving you a look which shall make you the envy of all your friends.</p><br />
<center>
<object width="640" height="360"><param name="movie" value="//www.youtube.com/v/BGDYiTV6S78?version=3&amp;hl=en_GB&amp;rel=0"></param><param name="allowFullScreen" value="false"></param><param name="allowscriptaccess" value="always"></param><embed src="//www.youtube.com/v/BGDYiTV6S78?version=3&amp;hl=en_GB&amp;rel=0" type="application/x-shockwave-flash" width="640" height="360" allowscriptaccess="always" allowfullscreen="false"></embed></object>
</center>
<br /><br />
<p align="left">
Avexir strictly adheres to quality standards set by JEDEC (the Joint Electron Devices Engineering Council) and ISO9001.</p>
<p align="left">
With 100% hand-tested extensively in multiple PC major-brand motherboard environments at its rated speed, Avexir makes sure that both stability and performance of every memory module reach the highest quality criteria.</p>
<p align="left">
<b>Features:</b><br />
- Black PCB<br />
- Black/Red high performance heatspreaders<br />
- Red LED Strobe lighting effect <br />
- SPD programmed at: JEDEC standard 9-9-9-24 values at 1333MHz.<br />
- CAS Timings: 11-11-11-24<br />
- Dual Channel Kit: (2x4GB)<br />
- 100% tested at 1600MHz in Intel & AMD based motherboards<br />
- Lifetime Warranty</p>
ORDER NOW
Avexir Core Blue Series 8GB (2x4GB) DDR3 PC3-12800C11 1600MHz Dual Channel Memory Kit (AVD3U16001104G-2CW) - Blue Light @ £50.99 inc VAT
nonl2br
<p align="left">
Avexir Core Series is designed specifically for the extreme power users who focus on challenging the excellence in high performance gaming experience. The Core Series is developed by Avexir R&D team with 10+ years’ experience of researching in memory core technology and designed specifically for the power users and gamers who demand ultimate performance and extreme reliability gaming modules.</p><br />
<center>
</center>
<br /><br />
<p align="left">
<p align="left">
<p align="left">
- Black PCB<br />
- Black high performance heatspreaders<br />
- Blue LED Strobe lighting effect (See product images)<br />
- Lifetime Warranty<br />
- Sandybridge compatible<br />
- Bulldozer compatible</p>
ORDER NOW
TeamGroup Elite 16GB (4x4GB) DDR4 PC4-19200C16 2400MHz Quad Channel Kit - Black (TPKD416GM2400HC16QC01) @ £169.99 inc VAT
TeamGroup Elite DDR4 offers great value and great performance with superb looks with all black PCB and heatspreader design,.
Specification:-
- CPU Compatibility: Intel Haswell-E ( LGA 2011-3 )
- Chipset: Intel X99
- Capacity: 16GB (4GBx4)
- Quad Channel kit: Yes
- Tested Speed: DDR4-2400 MHz (PC4-19200)
- Tested Latency: 16-16-16-36
- Tested Voltage: 1.2V
- Registered/Unbuffered: Unbuffered
- Error Checking: Non-ECC
- Type: 288-pin UDIMM
- SPD Speed: 2133 MHz
- SPD Voltage: 1.2V
- Features: Intel XMP 2.0(Extreme Memory Profile)Ready
Was [£179.99] Inc. VAT
Only £169.99 inc VAT.
ORDER NOW
TeamGroup Elite 32GB (4x8GB) DDR4 PC4-19200C16 2400MHz Quad Channel Kit - Black (TPKD432GM2400HC16QC01) @ £329.99 inc VAT
Specification:-
- Capacity: 32GB (8GBx4)
- SPD Voltage: 1.2V
Was [£359.99] Inc. VAT
Only £329.99 inc VAT.
ORDER NOW
Kingston Predator 16GB (4x4GB) DDR4 PC4-24000C15 3000MHz Quad Channel Kit - Black (HX430C15PB2K4/16) @ £239.99 inc VAT
Kingston Predator DDR4 is some of the most aggressive looking DDR4 available and looks menacing. Make your opponents fear you with Kingston Predator DDR4.
Specification:-
- Tested Speed: DDR4-3000 MHz (PC4-24000)
- Tested Latency: 15-16-16-36
- Tested Voltage: 1.25V-1.45V
- SPD Voltage: 1.2V
Was [£269.99] Inc. VAT
Only £239.99 inc VAT.
ORDER NOW
Kingston Predator 16GB (4x4GB) DDR4 PC4-21300C13 2666MHz Quad Channel Kit - Black (HX426C13PB2K4/16) @ £221.99 inc VAT
Specification:-
- Tested Speed: DDR4-2666 MHz (PC4-21300)
- Tested Latency: 13-14-14-35
- Tested Voltage: 1.25-1.35V
- SPD Voltage: 1.2V
Was [£249.95] Inc. VAT
Only £221.99 inc VAT.
ORDER NOW
Kingston Predator 16GB (4x4GB) DDR4 PC4-19200C12 2400MHz Quad Channel Kit - Black (HX424C12PB2K4/16) @ £209.99 inc VAT
Specification:-
- Tested Latency: 12-13-13-35
- Tested Voltage: 1.20-1.35V
- SPD Voltage: 1.2V
Was [£229.99] Inc. VAT
Only £209.99 inc VAT.
ORDER NOW
Kingston HyperX Savage Red 8GB (2x4GB) DDR3 PC3-19200C11 2400MHz Dual Channel Kit (HX324C11SRK2/8) @ £62.99 inc VAT
Features:-
Specification:-
Was [£89.99] Inc. VAT
Only £62.99 inc VAT.
ORDER NOW
Kingston HyperX Beast 8GB (2x4GB) PC3-19200C11 2400MHz Dual Channel Kit (HX324C11T3K2/8) @ £61.99 inc VAT
Unleash the Beast on your system. The vicious HyperX® Beast features a dynamic new heatspreader to maximize thermal dissipation for increased reliability. Plus it looks really cool and enhances any system. It’s Intel XMP ready so higher-performing frequencies, timings and voltages are just a few clicks away. The Beast gets along well with third-generation Intel Core i5 and i7 processors and the latest AMD performance and gaming processors. Put the Beast in your corner and crush your opponents — or just conquer your challenging workload.
Features:-
- Capacity 8GB (2x4GB)
- Speed: 2400MHz
- CAS Latency: 11-13-13-31
- 1.55V-1.65V operating voltages enable stable overclocking
- Compatible with Intel XMP auto-overclocking function
- Designed to work with P55, H67, P67, Z68, H61 (AG), X79 and Z77 Intel chipsets; as well as A75, A87, - A88, A89, A78 and E35 (Fusion) AMD chipsets
- Dynamic black design and sharp edge accents
- Lifetime Warranty
Only £61.99 inc VAT.
ORDER NOW
CHECK ALL OUR MEMORY BLACK FRIDAY DEALS HERE!!
So after looking at these what would be the best ram for me? FX8350 cpu ,formula v z mobo .Im looking for 2x4gb at the moment then another 2 later when my wallet's a bit fatter.
